Fuel line and return size
#2438491
01/21/18 05:25 PM
01/21/18 05:25 PM
Posts: 4,450 Michigan
MarkZ
Worthy
Worthy
Hey guys, I upgraded to a stroked 512 last summer and now I'm looking to upgrade the fuel line with PTFE braided stainless. Factory lines are 5/16" supply with a 3/16" return. Motor is pretty docile with having untouched Eddie heads and a 239 @ .050" roller cam in it. Future plans include pulling the heads off for CNC porting and a 600HP FiTech - won't be going beyond that, so room for upgrades beyond this level would be unneeded.
I was thinking 3/8" supply and 1/4" return. Opinions? Thanks guys!
Re: Fuel line and return size
[Re: MarkZ]
#2438496
01/21/18 05:33 PM
01/21/18 05:33 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
When I build a return system I usually use the original supply as the return and upsize the new supply. So I'd got with the 3/8" supply and use the existing 5/16" as a return. You really can't go too big on the return, within reason in case some clown want's to mwntion 2" black pipe or some such silliness.
[Re: MarkZ]
#2438497
01/21/18 05:34 PM
01/21/18 05:34 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
I would absolutely not use 1/4" retuirn. If you use 3/8 feed use the same for the return. Absolutely would make the return at least 5/16.
I am building a 69 GTX with a 505 about 700 hp. I am running 8 AN (1/2") feed and return. Aeromotive tech support agreed with these sizes.
[Re: MarkZ]
#2438591
01/21/18 08:18 PM
01/21/18 08:18 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
If using a high flow,volume electric pump I would use a 3/8 supply,3/8 return, that is how my car is, 5/16 is ok for EFI, because it runs a much higher pressure, but for a carb,3/8 would be better for a return, mine is carb for now.
[Re: MarkZ]
#2438650
01/21/18 09:37 PM
01/21/18 09:37 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
I personally like the idea of using the stock 5/16" line as a fuel return. It's already there, well-routed & simple.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: MarkZ]
#2438736
01/21/18 11:11 PM
01/21/18 11:11 PM
MarkZ
Worthy
Worthy
I should have stated that I plan on using an in-tank pump like the Aeromotive 340 when I change over. I'm just not a fan of the under hood surge tank FiTech sells. It'll be a another season though before that happens. Just trying to get the lines in order this year.
Thanks for the input everyone. This forum has been invaluable to me over the years.
[Re: JRs_Charger]
#2441503
01/27/18 02:37 PM
01/27/18 02:37 PM
Posts: 4,753 Florida
BDW
I have the 600 HP FItech, and an in tank pump, and use 3/8th line for both feed and return. The large return line seems to help keep fuel temps lower.
The 5/16 and 1/4 lines are a no go. I have exact set-up, 600 HP Fitech with Spectra tank with in tank pump. Added 3/8" line for feed and used existing 5/16" for return. Works perfectly. Curious why you say it's "no go"? Nice thing about Fitech is you can adjust the voltage to the fuel pump , PWM, to lower the fuel pressure if needed.
