Balance and weght mods- worth it? Bang:buck? What order?
#2439932
01/24/18 11:20 AM
01/24/18 11:20 AM
Posts: 111 Connecticut, USA
MRGTX
Connecticut, USA
Everybody knows that less mass and better balance means a more capable (and usually more fun) car.
Going from a stock car, which weight reduction mods would you start with? Which ones would you not bother with?
How far would you be willing to go with a street driven car? What are your plans?
Lighter wheels? Fiberglass hood? Fiberglass front bumper? Fiberglass rear bumper? Aluminum bumper brackets? Battery relocation? Other fiberglass body part? Lexan(?)windows?
Re: Balance and weght mods- worth it? Bang:buck? What order?
[Re: MRGTX]
#2439947
01/24/18 12:04 PM
01/24/18 12:04 PM
Posts: 200 Colorado
Bob J
Colorado
I was thinking of moving the battery but you have the added weight of the cable. With modern light weight batteries is it worth it over the weight of the cable? On the rear fiberglass bumper my thought is after driving a 911 I don't want that large weight of bumper and brackets that far back. The large weight behind the wheels will move you around, granted it's less than in a 911 but it's way back there.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
[Re: MRGTX]
#2439985
01/24/18 01:21 PM
01/24/18 01:21 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Another consideration and Bob touched on it, weight location. There are certain things you cannot do without, even getting a lightweight battery, you still need a battery and it can be located in a more advantageous location. Putting the battery and the end of the vehicle is a bad choice. You want the weight of the vehicle centered and down low. If you are going to relocate things, or can relocate them give thought to putting it and low down as you can and as close tot eh center as you can. https://en.wikipedia.org/wiki/Moment_of_inertia
[Re: Bob J]
#2440235
01/24/18 09:22 PM
01/24/18 09:22 PM
Posts: 350 central IL
myduster360
central IL
I was thinking of moving the battery but you have the added weight of the cable. With modern light weight batteries is it worth it over the weight of the cable? On the rear fiberglass bumper my thought is after driving a 911 I don't want that large weight of bumper and brackets that far back. The large weight behind the wheels will move you around, granted it's less than in a 911 but it's way back there. Apples and Oranges,,A 911 is in the 40/60 range for weight distribution(for very good reasons) but most mopars are nearly the opposite,,they nearly have 60% of their weight on the front axle Any Mopar has a LONG road just to get anywhere close to 50/50. Any weight you can get off the FRONT end will not only improve handling but also braking. So YES get the battery in the trunk. Front Bumper & Brackets, hood I'm going so far as to swap in a 300hp Pentastar V6 into my 72 Swinger. It's not only 200lb lighter but 10" shorter than an iron small block. So its light weight is also centered further to the rear. www.forabodiesonly.com/mopar/attachments/upload_2017-12-23_19-5-46-png.1715123788 www.forabodiesonly.com/mopar/attachments/upload_2017-11-25_19-28-43-png.1715114595
1972 Swinger 3.6L Pentastar Diablo CMR tuner
[Re: MRGTX]
#2440258
01/24/18 10:18 PM
01/24/18 10:18 PM
Posts: 200 Colorado
Bob J
Colorado
I know that a 911 is a different animal but that bumper out back on a GTX is way out there. Drag racers also put the battery way out back for weight transfer. That and a steel bumper and brackets will only help getting the pendulum effect going. Moving the battery over the rear axle might be worth the added weight of the cable as it gets the weight of the nose. Or go with a battery that weighs 2 or 3 lbs but not cheap. Run 1 Hi Low horn not 2 as it's out front and cheap to do.
I'm trying to get my GTX under 3400 and most of the weight is from the nose of the car. You can also do some drilling. It's a power window assy. that I took a pound out of ans 1.5 lbs out of the backs.
