Turn signal ground issue
#2441681
01/27/18 07:57 PM
01/27/18 07:57 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Years ago installed a dash tach in the place of the clock in my ‘72 Charger. Ever since then when the right turn signal is turned on the tach bounces from zero to the idle rpm. The left signal does not do it. Seems it would be a ground issue. I have the cluster out working on other mods so wanting to address the issue now. Any ideas what to do or look for?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Turn signal ground issue
[Re: dfsmopars]
#2441688
01/27/18 08:07 PM
01/27/18 08:07 PM
dfsmopars
Kentucky
Here’s a picture of the back of the tach. Screwdriver painting to the hole for the right turn signal socket.
[Re: dfsmopars]
#2442098
01/28/18 10:59 AM
01/28/18 10:59 AM
dfsmopars
Kentucky
The bottom socket is for the instrument light. No problem. The turn indicator ground strap screw was not tight. I am hoping after tightening it more, that will cure it. I think the extra ground is a good idea.
