M1 vs. RPM #2439282
01/23/18 12:17 AM
01/23/18 12:17 AM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
I built a 512 for my Super Bee last year, and here are the basics:
.040 over 400 block.
Source 4.25" stroke bottom end with the lighter crank and upgraded rod bolts.
TF 240 heads, Scott Brown solid lift cam, Hughes 1.5 rockers.
10.6:1 compression.
I read a bit on intakes before I chose one, and then put out the word looking for an M1 or a Holley Street Dominator.
A friend thought he had a SD, and it ended up being a Performer RPM, so I picked that up. Then I found a screaming deal on an M1 single plane. I put the M1 on, but got to talking with Cab Burge and he says the RPM would be a better choice.
What do you all think? I am pretty sure the M1 gives me more hood clearance with the N-96 air box, but I know an RPM will fit, I had one on the previous 383 that was in it.
It's going in my '69 Bee, 4-speed, 3.54 Dana. Suspension will be switched over to either Assassin Bars or Cal-Tracs once I get it all back together.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: M1 vs. RPM [Re: OhioMopar] #2439308
01/23/18 12:40 AM
01/23/18 12:40 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Imo, the rpm will be much more responsive and street friendly with those 3.54 gears. You have them both so its easy to try them both. But I think for the street you will like the RPM best. It might even be the best choice for the track as well since you have a 4 speed and not a mild stall vert with a automatic.
Re: M1 vs. RPM [Re: OhioMopar] #2439324
01/23/18 01:19 AM
01/23/18 01:19 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
M1
ITS A 512 CI MOTOR
two inch spacer help out with a 850 carb
1.39 9.85 - 137 mph
Re: M1 vs. RPM [Re: OhioMopar] #2439352
01/23/18 01:59 AM
01/23/18 01:59 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I have ran the M1 on my 512 (400) for going on 4 yrs now. Throttle response is a non issue. It is great at low, mid and full.
Last yr I switched to a 4500 version of the M1, no loss of throttle response on the street but it is .12 faster in the 1/8. I hope to get to run some 1/4 mile times this yr.
With the 512 there is so much low end torque I dont think you will notice any let off by running a single plane.
Ok
Re: M1 vs. RPM [Re: OhioMopar] #2439374
01/23/18 02:56 AM
01/23/18 02:56 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
PHR did a B series intake shootout a few years ago that you’ll find if you google it. It suggests that those two make similar HP up top, but the RPM will offer a much broader torque curve and better power down low. With 3.54 gears and especially in a big street-heavy B-body, what you need is midrange torque. My sense is the RPM makes more of the meat your car needs. I run one on my 452” B motor. Last fall I added a short 1/2” open spacer and blended the top of the intakes carb-pad in an effort to open up more plenum volume to each cylinder. Although I didn’t do a back to back test, I noted that the car felt like it wanted more RPMs and made better top end power. It went faster but the air was good, so...??
Re: M1 vs. RPM [Re: StealthWedge67] #2439382
01/23/18 03:11 AM
01/23/18 03:11 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
On a 512 go with the M1. On my old 440 with 3.55's I had the same question . There was almost no difference at the the track or on the street between the two intakes.
The only Carbs I care about are under the hood!
Re: M1 vs. RPM [Re: Sport440] #2439383
01/23/18 03:12 AM
01/23/18 03:12 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Very true.
Re: M1 vs. RPM [Re: Ari440] #2439384
01/23/18 03:12 AM
01/23/18 03:12 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Originally Posted By Ari440
M1
ITS A 512 CI MOTOR
I guarantee neither will fit under my hood with a 2" spacer.
Re: M1 vs. RPM [Re: cudatom] #2439386
01/23/18 03:14 AM
01/23/18 03:14 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I was hoping someone had some real world experience with it. I was thinking the torque should be a non-issue, but I was concerned about the 3.54's.
Re: M1 vs. RPM [Re: StealthWedge67] #2439387
01/23/18 03:14 AM
01/23/18 03:14 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
What gear do you run?
Re: M1 vs. RPM [Re: Azzkikrcuda] #2439388
01/23/18 03:15 AM
01/23/18 03:15 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Thank you.
Re: M1 vs. RPM [Re: OhioMopar] #2439830
01/24/18 01:06 AM
01/24/18 01:06 AM
Puyallup, WA
Puyallup, WA
I run 4.10’s with a 28” tire. I’ve toyed with the idea of an M1; I’d be interested in your results if you were able to do a back to back test.