[Re: MRGTX]
#2440271
01/24/18 10:40 PM
01/24/18 10:40 PM
MRGTX
Connecticut, USA
Awesome stuff, guys! I’ve been sold on the concept of a battery relocation job for a while...I’m thinking that mounting it right behind the rear passenger seat would be optimal for handling. Has anyone done that? Did you make your own kit or did you buy one? Most tracks (drag, road, Autox) require a metal box, correct? While the Pentastar swap is an insanely cool project, some of us are V8 loyalists. too bad the Modern Hemi engines still run iron blocks! Aluminum heads seem like a golden opportunity at least...how much weight to be shaved there on a small block?
[Re: MRGTX]
#2440300
01/24/18 11:43 PM
01/24/18 11:43 PM
myduster360
central IL
You'll gain even more from relocating the battery if its as far back as you can get. So not the high up near the rear seat back but even further back by the bumper. If a 20lb battery is placed say 2ft behind the rear axle, it will create a moment about the axle and is like removing an additional 5lb right off the Front axle of a 3600lb B-body.
Removing rear weight hurts weight distribution but can still have its benefits. Hyperco rear fiberglass Leafs will shave a good 70lbs of static weight off the car but most of it is UnSprung weight, which is a great thing for a portly live axle.
[Re: MRGTX]
#2440312
01/25/18 12:09 AM
01/25/18 12:09 AM
Posts: 27,465 So Cal
autoxcuda
So Cal
Next battery I buy will go under the passenger seat. Small gel cel like an Odyssey or something My steering box is worn I'm thinking of a borgenson. Going to upgrade front brakes with aluminum calipers, hubs, adapter Going to install aluminum power steering pump with remote resivior. Want to remove heater and heater box. I currently have: one plastic horn, aluminum: heads, radiator, water pump, master clylinder, My 68 Barracuda coupe:
[Re: myduster360]
#2440328
01/25/18 12:26 AM
01/25/18 12:26 AM
Supercuda
About to go away
About to go away
up yours
That thinking is adequate for straight line racing. Putting the battery far back is not ideal in racing involving turns. The farther you have a weight from the center the more it wants to resist turning. That is why a mid engined car out handles a rear engined one, all else being equal. Under the rear seat pass side for the battery, ala VW Bug, is ideal, but likely no room.
[Re: autoxcuda]
#2440480
01/25/18 11:57 AM
01/25/18 11:57 AM
MRGTX
Connecticut, USA
... Awesome...I've come to realize that you have blazed a lot of trails with your Barracuda so I'm always interested in your findings, your advice and your plans! Which brakes are you looking at? How much weight will those save over stock style disk brake calipers? Plastic horn? This never occurred to me. Which one did you go with? The aluminum steering pump sounds like a good opportunity to save a few lbs off of the nose but did you ever consider just going to a manual box?
[Re: Supercuda]
#2440506
01/25/18 01:02 PM
01/25/18 01:02 PM
myduster360
central IL
That thinking is adequate for straight line racing. Putting the battery far back is not ideal in racing involving turns. The farther you have a weight from the center the more it wants to resist turning. That is why a mid engines car out handles a rear engine one, all else being equal. Under the rear seat pass side for the battery, ala VW Bug, is ideal, but likely no room. No, in fact its pointedly true for any car trying to turn. The OP B-body has nearly 60% of its weight on the front wheels. That's a huge amount of weight. Same with autoxcuda's A-body. So the Center of Gravity of those vehicles is quite forward the car's geometric center. Its about the CG is where the vehicle will turn. Its a fact that cars with a REAR weight bias both handle and brake better compared to a cars with a FRONT weight bias( All mopars). Its also a fact that moving the heavy weight of the Battery furthest to the Rear of the car will contribute the MOST to moving the CG rearward. But move the same Battery half as far and that contribution will be diminished accordingly. Given the fuss of moving a battery, why bother moving it half way?Seems the Spare Tire well of an A-body(like all LX cars) would be a great place for a battery. But using a set of scales to pick the perfect spot would be ideal.
