Stock torque converter for 727 big block? #2435448
01/16/18 03:44 AM
01/16/18 03:44 AM
3
340clone Offline OP
340clone  Offline OP
Looking to de-tune my '74 Charger with 440 a bit. First, monster cam had to go. Car had a 2500 stall converter, but looking to go back with a stock application. Motor is a '74 now back with stock HP cam. Not really looking for anything fancy, just want to make the car more street-able.
What and where to buy for a stock converter? Transstar, Autozone? Any suggestions welcome.
Thanks!
Re: Stock torque converter for 727 big block? [Re: 340clone] #2435716
01/16/18 04:11 PM
01/16/18 04:11 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Rebuilt stock 340 converter is the way to go. Works great in a combo like yours.
Leave the gun.......take the Cannoli's....Mike
Re: Stock torque converter for 727 big block? [Re: 340clone] #2435744
01/16/18 04:57 PM
01/16/18 04:57 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
166K MP if you find some ( PN P4876878AB )... I got one 175K used coupe of times after a fresh Chrysler remanufacture ( still on its box ) in barelly $75, but I THINK for a 400 with HP camshaft 166K is way enough.
the hard part is get one at this moment since they are discontinued now.
Re: Stock torque converter for 727 big block? [Re: 340clone] #2435775
01/16/18 05:37 PM
01/16/18 05:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Probably the best factory performance converter is the 2801764 introduced in '68, this is a 10 3/4" converter used on the /6, 318, 340, 383-4 and later 440.
This is often referred to as a 2500 converter but will stall as low as 1700 and as high as 2800 depending on the power input.
Re: Stock torque converter for 727 big block? [Re: 340clone] #2435797
01/16/18 06:00 PM
01/16/18 06:00 PM
A727Tflite Offline
A727Tflite  Offline
What does the stall test show for this converter in your car - today.
A good 440 with the production 10-3/4" converters will stall right around 2200-2800 depending on engine build and which converter.
If your converter today stalls at a real 2500 you'll gain little if anything by going to any of the suggested converters, they'll likely get you the same result you have.
If you are trying to kill low end slip then just install the production 440 11-3/4" converter - used on all the 440 engines - Sixbbl and 4 bbl.
Re: Stock torque converter for 727 big block? [Re: A727Tflite] #2435855
01/16/18 07:43 PM
01/16/18 07:43 PM
3
340clone Offline OP
340clone  Offline OP
I believe it is a 2500 stall converter, according to PO. It is made by SMR, and has TF3R written on it. I don't know enough about converters to really translate any of this info. smile
If this is something that I could continue to run, and not have it drive like a race car, and that I could still cruise in, I'd be great with that.
Any info on what I have would be great! Thanks!
Re: Stock torque converter for 727 big block? [Re: 340clone] #2435857
01/16/18 07:53 PM
01/16/18 07:53 PM
A727Tflite Offline
A727Tflite  Offline
340clone - I would check the stall speed with your current package. Engine fully warmed up, bury your foot on the brake pedal and raise the engine speed until the tires break loose. Shouldn't take more than 2 or 3 seconds to get to the max engine speed.
Do that once, run in neutral for 30 seconds place in drive and do it again. Average your two results and that should get you a fairly accurate stall speed. If by chance you have a manual shift auto place it in third and do the test.
For a few hundred RPM potential change sounds like you may be better off leaving things alone.
Starting with a new converter opens you up to all kinds of potential issues.
Re: Stock torque converter for 727 big block? [Re: 340clone] #2435858
01/16/18 07:53 PM
01/16/18 07:53 PM
A727Tflite Offline
A727Tflite  Offline
You have a known quantity with this converter.
The other thing many people don't understand is that STR differs between converters.
They all look alike from the outside.
Re: Stock torque converter for 727 big block? [Re: A727Tflite] #2436415
01/17/18 05:00 PM
01/17/18 05:00 PM
dogdays Offline
dogdays  Offline
I'm thinking it's a cast crank engine. That makes buying just any converter much more difficult.
R.
Re: Stock torque converter for 727 big block? [Re: 340clone] #2436462
01/17/18 06:09 PM
01/17/18 06:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The TF3R is what SMR calls their PRO SPORTSMAN 10 3/4" 'Race Tuff' TORQUE CONVERTER
http://smrtrans.tripod.com/smrtransmissionsintro/id37.html
It's for street applications, I'd keep it.
