Re: Detail Question on Plug wire location for Hemi DP Prestolite
[Re: dragon slayer]
#2441116
01/26/18 06:21 PM
01/26/18 06:21 PM
Posts: 3,069 Michigan
A727Tflite
Maybe I am missing it but what are you trying to accomplish?
[Re: dragon slayer]
#2441128
01/26/18 06:53 PM
01/26/18 06:53 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: dragon slayer]
#2441134
01/26/18 07:08 PM
01/26/18 07:08 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
With many of these distributors being rebuilt or purchased as rebuilt back in the day you may not have original internal parts and the clocking is off.
Regardless of new/rebuilt, the orientation of the main shaft will be the same. IOW, the cam plate and the rotor index off of the main shaft.
[Re: dragon slayer]
#2441313
01/27/18 01:09 AM
01/27/18 01:09 AM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
Cam installed correctly and intermediate shaft installed correctly, #1 at bottom 6 o’clock.
68 Charger 70 Cuda
[Re: dragon slayer]
#2441686
01/27/18 08:04 PM
01/27/18 08:04 PM
John_Kunkel
Rio Linda, CA
FWIW, here's a pic of a pre-'70 with the VC pointing to the front under the fuel lines. Does look like #1 is at 6 o'clock.
[Re: dragon slayer]
#2442938
01/29/18 04:45 PM
01/29/18 04:45 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
I always had my #1 two holes to the left of the front cap hold down clip as you’re looking from the front. At top dead center with your timing mark on 0, the slot in top of the oil pump drive gear is supposed to be parallel to the centerline of the crankshaft. My #1 plug wire for my old Hemi and my 440-6 motors was always in the cap terminal closest to the front of the valve cover but I think it was just two holes towards the passenger side of the cap hold down clip?