Re: M1 vs. RPM [Re: StealthWedge67] #2439834
01/24/18 01:10 AM
01/24/18 01:10 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I'll see what I can figure out. I'd like to switch them on the same trip to the track and see which one performs.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: M1 vs. RPM [Re: OhioMopar] #2439880
01/24/18 03:52 AM
01/24/18 03:52 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I run a small Comp Cams Mech, grind XS282S. Like Stealthwedge67 I also run 4.10 and 28" tires and my car is 4000lbs.
Going to try and get something closer to 29" tall tire. The convertor on my car is tight enough that when I drive on the street that when I left off the brake it moves w/little slippage. On the track when I mash it it flashed to 4500. That is a little higher than I wanted. Was wanting closer to 4-4200. I shift at 5500-5600. If I'm running 1/4 I cross the stripe at 6100. I wont return my convertor because its too conmsistent. But I will be trying one another one from PTC that is a tad tighter to see if I can even out the shift points and finish line rpms.
The edelbrock is a great intake, my brother runs it in his Cuda w/the same cam I do. Only difference is his is 446CU and I'm 512. Which ever you chose you will like. The 512 is a great set up.
Ok
Re: M1 vs. RPM [Re: cudatom] #2439888
01/24/18 05:42 AM
01/24/18 05:42 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I was planning on going with a 29-30" tall tire. I plan on driving it a lot, so I will be attempting to keep the revs down. 295-65/15 is my tire of choice, but it is only available in drag radials and the super expensive flame-tread Mickey Thompson tires.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: M1 vs. RPM [Re: OhioMopar] #2439965
01/24/18 12:49 PM
01/24/18 12:49 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Really don't see why a RPM would even be mentioned on a 512?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: M1 vs. RPM [Re: Von] #2440082
01/24/18 03:54 PM
01/24/18 03:54 PM
Von, the RPM is a great intake for the street up No matter what C.I on anything that has less than a all out solid roller cam with 440 size port heads shruggy scope
I've dyno tested multiple RB and B motors with a bunch of different intake, the RPM is the best over all for low RPM HP and torque, especially with light part throttle driving below 3500 RPM scope
I haven't done any same day at the track tests on BB 440 intakes in a long time so no valid feedback on that blush
Re: M1 vs. RPM [Re: OhioMopar] #2440124
01/24/18 04:50 PM
01/24/18 04:50 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Fathers Roadrunner:
Going from an RPM to M1 produced cleaner and more consistent plugs for all the cylinders on his pump gas, FT cam 440. With 3.23 gears and a 9” convertor it still kills the tires on the street.
He went to a Holley SD but swapped to a larger cam at the same time. It was a 12.0-12-teen car with the RPM and smaller cam. With the single plane and larger came it’s an 11.90-11.98 car @ 112-113 car.
91 octane
3900 pounds
My Coronet:
On my 505 with Eddy RPM heads, flat tappet, 93 octane I went from the INDY 2D dual plane to an M1 4150 ( STD port )
I’ve hit 11.05 ( peddling on top end ) and 11.06 and some other 11.0’s @ 120-121 ( Close to 122 once ) with 3.54 gear and the single plane.
Couple of the passes have been 6.99 and 6.98 in the 1/8 with the M1
11-teens and some 11.20’s with the exhaust still on and the M1 but 118 to high 119 mph
Does pull 24 MPH from the 1/8 to the ¼ on some of the passes.
While bracket racing, I noticed that peddling on the top end with the single plane does shave off et as much as peddling with the dual plane.
3840 pounds with head pipes and mufflers off.
3900 pounds with mufflers and head pipes on.
Sixty foot has been 1.54 best and as high as 1.58 with M1 and 3.54 gear
Flat steel hood.
FWIW
Mike
Re: M1 vs. RPM [Re: Cab_Burge] #2440216
01/24/18 08:35 PM
01/24/18 08:35 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I still venture that overall...a RPM is a choke on 500 plus inches, unless we are talking a super heavy/pulling type application.
Re: M1 vs. RPM [Re: OhioMopar] #2440217
01/24/18 08:39 PM
01/24/18 08:39 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Silver,
Exhaust is costing you a solid tenth, (maybe .15) , it looks like?
