Re: 225 slant [Re: MarkZ] #2445425
02/02/18 11:56 PM
02/02/18 11:56 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Originally Posted By MarkM
I recall there being something about a guy cutting up some 5.7 Hemi heads and modifying it to fit the /6.
https://www.jalopyjournal.com/forum/threads/home-brew-hemi-head-slant-six.372471/
Don't know if it was BS or not though. The pictures were hosted on photobucket, so those are gone.
It was a hoax. A really good one, but crap just the same.
Re: 225 slant [Re: Crizila] #2445694
02/03/18 04:22 PM
02/03/18 04:22 PM
New York
polyspheric Offline
polyspheric  Offline
New York
And, as I said at the time:
"I wonder how many cut-n-shuts he did to the original head(s)?
Slant bore spacing is alternately 3.98" and 4.00".
The 5.7 is 4.46", just like the LA.
This means if you start at the front, the #2 cylinder is .46" too far back, the #3 is .92", #4 is 1.38", #5 is 1.84", and #6 is 2.3"... hanging off the back of the block.
Even cutting each head in halves (2 chambers each), each pair of chambers (if centered) is off by .23".
Lot of welding."
Boffin Emeritus
Re: 225 slant [Re: polyspheric] #2445703
02/03/18 04:42 PM
02/03/18 04:42 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Has anyone ever found a head with the same (at least similar) bore spacing? Yes, I know it alternates .020" but really a non alternating one would be fine
Re: 225 slant [Re: Crizila] #2445898
02/03/18 10:01 PM
02/03/18 10:01 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
4.6 Ford is close.
Re: 225 slant [Re: Crizila] #2445903
02/03/18 10:07 PM
02/03/18 10:07 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I'm tired. Let someone else do this.
Boffin Emeritus
Re: 225 slant [Re: Crizila] #2446020
02/04/18 02:00 AM
02/04/18 02:00 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Whatever
Boffin Emeritus
Re: 225 slant [Re: Crizila] #2446081
02/04/18 06:53 AM
02/04/18 06:53 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Already been done almost 50 years ago. A guy who worked for Ford used a combination of SOHC 427 and Pinto parts to make an OHC 170. He made cam stands on the head, had a cam ground, modified SOHC followers, and used a Pinto style belt driven off a sprocket between the crank and flywheel. He also made a spacer for between the block and bellhousing. IIRC, it was in a '63 Valiant.
The motor came up for sale a few years ago. I thought Lou Madsen bought it, but it went somewhere else.
FWIW, my good motor has made real close to 300 n/a and 375 on a little spray for waaaaayyyyyy less than $10K.
Re: 225 slant [Re: Crizila] #2446155
02/04/18 12:46 PM
02/04/18 12:46 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have a faint memory of a slanty race group maybe in Michigan with some of them tapping in the 10's.I haven't bought a mag in years so I'm not up on the latest.
I do have a friend that built an AWB Dodge,put a turbo on it with a big stuff 3 setup.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 225 slant [Re: Crizila] #2446157
02/04/18 12:49 PM
02/04/18 12:49 PM
hemi-itis Offline
hemi-itis  Offline
That pic he still is blowing through a carb.Have pic's in my archives,,,,,,,somewhere.Having over 10k images,it's getting harder to find stuff PLUS,,,,,,I have CRS! work
Re: 225 slant [Re: polyspheric] #2449762
02/10/18 09:14 PM
02/10/18 09:14 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted By polyspheric
Shades of Luke Duke.
Re: 225 slant [Re: Crizila] #2455432
02/22/18 02:50 AM
02/22/18 02:50 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Thanks for all the input guys. Lots to mul over. Ya, not lookin to run mid 10's. Just want to [censored] it up a bit. With the inherent limiting factors mentioned, sounds like puffing it might be one way to go. My other option might be to just do a little home port work on the existing cast iron head, up the C.R. a bit, intake, headers, cam and call it done. If I could squeeze 200 HP out of it (normally aspirated) that would be great. Ether way, I'm sure just dumping a stock SB in to it would result in more HP with a lot less $. This is my first /6 endeavor, so I'm on a learning curve at this point. On the plus side, at 112 HP, my tinker toy drive line should last for ever. beer
Fastest 300
