Re: Door/Quarter Vapor Barrier - What Material? Any Upgrades?
[Re: GoodysGotaCuda]
#2445098
02/02/18 09:58 AM
02/02/18 09:58 AM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
Performance car graphics has kits for some mopars
#2445114
02/02/18 11:19 AM
02/02/18 11:19 AM
Posts: 4,922 new berlin wisconsin
Mr T2U
you are limited by your imagination. if i were doing this i would just find the thickest plastic film i could buy and attach with strip calk. then find some thin sound deadening for under the carpet then trim to fit under the trim panels..
perception is 90% of reality
#2445115
02/02/18 11:24 AM
02/02/18 11:24 AM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
I just used a 6 mil poly sheet from home depot. The original caulk was a string caulking. I just rolled plumbers putty into thin strands and used that. Once installed, it looked pretty close to original. I also sprayed sound deadener in the doors. I think the issue with using a foam is that it will keep the door panel from sitting flush against the door shell. Though on an e-body, I don't think you will have that issue due to the way the door panels screw on. For a b-body using the fiber board cards, it would be more of an issue.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
#2445195
02/02/18 02:12 PM
02/02/18 02:12 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I upgraded mine using the double-foil-sided insulating mat from Speedway Motors and taped it along the edges of the door, just short of the plastic door panel using the aluminum ducting tape with the foil backing.
It has a fluffy, flame resistant matting that really cuts down on noise, fumes and heat. I cocooned my entire interior with that and Dynamat Extreme. The car sound like your sitting in a bank vault when you close the doors. It really trips people out when they sit in it.
I lost my pictures of the installed product when my computer died.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
#2445900
02/03/18 10:05 PM
02/03/18 10:05 PM
Posts: 1,894 Harriman NY
71GTX471
Harriman NY
Go by a mattress store & garbage pick one of the thick plastic bags they come in all the plastic you'll ever need,prefit the plastic making all the necessary trim cuts/openings,3M spray adhesive & using a piece of cardboard to block/direct the spray pattern where you want it.
