Re: 72 duster
[Re: RustyM]
#2443311
01/30/18 11:40 AM
01/30/18 11:40 AM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
I'm lazy... and I like things easy to work on. Tube K, rack steering, coil overs were one of my better mods. Plenty of room for oil pans, no torsion bars getting in the way of headers, no hassle over getting engine diaper to fit. My chassis shop of choice made my set up, but there are plenty of them out there now that can show up on your porch in a box. We're not terribly serious about this stuff, but we've ran ladder bars on our last two rides. Found they work better than leaves, and once we set corner weights and ride height, we pretty much never touch them. And speaking of lazy, the two piece trans tunnel floor was a really nice addition as well. That also came about as we do run a 727 and the CSR shield wouldn't fit.
btw a nice front end set up delivered to your door: look up Tory Shellehamer on FB. Makes some nice stuff.
Re: 72 duster
[Re: RustyM]
#2443535
01/30/18 05:24 PM
01/30/18 05:24 PM
Posts: 11,579 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Cm: If you were going to go tubular up front, who would you suggest?
Secondly : do you or anyone here have a suggestion on complete front end rebuild kits for this car, with good parts/ bushings should we decide to go that west.
Thirdly : I have an opportunity to pick up a built Dana with Wilwoods / Strange axles/ Strange billet cover/ 4:56 spool that’s set up for 4 link - 2200 bucks. Came out of a tube chassis 8:50 duster that took a bad turn. Advantage Other than being a Dana is it’s set up and I don’t think I can build an 8.75 with cal’s / monoleaf / spool / gear / brakes any cheaper really .
Thoughts? Honestly, the only one I have any experience with is the Alterkation. We used those in a restomod deal and they seem to be fine. Car drove great with that and a 4 bar in the rear. I'm sure others have had experience with other units. There are places that do suspension kits or you can probably source it from NAPA or somewhere. I try to avoid Chinese stuff, but that's hard to do these days. If I were replacing stock stuff, I would probably go on and convert it to '73 and up parts. If I were building a new car, I would not use a D60 if it were free, unless it were a Stocker and had to be that or a 8.75. Too many negatives. But, ignoring my preference for the 9" - I've seen a lot of cars built where a used rear, that someone pick up cheap, was used and the car was built to the rear, rather than the other way around. They usually end up being a mess - built in a driveway somewhere and not close to being right, brackets are junk, driveshafts run crooked, wheel spacers needed, wheels not in the same place one side to the other or they have to use some queer wheel offset, 4 link is a mess and no way to get the bars in right, etc. I wouldn't consider it without close inspection and being satisfied that it exactly fits my needs - who built it and was it done correctly; is it straight, square and not bent; where is the pinion offset; how wide is it; what is the C-C of the 4 link brackets; are the brackets 20 years old with an obsolete geometry; etc.? If the car has to be substantially compromised to use it, it's not worth it if it's free.
Re: 72 duster
[Re: RustyM]
#2443544
01/30/18 05:35 PM
01/30/18 05:35 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
This is not rocket science to be sure. Lots of proven combos to do what you are trying to do. You need to make a decision on exactly what you want to do with the car. Is this a temporary deal just to have something to race for now. Id its the latter then the KISS principle seems to be a good way to go. You are not making a lot of HP and just about any rear suspension can EASILY handle it. If this is a temporary race car, which is kind of what I'm getting here they why go extravagant. Just fix what needs to be addressed to make the car safe and legal to run. Caltracs are MORE than up to the task of making the car work easily. Why reinvent the wheel or invest a lot of money in something that is going to scratch a temporary itch while you chase/build the NSS car. Seems to me the money is better saved for what your real end goal is. Just make what you have safe and legal go racing and learn.
Re: 72 duster
[Re: RustyM]
#2443568
01/30/18 06:29 PM
01/30/18 06:29 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Geez. I had to go back and read the OP. Didn't catch this was a toy just for this year. Sure don't want to tackle a big project and expect to have it up and running early this season. Or even a small one. I'd be looking for something done, plug a motor in it and go. Always less than building as well.
Re: 72 duster
[Re: RustyM]
#2443752
01/30/18 11:41 PM
01/30/18 11:41 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Be careful putting a brace on that housing. I will bend if not done correctly.
I had a 72 340 Duster that I would love to have back. They are near and dear to my heart.
Re: 72 duster
[Re: CMcAllister]
#2444431
02/01/18 02:06 AM
02/01/18 02:06 AM
J_BODY
aZLiViN
Geez. I had to go back and read the OP. Didn't catch this was a toy just for this year. Sure don't want to tackle a big project and expect to have it up and running early this season. Or even a small one. I'd be looking for something done, plug a motor in it and go. Always less than building as well. I'm guilty as charged also... I certainly wouldn't have done some of the things I mentioned on a short term project. I have an S60 in the car, and wish we'd gone 9" based. ...and to me "racecar" usually means trans brake, and 8.75 doesn't fit into the equation at all...
Re: 72 duster
[Re: RustyM]
#2445029
02/02/18 02:33 AM
02/02/18 02:33 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you are watching you budget do some measuring. My sons 1970 Duster has a 15-10 wheel and I think 5 inch backspace. Stock location caltracks with mono leafs. Stock wheelwells and ran a 10 inch micky Thompson slick but has now switched to radials. Last time out he ran 6.54 in the 1/8 mile with a fresh 360 and zero tuning
Re: 72 duster
[Re: RustyM]
#2445492
02/03/18 03:47 AM
02/03/18 03:47 AM
Posts: 566 Texas
RustyM
Texas
Anyone know exactly where to cut, or, take a pie cut out of the front of the rear quarters at the front of rear wheel wells for slick clearance ? I think I know where I want to make the cut but would like to confirm. It’s just really tight on the front side of the tire on the lowest side of the wheelwell.
I know I have seen pics, read an article but danged if I can find either .
Parts rolling in next week, trying to get as much done as possible before they arrive. Thanks again for all the help.
Plan as it stands: Finish pulling trim. Media blast engine bay / prep for paint . Strip/ sand body/ media blast what is needed. Should finish most of that tomorrow .
Interior is stripped out other than main wiring section from dash/ steering volume to engine bay- it comes out in the morning. I will retain twilight and headlight electrical runs.
Clean/ prep interior metals for primer/ paint.- hope to finish prep tomorrow or Monday.
Strip/ DA body for primer/ paint-/ paint engine bay, should finish by Monday night.
Body work and primer should go pretty quickly this week.
Wheels and Tires arrive Tuesday.
Strange spool/ 8.75 build kit arrives Wednesday and rear goes to our builder . Get it back Thursday or Friday .
727 trans kit from A&A should get here Thursday or Friday.
Gerst tubular front suspension , coil overs, Viking dual adjutibke shocks should arrive Thursday.
Cal Trac’s/ split mono - probably Friday. AR engineering motor plate - hopefully by Friday. Fuel cell/ pumps/ regulators/ seats hopefully by Friday.
Start mock up of driveline by Saturday . Hopefully take a correct roller to Fabricator by following Monday or Tuesday for cage - get car back Friday or Saturday to final the body, stick in booth for paint and start final assembly .
I think we can pull this together if build schedule doesn’t get completely blown up prior to final assembly .
If my math is right and, due to the help here- should be a fun car and, be on time for season here .
Caveat- Car hits a frame machine early Monday to be checked- if all is well, a very short visit, couple hours maybe. If not- I will lose a day or two.
Having a blast in Texas!