[Re: MRGTX]
#2440632
01/25/18 05:04 PM
01/25/18 05:04 PM
autoxcuda
So Cal
... Awesome...I've come to realize that you have blazed a lot of trails with your Barracuda so I'm always interested in your findings, your advice and your plans! Which brakes are you looking at? How much weight will those save over stock style disk brake calipers? Plastic horn? This never occurred to me. Which one did you go with? The aluminum steering pump sounds like a good opportunity to save a few lbs off of the nose but did you ever consider just going to a manual box? Looking at Willwood or Dr Diff 13". Universal JC Whitney/Summit type horn. Newer little cars have real small plastic horns. I drive it a lot on the street and go down to more urban So Cal areas. Even on a road course I for a heavy street car I like it. I don't autocross it anymore, but I would not want it for that.
[Re: MRGTX]
#2440635
01/25/18 05:11 PM
01/25/18 05:11 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Weight reduction is one the most important factors, along with balancing... side-to-side (l-r) for each half (f/r).... with the driver and as you plan to drive/race it the majority of time.
Front seats can drop weight 20-30-40 pounds.
Master brake cylinder.. go with aluminum. and consider keeping or removing the power booster.
Radio stereo? eliminating all can reduce about 20-30-40-50 punds, pending what you have.
Do you need the passenger door mirror? Do you need a front and/or rear spoiler? Carpeting and insulation?
The list from everyone can be further expanded.
But, are you considering running in any sanctioned organized club events that have RULES/restrictions per your chosen class? consider your choices. IF you're an outlaw... running without RULES for mods of your car, then there's no limits, but, if you choose to run competitively in a sanctioned club event with RULES/restrictions, then decide ahead and make your mods very selectively. In other words, you don't want to over-or-under-mod your car then find yourself not competitive... and not happy having the fun you're hoping for.
With my own Challenger T/A (cloned long time ago, back in the 70's.. 80's), I followed the SCCA E/Street Prepared Solo II class rules for any mods done to the car... was ultimately able to get the weight of the car down, legally, to ~3150 (1/8-1/4 tank gas) w/o driver, with ~52f/48r% balance, and also had the side-to-sides equaled nearly same to each other... with driver as raced. Its also street/hwy driven.. raced seriously and highly competitively at AX/HSAX/HPDE events.
My battery (lt-wt Optima) is located far r/r of the trunk...as that's where the scales showed it to be best located. I tried it centered above the differential... scales showed it better far r/r. Overall, car handles great!
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2440684
01/25/18 06:57 PM
01/25/18 06:57 PM
myduster360
central IL
My battery (lt-wt Optima) is located far r/r of the trunk...as that's where the scales showed it to be best located. I tried it centered above the differential... scales showed it better far r/r. Overall, car handles great! Thats right where i'm figuring it should be, especially with the weight of the driver included. 52f/48r% is pretty decent.
[Re: MRGTX]
#2440883
01/26/18 05:44 AM
01/26/18 05:44 AM
Posts: 24 Northern Colorado
EagleDuster
Northern Colorado
Here's a great reference for weight reduction in A-bodies for common parts, no mention of F/R distribution change but it's pretty easy to get an idea which parts go on the front or back of the car... A-body Mopar Weight Reduction I haven't done much to reduce weight on my '70 Duster aside from an aluminum intake and gutting the factory A/C system from under the hood but I do plan to relocate the battery to the trunk; thinking of going with stock or slightly larger battery to maximize the offset effect. I also plan to replace the steel 15" Rallye wheels with something aluminum, probably no bigger than 17" for weight reasons (am I thinking right here? lol... tires will be 26" tall in front, 27" in back). I'm also thinking of ditching the factory power steering system and going with a manual box and electric P/S system out of a newer car; I've heard it's pretty straightforward and very cheap. I'll need the space anyway when I do my Gen 3 Hemi swap.
Khalid 1970 Plymouth Duster, 1993 Jeep Cherokee 4x4
