ALTERNATOR WIRING 101..................... #2431241
01/08/18 08:40 PM
01/08/18 08:40 PM
State of confusion
Thumperdart Offline OP
State of confusion
So my alt. is done after 10 years of abuse and a friend is going to warranty it out and step it up to a newer 90 amp Denso so what's the best way to wire it in. Currently it goes through the column like factory.........Thankxxx................. thumbs
Re: ALTERNATOR WIRING 101..................... [Re: Thumperdart] #2431249
01/08/18 08:51 PM
01/08/18 08:51 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: ALTERNATOR WIRING 101..................... [Re: Thumperdart] #2431257
01/08/18 08:57 PM
01/08/18 08:57 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Dim if you haven’t allready done it yet. I would bypass the Alt wire wear it goes through the bulk head connector and bypass the factory amp guage
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: ALTERNATOR WIRING 101..................... [Re: Thumperdart] #2431258
01/08/18 08:58 PM
01/08/18 08:58 PM
mopar65 Offline
mopar65  Offline
That was supposed to be Dom. Stupid phone. Lol
Re: ALTERNATOR WIRING 101..................... [Re: Thumperdart] #2431260
01/08/18 08:58 PM
01/08/18 08:58 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
doesn't Andy's brackets have wiring instructions.
run the alt output to the post on the starter relay and then to the battery.
run a reference 12v source to the alt plug and maybe a switched 12v wire too...
it's pretty simple, wired this way the ammeter won't be accurate. so maybe run an aftermarket voltmeter in the car...
Re: ALTERNATOR WIRING 101..................... [Re: mopar65] #2431263
01/08/18 09:06 PM
01/08/18 09:06 PM
State of confusion
State of confusion
Did that years ago............Thankxxx guys and I do have a volt meter but me and a drunk friend wired some of this stuff 15 years ago and w/the key in the run position it charges but when I click it back a notch, no charging so part of it goes through the ign.......... thumbs
Re: ALTERNATOR WIRING 101..................... [Re: Thumperdart] #2431273
01/08/18 09:26 PM
01/08/18 09:26 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I would run a 6 gauge or 8 gauge wire from the alternator back to the battery in the trunk and fuse it with a 50 amp fuse in case of a short. Get the wire and terminals from a local car audio shop.
Re: ALTERNATOR WIRING 101..................... [Re: nss guy] #2431287
01/08/18 09:57 PM
01/08/18 09:57 PM
State of confusion
State of confusion
I actually run a big regular batt cable to a bulkhead on the firewall that goes straight to to the batteries.........The fuse or relay was recommended so I will also do that............ thumbs Do I need a bulb/light like stock cos it's been w/out since day one......
Re: ALTERNATOR WIRING 101..................... [Re: Thumperdart] #2431311
01/08/18 10:27 PM
01/08/18 10:27 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Iv had a 1 wire denso a long time now. Just 1 10 gage wire to battery. I beleive when the alt spins it turns on. Easy peezy.
Re: ALTERNATOR WIRING 101..................... [Re: Thumperdart] #2431337
01/08/18 11:10 PM
01/08/18 11:10 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
None of the actual charging amps goes through the ignition switch. The ignition switch does send positive voltage to the alt or regulator, Depending on the Alt setup. Stock, the + went to the Regulator from the Ign switch.
Do you have the 4 wire Denso as shown in the above diagram? If so it does need a light or small resister to energize the alt. But, you say your light has never worked. I say move up to a one wire as suggested.
Your big Positive output wire to a bulk head, non factory on the fire wall is fine. But, it does make it tougher to get your motor to lose + volts with the trunk mounted kill switch. Is that operational now, as wired previously? If not, time to address that as well.
But, Whats wrong with your ignition switch. You can turn it back a notch and lose charge voltage. Most switches are {Acc/Off/Run/Start}. So you have {Acc/no,charge/Run/Start}. That doesn't make any sense to me, maybe just a Wore out ign switch that you can rotate back in between {Run/Off}, killing power to the alt or reg. But I think Denso,s have there own built in reg.
