Bench and Bucket Seat mounting bolts #244124
03/05/09 02:41 PM
03/05/09 02:41 PM
Sterling Conn
manymopars Offline OP
Sterling Conn
I need to know if there is anybody out there that might be reproducing the special round head seat track bolts that mount the seats to the floor?I pulled the seats out of my 67 R/T Convert to have the seats recovered,and could only save one out of the eight bolts.These bolts are squared off under the round head like a carriage bolt and are swedged to the seat tracks.
Re: Bench and Bucket Seat mounting bolts [Re: manymopars] #244125
03/07/09 09:47 PM
03/07/09 09:47 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
If you can find a set of 'junk' seat tracks from another Mopar, you can pound out the bolts and re-use them with your tracks. I pounded some out of a set of bench seat brackets last summer. Thread a nut on the end of the bolt, place a socket under/around the head, and give it a solid hit.
After installation, I added small tack weld to opposite sides of the head to make sure the bolts stayed put.
