Re: Home Brew'd engine test stand idea's? [Re: 4spdana] #244474
03/07/09 09:57 AM
03/07/09 09:57 AM
Windsor, Pa
DartSport Offline
DartSport  Offline
Windsor, Pa
Built this one so we can break it down to make a transport stan if needed, and it rolls real nice with the big wheels and does not walk with engine running
Can Never Have Too Much Fun!!!!!
Re: Home Brew'd engine test stand idea's? [Re: Blakcharger440] #244475
03/07/09 10:18 AM
03/07/09 10:18 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
That engine run stand on garagejournal looks to be a good one. Too bad there arent more pics of how he built it.
Etek is a member here also, so I'm sure he will chime in if he sees this.
Re: Home Brew'd engine test stand idea's? [Re: JDMopar] #244476
03/07/09 11:37 AM
03/07/09 11:37 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Here's mine. I havent painted it yet...lol. But I have a dirt area outside the garages, so I needed big wheels. The pnuematic tires keep it from shaking the floor or moving around, and I made it high enough to run the valves comfortably and open on the bottom should I need to drop a pan. I think it was $28 in recycler steel, the radiator from a junked plow truck (large w/3 core), plus the casters in the front, the tractor tires for the rear, and the gages. I pull the gage cluster and everything else stays out in the weather. I dont want to stand in the exh path.
Re: Home Brew'd engine test stand idea's? [Re: Bill MeLater] #244477
03/08/09 07:17 PM
03/08/09 07:17 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
The starter plate looks like a good lowbuck idea. I wonder if you could use a torque convertor instead of the flywheel?
This is the land of the free because of the brave
Re: Home Brew'd engine test stand idea's? [Re: Bob_Coomer] #244478
03/10/09 09:06 AM
03/10/09 09:06 AM
Jacksonville, Fl
426runner Offline
426runner  Offline
Jacksonville, Fl
Stand? We don't need no stinkin' stand!
http://www.youtube.com/watch?v=ndgYgQYrW7Y
Later, Sandy '70 HEMI Road Runner B5/B5, 4 spd "Sandy's Garage" on Facebook
Re: Home Brew'd engine test stand idea's? [Re: rbstroker] #244479
03/10/09 12:32 PM
03/10/09 12:32 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I doubt it. ATF would surely come out and make a mess. Run it dry and it will eventually self-destruct inside and come out of balance. That's assuming the flexplate doesn't break first - the converter really needs some support on the rear hub while it spins.
Flywheel is a much better idea.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: Home Brew'd engine test stand idea's? [Re: 426runner] #244480
03/10/09 10:36 PM
03/10/09 10:36 PM
Joplin, MO
734x4PW Offline
734x4PW  Offline
Joplin, MO
Yeah, that's a really smart idea! Let's run an engine without a frame, open exhaust manifold and no cooling system. Hey, let's run it for a long time, it won't hurt it!
Mark
Re: Home Brew'd engine test stand idea's? [Re: 734x4PW] #244481
03/10/09 10:51 PM
03/10/09 10:51 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
I made one like Dartsport's from a generator frame. I can bolt the engine on with a bell housing and support the front with scrap mounts. It was free, and I used stuff I had laying around.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: Home Brew'd engine test stand idea's? [Re: phantomx] #244482
09/07/09 06:59 AM
09/07/09 06:59 AM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
A True Hybrid: Burns Gas AND Rubber!
Re: Home Brew'd engine test stand idea's? [Re: phantomx] #244483
09/07/09 07:02 AM
09/07/09 07:02 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I built one from 2" muffler pipe for doing calibration stuff on 2.2 and 2.5 engines.
Works good! Factory motor mounts, used a old transaxle case that the diff blew out, Omin aluminum radiator, wiring harness from an 88 CSX-T, Napa battery and a 3 gallon fuel jug.
Has casters so I can roll it about, nice and sturdy too.
Makes a nice generator in a pinch.
