Radiator hoses 69 B Body? #2445486
02/03/18 03:30 AM
02/03/18 03:30 AM
Northern NJ
StukaJU87 Offline OP
Northern NJ
'69-383, b body, 26" radiator.
Want to buy new upper and lower hoses for the Bee.
Was looking at Rock Auto and have no idea what would be the best to buy for a driver car.
What make and part numbers are you guys using that are good quality and fitment?
Thanks in advance.
Scott
1969 Super Bee, 383/4 speed
Re: Radiator hoses 69 B Body? [Re: StukaJU87] #2445540
02/03/18 10:58 AM
02/03/18 10:58 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Last ones we got for my 65 and the 62 was at Advanced.IIRC they were stock gates.Ordered the 62s and they were there next day.Rocky
Chrysler Firepower
Re: Radiator hoses 69 B Body? [Re: StukaJU87] #2445612
02/03/18 01:31 PM
02/03/18 01:31 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Gates #20630 for the upper
Gates #20609 for the lower
Re: Radiator hoses 69 B Body? [Re: gtx6970] #2445685
02/03/18 04:03 PM
02/03/18 04:03 PM
Northern NJ
Northern NJ
Thank you so much!
Scott
Re: Radiator hoses 69 B Body? [Re: StukaJU87] #2445693
02/03/18 04:20 PM
02/03/18 04:20 PM
Northern NJ
Northern NJ
One last thing, shouldn't the lower hose have that coil spring in it?
Is it in there? If not, what material are you using to make one?
Scott
Re: Radiator hoses 69 B Body? [Re: StukaJU87] #2445696
02/03/18 04:29 PM
02/03/18 04:29 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I have never seen them come with a spring - I believe intent is to reuse the old one. I make mine out of stainless steel spring wire.
Re: Radiator hoses 69 B Body? [Re: markz528] #2445697
02/03/18 04:32 PM
02/03/18 04:32 PM
Northern NJ
Northern NJ
Alrighty, thank you.
Scott
Re: Radiator hoses 69 B Body? [Re: StukaJU87] #2445764
02/03/18 06:28 PM
02/03/18 06:28 PM
Illinois
sixbbl 69 Offline
sixbbl 69  Offline
Illinois
will these fit 69 440-6bbl cars?
Re: Radiator hoses 69 B Body? [Re: sixbbl 69] #2445816
02/03/18 07:31 PM
02/03/18 07:31 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Yes.
Re: Radiator hoses 69 B Body? [Re: gtx6970] #2445840
02/03/18 08:25 PM
02/03/18 08:25 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Re: Radiator hoses 69 B Body? [Re: StukaJU87] #2446014
02/04/18 01:52 AM
02/04/18 01:52 AM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Has anyone used any brand of hose that was junk? I guess I've just never seen any hose (that was right for the application) that did not work regardless of brand name.
Re: Radiator hoses 69 B Body? [Re: StukaJU87] #2446151
02/04/18 12:40 PM
02/04/18 12:40 PM
moparx Offline
moparx  Offline
for springs, i have used .074dia. stainless wire and wrapped it around some black pipe [1" i think] that was a little smaller than the i.d. of the hose. since the pipe is smaller than the inside of the hose, it will spring back to the perfect diameter. make sure the ends are deburred and "pig tailed" so they don't contact the inside of the hose, then screwed into the hose. cheap [around $3.99 for a 30" piece of wire at the local ACE hardware] and easy to do.
beer
Re: Radiator hoses 69 B Body? [Re: moparx] #2446172
02/04/18 01:11 PM
02/04/18 01:11 PM
Northern NJ
Northern NJ
beer
That's awesome, thank you for the tip!
Scott
Re: Radiator hoses 69 B Body? [Re: StukaJU87] #2446789
02/05/18 12:56 PM
02/05/18 12:56 PM
moparx Offline
moparx  Offline
one thing i forgot to add that makes this work. drill a 3/32" [.0935] hole in the pipe, then insert the wire till it bottoms. this starts the "pig tail" and it keeps the wire from rolling around the pipe as it's wound up. practice using a coat hanger first to get a feel for this. if running a coolant with lube and anti corrosion inhibitors, you could even use the coat hanger if you wanted ! i prefer stainless though, just for peace of [my] mind.
beer
Re: Radiator hoses 69 B Body? [Re: StukaJU87] #2447282
02/06/18 06:23 AM
02/06/18 06:23 AM
southeast NE
lemondana Offline
lemondana  Offline
southeast NE
Rockauto, use Continental 60659 lower, 60621 upper. Continental bought out Goodyear industrial products. So the Continental products you now see were formally Goodyear..
The spring in the lower hose served only for the purpose of the vacuum fill on the assembly line. I've worked at this Goodyear plant for 30 years. Back when they made the big block hoses for instance. The original hose that went to the Chrysler factory had the springs in them, the replacement hoses that were sent to the dealers and the Goodyear brand were the same hose but NO spring was installed. If you need a spring then you have some other problem with your cooling system. YOU SHOULD NOT NEED A SPRING!
