correct 62 300h dual 4 barrels choke setup #2440676
01/25/18 06:39 PM
01/25/18 06:39 PM
texas
magnum440 Offline OP
texas
hello working on a 62 330h 413 with 2 4barrel carbs,,,trying to
set up the choke on it,,theres no heat tube and choke plate is flat...found one pic from mancini shows heat tube going from plastic choke plate with a hole in it to exhaust manifold but theres no hole on right exhaust manifold..this car has 58000 miles on it,,,any other input would be appreciated,,thanks in advance ...https://youtu.be/J6mqcVrV9tk?t=51
Re: correct 62 330 dual 4 barrels choke setup [Re: magnum440] #2440740
01/25/18 09:59 PM
01/25/18 09:59 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
Here's a picture of the choke setup on my father's 58 Fury. I don't know if all 2-4's of the era had the same setup or not. I don't have a real good detail down by the manifold. There is a triangular boss on the top which has a small tube sticking out towards the rear of the car.
Re: correct 62 330 dual 4 barrels choke setup [Re: cudaize] #2440743
01/25/18 10:04 PM
01/25/18 10:04 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
Here's a little better shot of down by the manifold.
Re: correct 62 330 dual 4 barrels choke setup [Re: cudaize] #2440771
01/25/18 11:33 PM
01/25/18 11:33 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
300H goes the same place,into the top of passenger side exhaust manifold.
Re: correct 62 330 dual 4 barrels choke setup [Re: magnum440] #2440827
01/26/18 01:44 AM
01/26/18 01:44 AM
PA
Scully Offline
Scully  Offline
PA
That's a 383, is it a friend of yours, I'm wondering if it's an old police car. It's been said that very few 383/343 cars were made and that they were mostly cop cars or dealer installed.
Re: correct 62 330 dual 4 barrels choke setup [Re: 62maxwgn] #2441069
01/26/18 04:53 PM
01/26/18 04:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Looks like the tube went behind the valve cover instead of over the top.
Re: correct 62 330 dual 4 barrels choke setup [Re: John_Kunkel] #2441461
01/27/18 01:36 PM
01/27/18 01:36 PM
moparx Offline
moparx  Offline
never noticed a black fuel filter before. is there a source for the decal so one could paint a commonly available wix filter and add the decal ?
beer
Re: correct 62 330 dual 4 barrels choke setup [Re: John_Kunkel] #2441561
01/27/18 04:16 PM
01/27/18 04:16 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
John,that was dependent on the application,there were variances in the heater/blower housing interference that made the difference.
Re: correct 62 330 dual 4 barrels choke setup [Re: 62maxwgn] #2441682
01/27/18 07:57 PM
01/27/18 07:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
300E and 300H (the subject) difference? A/C box is definitely different.
Re: correct 62 330 dual 4 barrels choke setup [Re: John_Kunkel] #2443014
01/29/18 07:17 PM
01/29/18 07:17 PM
texas
texas
thanks for input..just looked on block and it is a S383...im guessing choke was different on 383 but i dont see anywhere where a heat tube would go...not on manifold either the carbs are 3259s and 3258s,,i wanted to put the choke because it wont come off fast idle...