Re: ALTERNATOR WIRING 101..................... [Re: Sport440] #2431463
01/09/18 03:23 AM
01/09/18 03:23 AM
State of confusion
State of confusion
Good stuff thankxx, the ign. click back and loose alt voltage was 15+ years ago and hasn't affected the charging any and the alt is around 9 years old iirc. I raced the car a couple weeks ago and it was normal, fire it up yesterday and 15.1-15.2 at the batteries so some things like us, just die w/out notice and I've gotten my $'s worth out of it on a car it was never intended for. I'll see how the 90 amp Denso works out since a buddy will warranty mine out and give me a new not rebuilt piece.........Thankxx guys, always an education............. beer thumbs
Re: ALTERNATOR WIRING 101..................... [Re: Thumperdart] #2431510
01/09/18 10:14 AM
01/09/18 10:14 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Re: ALTERNATOR WIRING 101..................... [Re: RATTRAP] #2431605
01/09/18 02:18 PM
01/09/18 02:18 PM
State of confusion
State of confusion
Good stuff and read through that years ago........... thumbs
Re: ALTERNATOR WIRING 101..................... [Re: Sport440] #2433993
01/13/18 05:50 PM
01/13/18 05:50 PM
State of confusion
State of confusion
Well after days of thinking and a basic understanding of how an alt. works, I decided to check some grounds and other connections as suggested from you guys and sure enuff the ground post nut was loose. Not a lot but obviously enuff to make the alt. send more current due to the resistance but I still have the issue where the afr gauge still goes crazy till I turn on the headlights so I will check the headlight connection and ground and go from there I guess unless anyone has another idea..........Much thankxxx guys............. beer
Re: ALTERNATOR WIRING 101..................... [Re: Thumperdart] #2434029
01/13/18 07:04 PM
01/13/18 07:04 PM
CA
crackedback Offline
crackedback  Offline
CA
Dom
Check the voltage where you are pulling power for the AF meter.
Madeletric has some good stuff, I don't agree with suggestions of cutting up wiring harnesses to make improvements. Cutting anything really isn't necessary.
Sounds as though you are still having an overcharge issue.
Cable size running from alternator to battery?
How are you sourcing power for cabin/ignition?
Re: ALTERNATOR WIRING 101..................... [Re: crackedback] #2434032
01/13/18 07:22 PM
01/13/18 07:22 PM
State of confusion
State of confusion
Originally Posted By crackedback
Dom
I need to do that as you and a few suggested and it's not overcharging anymore and in fact, is charging less now that the main grounds and power posts are tight. The alt. power cable is actually a battery cable so is it possible it's TOO big and maybe only need a #8? I just drove it and w/out lights the idle, cruise and wfo #'s dance, lights on, rock solid so I will isolate the WB system away from other sources and try again...........Thankxxx............. beer
Re: ALTERNATOR WIRING 101..................... [Re: Thumperdart] #2434040
01/13/18 07:40 PM
01/13/18 07:40 PM
CA
crackedback Offline
crackedback  Offline
CA
Nope on too big... too small is always the issue.
If you have a large cable, as in a 4 gauge or larger running from alt to battery, I'd leave it.
Re: ALTERNATOR WIRING 101..................... [Re: Thumperdart] #2434041
01/13/18 07:41 PM
01/13/18 07:41 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Dom what is the voltage before and after the lights are turned on? Have you checked all the grounds on the lights?
Re: ALTERNATOR WIRING 101..................... [Re: Thumperdart] #2434065
01/13/18 08:21 PM
01/13/18 08:21 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
are you checking all the wring by doing a "voltage drop test"? I would check between the alternator case and the battery.
Joe
Without Data, you’re just another guy with an opinion.
Re: ALTERNATOR WIRING 101..................... [Re: justinp61] #2434104
01/13/18 09:10 PM
01/13/18 09:10 PM
State of confusion
State of confusion
Voltage is now a solid 14.1-14.2 at idle w/headlights on but as I add water pump and the HHR fan, idle voltage drops to battery voltage and didn't rev it up to check since I was alone testing at the batteries. I wired in relays and halogens years ago so even at 12 volts, they are nice n bright. I will run the afr gauge wires away from the common bus bar and try the starter relay or ? and see how that goes and may just step up to the 90 amp and be done with it........... thumbs
