Motorhome hitch upgrade needed? #2439430
01/23/18 08:34 AM
01/23/18 08:34 AM
gregsdart Offline OP
We just bought a 2015 Itasca 37f, Ford v10 f53 chassis rated at 28,000 gcwr. Trouble is, the coach came with a frame extension that is smaller than the original nine inch channel frame of the chassis. My trailer is a 28 ft Edge, about 10,000 loaded. Towing this trailer is limited to 115 miles to either t rack i race at, and we don't get out more than three or four times a year. Looking for input on what to do to make sure i don't damage this coach.
Re: Motorhome hitch upgrade needed? [Re: gregsdart] #2439450
01/23/18 10:45 AM
01/23/18 10:45 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Class a or c coach? Most gas coaches are only rated to tow 4000 lbs. Read the manual. Probably going to need a Trailer Toad for that kind of hitch weight. I know you will get people that say they have towed more no problem. The issue is stopping and as you said not damaging the coach.
Re: Motorhome hitch upgrade needed? [Re: gregsdart] #2439459
01/23/18 11:26 AM
01/23/18 11:26 AM
I am not worried about braking, i travel slow enough (under 60 mph) and won't be over the gcwr by much when loaded. So that brings it down to potential coach damage.
The coach is a 38 ft class A.
Re: Motorhome hitch upgrade needed? [Re: gregsdart] #2439463
01/23/18 11:44 AM
01/23/18 11:44 AM
Ohio
lockjaw-express Offline
Ohio
I have the same problem, towing is not the problem, but the tongue weight...I am in the process of buying a Trailer Toad. Jok owns the company.
I am getting the 5000SD unit, as I have a 600lb Diesel generator, 20 gal tank, bench, cabinets, tool box, and the tongue weight is about 3000lbs!
I have talked to lots of people at races, and the people that have motor homes, most have the Trailer Toad.
Mark
Re: Motorhome hitch upgrade needed? [Re: gregsdart] #2439474
01/23/18 11:59 AM
01/23/18 11:59 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
While the Trailer Toad will take care of the tongue weight you might still want to beef up the back of the frame to keep it from racking with side loads.
I think it would be easier to get everything setup correctly now than to repair damage later.
Re: Motorhome hitch upgrade needed? [Re: 340Cuda] #2439495
01/23/18 12:59 PM
01/23/18 12:59 PM
Definately will before i tow.!
Re: Motorhome hitch upgrade needed? [Re: gregsdart] #2439519
01/23/18 01:40 PM
01/23/18 01:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The problem with most any puller coach is built on a medium duty chassis and there is very little support at the rear for towing ANYTHING. They basically have enough material to support the body of the coach on. If it were me I would want to substantially reinforce the rear frame of the coach to tow a racecar trailer myself. There is a lot of overhang that is very lightly supported on the back of a class A puller. A trailer toad will help for sure, but even then I would want the rear frame area reinforced.
Re: Motorhome hitch upgrade needed? [Re: gregsdart] #2439522
01/23/18 01:44 PM
01/23/18 01:44 PM
PA
Scully Offline
Scully  Offline
PA
Re: Motorhome hitch upgrade needed? [Re: gregsdart] #2439555
01/23/18 02:40 PM
01/23/18 02:40 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
The problem is not the chassis in his case. Its the added length that screws up the towing. The F53 chassis is a good chassis to tow with if its not been added on to. You have stay under 32 feet to keep from this happening.
https://www.ford.com/commercial-trucks/stripped-chassis/models/f53-motorhome/
In his case, you will need to brace a ton or use a toad.
Re: Motorhome hitch upgrade needed? [Re: 66coronet] #2439686
01/23/18 07:12 PM
01/23/18 07:12 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
Mine is a class A. 2008 Four Winds Hurricane 33H. Ford F53 chassis, with the V10 engine, 33' in length. The F53 chassis's original frame ands about 3 feet short. You can see where the motorhome or chassis company added an extra 3' of frame. The additional frame is the same size as the rest of the frame. I will add a few pics of the bracing for the hitch.
http://drcraceproducts.com/motorhome.html They reinforced and installed my heavier duty hitch. Mine has a GCVR of 26,000 pounds. Motorhome weighs in a little under 16,000 pounds loaded and ready to tow without trailer. I have a 2004 Haulmark Edge 26' , that weighs a little under 10,000 pounds loaded and ready to tow. All together everything weighs a little under 26,000 pound on a certified tractor trailer scale. Front axle, rear axle and trailer axle weights are all within my limits. According to motorhome weigh sticker.
