1st time out with a trans brake , woh #2435126
01/15/18 06:43 PM
01/15/18 06:43 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
well finally got everything together on Saturday . First t&t for the year only full day one before championship starts in feb .
I must say it is different than the last 12 or so years of footbraking .
Tree was run on pro tree so that didn't help .
Weather was terrible , 91-101F 3500-4100DA and blowing a gale almost direct headwind .
Leaving at 3300 only car got within 0.005 of best ever sixty, went 1.480 , and ran et similar to what it ran at 2900-3000DA with no head wind .Best 10.718@14.19 3700DA , I think wind eased otherwise ran 123mph's
So that appears a good improvement , will be good to see how it goes with a bit cooler and no wind .
BUT
darn does the motor zing up with the new 8" converter . Certainly hits the shift light faster/earlier . Completely different to my old trans/vert , so I will need to make a fast adjustment .
Not sure whether I may raise the shift a little as am only shifting at 6000
May also move button from shifter area ? but think I will try a street meet to double check
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 1st time out with a trans brake , woh [Re: tex013] #2435133
01/15/18 06:53 PM
01/15/18 06:53 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
First 2 passes i was all over the shop , third pass turbed the tyre .
I use MT 28x10.5r15 pro bracket radial
Tex
New best MPH 130.32
Re: 1st time out with a trans brake , woh [Re: tex013] #2435162
01/15/18 07:37 PM
01/15/18 07:37 PM
Renton Washington
Triple Threat Offline
Renton Washington
Sounds like you've made some steps in the right direction. Good luck with your season!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 1st time out with a trans brake , woh [Re: tex013] #2435168
01/15/18 07:44 PM
01/15/18 07:44 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Did you footbrake on any of the runs?
A lot racers say et same brake vs footbrake, but reaction time better.lots of adjustable buttons to dial in RT
Re: 1st time out with a trans brake , woh [Re: tex013] #2435176
01/15/18 08:01 PM
01/15/18 08:01 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Dude! I'd say you're pretty much getting nearly the best of it for that mph! The heat and adjusted altitude is killing it. Did you have fun letting go of the button? How many times did you practice holding it on the chip before you went to the line the first time? grin Did you get a chance to try a different launch rpm? Staging is super important for lowering 60's. A guy on here running no electronics bumps their cars in with the trans. brake button and they are pretty darn successful at it.
Re: 1st time out with a trans brake , woh [Re: Dave Hall] #2435180
01/15/18 08:09 PM
01/15/18 08:09 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
to me, using the transbrake for the first time felt like getting a swift kick in the shorts, love it and swore off footbraking for ever.
Re: 1st time out with a trans brake , woh [Re: tex013] #2435200
01/15/18 08:56 PM
01/15/18 08:56 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
no footbrake passes , got to get my act together . No adjustable buttons allowed in my class . Just using a Dedenbear .
Never tried it on the chip before the first pass . Tried 3100 then stayed with 3300 launch . Too much to get used to .Just shallow staged like footbraking .
Yes it felt like someone rear ended me .
Dustin , thanks , I want to do my best to replicate last season .
Car still launches square
Tex
New best MPH 130.32
Re: 1st time out with a trans brake , woh [Re: tex013] #2435221
01/15/18 09:21 PM
01/15/18 09:21 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
From the pic the car could use a little less separation in the rear. Tighten up the extension on the shock.
Re: 1st time out with a trans brake , woh [Re: tex013] #2435259
01/15/18 10:28 PM
01/15/18 10:28 PM
crabman173
crabman173
Isn't the same force that is pushing the body up also planting the rear?
That baby looks good
Re: 1st time out with a trans brake , woh [Re: Dave Hall] #2435316
01/15/18 11:41 PM
01/15/18 11:41 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Dave , it is a radial tyre car . I have left same shock settings as footbrake
if there was more testing I would certainly try tighter
Tex
New best MPH 130.32
Re: 1st time out with a trans brake , woh [Re: tex013] #2435318
01/15/18 11:46 PM
01/15/18 11:46 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Hey don't you know street cars don't use trans brakes ?? grin Sounds like it going to work good for you and the car looks great in that pic. up Ron
Re: 1st time out with a trans brake , woh [Re: tex013] #2435389
01/16/18 01:36 AM
01/16/18 01:36 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I've always been afraid to use one w/the 8 3/4 but heard some pick up very well so lookin forward to your results after some tweaking....... thumbs
Re: 1st time out with a trans brake , woh [Re: 383man] #2435391
01/16/18 01:41 AM
01/16/18 01:41 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
That's what I have been told Ron shruggy
I have driven American based or American cars as dailies since I was 18 why stop now .
Tex
New best MPH 130.32
Re: 1st time out with a trans brake , woh [Re: Thumperdart] #2435395
01/16/18 01:44 AM
01/16/18 01:44 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Thump ,
I lost my 8 3/4 quite few years ago , love my S60 no more worries .
Hopefully a little more seat time , better weather and experimentation will help reach my goal . 1.45 sixty would be good
Tex
New best MPH 130.32
Re: 1st time out with a trans brake , woh [Re: tex013] #2435447
01/16/18 03:42 AM
01/16/18 03:42 AM
Cab_Burge Online work
Cab_Burge  Online Work
Turn the stall RPM up to 4200 RPM and see what effect that has on the 60 ft. times scope If it stick then try 4400 RPM devil If it spins at 4200 try 4000 RPM thumbs
Sometimes getting rid of the flash stall helps our old Mopars 60 ft. better, depending on the chassis shruggy
Re: 1st time out with a trans brake , woh [Re: Cab_Burge] #2435470
01/16/18 05:47 AM
01/16/18 05:47 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Will do Cab . Will creep up on it
Tex
New best MPH 130.32
Re: 1st time out with a trans brake , woh [Re: tex013] #2436112
01/17/18 02:12 AM
01/17/18 02:12 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What is your 60 now ? I forgot but do you run Cal Tracs ? Ron
Re: 1st time out with a trans brake , woh [Re: 383man] #2436146
01/17/18 03:55 AM
01/17/18 03:55 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Ron
yes caltracs .
Best previous sixty 1.47s
Tex
New best MPH 130.32
Re: 1st time out with a trans brake , woh [Re: tex013] #2436149
01/17/18 04:02 AM
01/17/18 04:02 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I wanna see your car leave like this one come this fall.
Re: 1st time out with a trans brake , woh [Re: Dave Hall] #2436166
01/17/18 06:27 AM
01/17/18 06:27 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Dave,
I have that car on a magazine cover at work . A favourite .
Doing that may be a bit beyond me eek
Tex
New best MPH 130.32
