Re: Anyone running MT Bias Ply Drag Tires with Rallye Wheels?
[Re: ScottSmith_Harms]
#2433816
01/13/18 11:30 AM
01/13/18 11:30 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Ton's of people run them tubeless but being a four speed the extra stiffness probably isn't a bad idea. If you do run tubes I would be inclinded to glue or screw the tires to the rims, any movement with a tube can cause issues with the valve stem. I would try no tubes first.
68 Barracuda Formula S 340
[Re: nss guy]
#2433821
01/13/18 11:37 AM
01/13/18 11:37 AM
Bad340fish
Tulsa OK
I have m/t slicks on stock rims, you will need to drill out valve stem. With a 4 sp run a stiff sidewall slick and skip the tubes. M/T are notoriously for leaking air thru sidewalks, so prep them to prevent air leakage. Usually dawn soap on the inside. He is right about that, I had a pair that you could drive to the track, race, drive to dinner, and drive home on just fine. But as soon as you closed the garage door and hit the light switch it seemed they went flat.
#2433875
01/13/18 01:36 PM
01/13/18 01:36 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Originally Posted By nss guy I have m/t slicks on stock rims, you will need to drill out valve stem. With a 4 sp run a stiff sidewall slick and skip the tubes. M/T are notoriously for leaking air thru sidewalks, so prep them to prevent air leakage. Usually dawn soap on the inside.
He is right about that, I had a pair that you could drive to the track, race, drive to dinner, and drive home on just fine. But as soon as you closed the garage door and hit the light switch it seemed they went flat. _________________________
Ok, but if I skip the tubes why would I need to drill out the VS hole with a 4 step? Stock VS should work without tubes right? In any event, I just want them to be safe, car is mostly street driven.
#2435535
01/16/18 11:55 AM
01/16/18 11:55 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Unless you're gonna use rim screws to hold the tire to the rim, don't use tubes.
[Re: an8sec70cuda]
#2437958
01/20/18 02:46 PM
01/20/18 02:46 PM
Posts: 9,862 MI, usa
dvw
MI, usa
Unless you're gonna use rim screws to hold the tire to the rim, don't use tubes. I'm going to test tubes w/o rim screws. I marked my last pair of slicks. They moved only 1/2",(and that was right away). They were glued with purple Permatex. Car has been 1.240 60ft Doug