It tows and stops great. Fuel mileage sucks, 5.5 to 6.6 mpg loaded.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Motorhome hitch upgrade needed? [Re: Dartsport540] #2439688
01/23/18 07:15 PM
01/23/18 07:15 PM
Ringtown, Pa.
Ringtown, Pa.
Another pic of hitch. I don't have any pics of motorhome and trailer on my computer, and don't know how to get a pic from my phone onto here.
Took motorhome and trailer to Piedmont this last Thanksgiving for their Fall Footbrake Frenzy Race. Almost 1,000 miles round trip. Towed great...
Re: Motorhome hitch upgrade needed? [Re: gregsdart] #2439723
01/23/18 08:48 PM
01/23/18 08:48 PM
Washington State
lorenr Offline
lorenr  Offline
Washington State
You really need to be careful about loading any Class A with any load and particularly a heavy two axle, box trailer. I never realized how dangerous it could be. Gas engines never make the grade.
Load your motor home to normal gross weight with all your stuff. Run it across a set of truck scales. Read the motor homes Gross Vehicle Weight. It is normally on a tag and/or owners manual.
You'll be shocked that they can get away with it and soon realize why they blow tires. You'll also want to avoid them on the highway. Race cars are way safer.
Most of the heavy duty diesel pusher motor homes with 350- 400 horsepower can do it, but not all. Check the tags before you buy.
The early Monaco's, Beaver's and Country Coaches with 325HP or more can do it.
Loren
Re: Motorhome hitch upgrade needed? [Re: lorenr] #2439734
01/23/18 09:23 PM
01/23/18 09:23 PM
Ringtown, Pa.
Ringtown, Pa.
Found a pic from Jim Harrington Footbrake race at Cecil county last year..
I checked my trailer tongue weight with my car chassis scales, before I towed with it. When first checked , I had 1300 pounds tongue weight. I moved car back 3 or 4 inches and moved my spare trailer tire and motorhome spare tire, to the back of car trailer, under rear of racecar. Then I had 1110 pounds of trailer tongue weight.
Re: Motorhome hitch upgrade needed? [Re: gregsdart] #2439741
01/23/18 09:32 PM
01/23/18 09:32 PM
Thanks for the input, guys. I like what i see in the "ladder frame" adition that goes all the way to the axle and maybe beyond. I will feel good with that setup. As far as tongue wieght, i can vary that a lot to almost nothing by moving the car and things around, so that won't be an issue.
I will be traveling from Florida to Minnesota April 1st, so if there is a welding and hitch shop along the way, we could get it done enroute. Recomendations?
Re: Motorhome hitch upgrade needed? [Re: Dartsport540] #2439742
01/23/18 09:34 PM
01/23/18 09:34 PM
dogdays Offline
dogdays  Offline
The word "racking" was a good reminder that not all loads are forward and backward. Diagonal bracing is the appropriate way to increase stiffness in the lateral directions.
In other words, triangulate!
R.
Re: Motorhome hitch upgrade needed? [Re: gregsdart] #2439745
01/23/18 09:45 PM
01/23/18 09:45 PM
Ringtown, Pa.
Ringtown, Pa.
Call John at http://drcraceproducts.com/motorhome.html Not in your direct route of travel.
Re: Motorhome hitch upgrade needed? [Re: gregsdart] #2439765
01/23/18 10:29 PM
01/23/18 10:29 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Contact the manufacturer.... would be interesting to see what they say. They only two guys I know that towed with a C class, no longer do. Structure damage to the coach prompted a hasty trade in.
Re: Motorhome hitch upgrade needed? [Re: gregsdart] #2439785
01/23/18 11:11 PM
01/23/18 11:11 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
As stated above in the diagram, the rear portion of the frame is bolted to the plywood , maybe OSB floor. Are you going to trust a couple of bolts going through maybe 3/4" wood to keep your car and trailer attached?
Re: Motorhome hitch upgrade needed? [Re: gregsdart] #2439837
01/24/18 01:17 AM
01/24/18 01:17 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
With these big trailers, you don't need the old standard 10% tongue weight. That puts to much stress on the tow vehicle and hitch. I measure the height of the trucks rear bumper before I connect the trailer. Then load the car near the rear of the trailer so the truck bumper (1 ton dually) only drops 1 - 1.5". It tows beautifully​.
Re: Motorhome hitch upgrade needed? [Re: Hemi_Joel] #2439840
01/24/18 01:30 AM
01/24/18 01:30 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I bought the old style Trailer Toad about five years ago used and love it. It has the small tires on it and I had my first blowout last year. I found high ply tires for 80.00 a pair mounted on Rims So every three years I will buy a new set. Cheap insurance.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
