Re: Lets hear your 1/8 th mile predictions for tonight..........
[Re: Thumperdart]
#2444978
02/01/18 11:56 PM
02/01/18 11:56 PM
Posts: 2,501 Sydney,Australia
tex013
Sydney,Australia
faster than my 1/8 mile tomorrow good luck Thumper Tex
New best ET 10.259@129.65 . New best MPH 130.94 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: pittsburghracer]
#2444989
02/02/18 12:18 AM
02/02/18 12:18 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
His current 112 MPH isn't close enough to get into the 5.99 ET Its a indicator of potential, he would want around 115/116 mph for a sub 6 sec. But Hes going to be close. Not necessarily. Every combo is a little different. I agree, see you had a 6.001 at 113.27 MPH, do you remember what your 60Ft. was for that. I'm guessing sub 1.30,s
[Re: Sport440]
#2445005
02/02/18 12:34 AM
02/02/18 12:34 AM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
His current 112 MPH isn't close enough to get into the 5.99 ET Its a indicator of potential, he would want around 115/116 mph for a sub 6 sec. But Hes going to be close. Not necessarily. Every combo is a little different. I agree, see you had a 6.001 at 113.27 MPH, do you remember what your 60Ft. was for that. I'm guessing sub 1.30,s Ya it makes some pretty good steam for a slip n slide powerglide. Best 60 foot so far was a 1.25
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: Thumperdart]
#2445219
02/02/18 02:20 PM
02/02/18 02:20 PM
Posts: 8,104 Tulsa OK
Bad340fish
Tulsa OK
I think with just three passes it will be impossible to say good or bad.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2445222
02/02/18 02:26 PM
02/02/18 02:26 PM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I think with just three passes it will be impossible to say good or bad. t 2 passes. He left in second gear on the one pass
[Re: gregsdart]
#2445258
02/02/18 03:47 PM
02/02/18 03:47 PM
Thumperdart
State of confusion
Thankxxx guys and maybe I can make the Famoso T&T on the 17th of this month and figure some stuff out so time will tell.............I had a bad feeling yesterday before we left and didn't even want to go but went anyhow and I want to thank Shiloh for his help and maybe he'll chime in w/what he saw my goofy azz do............... Greg, I appreciate the offer and if you were here maybe we could do something but if you need carb help just call me and I'll see if I can help ya out...........As far as the shock working, apparently they did their job and they felt nice n smooth not violent like before w/the Ranchos................peace!
[Re: Thumperdart]
#2445267
02/02/18 04:21 PM
02/02/18 04:21 PM
Posts: 19,610 Las Vegas
Al_Alguire
Las Vegas
Dom I think you just need some seat time and laps. Hard to get anything dialed in with only a couple hits. Fontana has TNT's occasionally might be worth the trip. Just need some time to make some laps and try some stuff. You will find it harder and harder to find improvements the fast you go.
[Re: Thumperdart]
#2445280
02/02/18 04:41 PM
02/02/18 04:41 PM
Posts: 10,155 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Dom, i was thinking of someone local to you. Someone known for good suspension tuning skills, well above my meager knowledge! I'm a loooong ways away this year !
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: racerx]
#2445336
02/02/18 06:28 PM
02/02/18 06:28 PM
Thumperdart
State of confusion
Thump ...I remember you pulling weight out of the car,what was the final #'s for this? Plus I see your using a different shocks. Ya, I removed the 2nd battery but put it back for these tests but as SPORT440 suggested, maybe the new shocks didn't need the ballast after all.........lots to do to get ready for what may be my last pass till my car is 100% legal..........
