Leaky transfer case #2432333
01/10/18 06:02 PM
01/10/18 06:02 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
The transfer case does appear to be wet on my recently purchased 1979 Power Wagon. I've had several Dodge trucks, but this is my first 4WD. I see there are gasket kits for transfer cases, but I'm so unfamiliar with them, I don't know if the TC has to come out of the truck to completely re-seal one. Also, I'm wondering if removing front driveshaft for time being would help to stop some of the fluid loss until I solve this. I've taken care of engine and trans leaks, so I am ready to move on to TC.
Thank you.
Larry
Facts are stubborn things.
Re: Leaky transfer case [Re: larrymopar360] #2432348
01/10/18 06:25 PM
01/10/18 06:25 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Still at it ey? if I recall, that case if still stock, still uses like 30 weight reg eng oil? If you remove front shaft, you'll have to run around with case in "loc". I'm gonna end up with one of them old full timers again, I just know it, and would be a drag if parts-gaskets etc would not be avail from places like Transtar etc.
Re: Leaky transfer case [Re: buildanother] #2432732
01/11/18 10:20 AM
01/11/18 10:20 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Where is it wet? Is it a leak or just appear wet. If the truck has been sitting the seal may be dry and might seal better if some miles are put on. If it is between the trans and T/case it maybe a rear trans seal not the t/case. Just some idea's to look at.
Re: Leaky transfer case [Re: larrymopar360] #2432768
01/11/18 12:55 PM
01/11/18 12:55 PM
scratchnfotraction Offline
there is a U-shape gasket where the xfer bolts to trans adaptor with 7 bolts. most just use silly cone at this spot when the case is removed..I did with no leaks.
yes there is a trans tail shaft seal that keeps fluid in the trans and a housing/seal on the xfer wher the trans output shaft goes...so 2 seals and 1 gasket at the trans/xfer mating.
if you look at the back of the xfer, behind the front shaft, that round cover plate can have the lowest bolt removed to drain the last little bit of fluid from the xfer when changing fluid. it has a fill and drain but leaves about a pint of oil. seems I used to run a 80w90 gear oil in my full time 203.
there is a gasket there on cover plate and on the xfer differential housing along with the rear output shaft.
yes I sad xfer differential.. it lets the front and rear output shafts turn at different speeds, this is the hi&lo function. it will let the rear tires spin with out spinning the front tires or vise-versa. when in HI LOC and LO LOC it locks the front rear drive shafts together so both axle are locked together with the same input speed for more traction...this is why it will drive off a set of jackstands with 1 axle up in the air.
at one time mile marker had a adjusta chain kit and a part time kit for the 203.
I had both which save the case with a worn chain, just adjust the slack up with the front output cover off.
the part time kit went in the xfer differential hosing to replace the spider gear set in there to get a part time function.
I would recommend them kits if you find them. tuff and longevity and well worth the $$.
speedo cable adaptor can leak as it is on the xfer.
best bang for the buck is to buy a hand pail pump and buy gear oil by the 5 gal bucket.
you service the front axle, xfer, rear axle together. I did a lot of swamp water so changed every outing when they turn milky.
Larry FYI I have a LOC-Right locker that replaces the spider gears in the rear 9 1/4 axle for a locking rear axle. this is one of the best things for a 4x4 is a locker rear axle. installs with hand tools and no need to R&R the differential guts. it is in a 3.55 gear 9 1/4 now if you are interested in it.
one thing I had a problem with was my xfer shifter mounting bracket worked loose every so often. made it had to shift from hi/lo
yep you can drive it in HI loc or lo loc with 1 drive shaft front or rear.
I ran around with just the front a while and only had to watch the torque steer using only the front not bad but had to correct under power and off the power slightly.
Re: Leaky transfer case [Re: larrymopar360] #2432832
01/11/18 03:23 PM
01/11/18 03:23 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Mike, thank you for the wealth of information! Very helpful. I like the idea of converting and willing to spend the money for something worthwhile. I'm going to PM you about the 9.25 axle.
I've sealed up the engine and trans nicely and have the truck running great, so I have put some miles on it to identify leaks. I'm cleaning years of [censored] off the transfer case and new wetness is appearing, but still hard to pinpoint exactly where it's coming from. I'm going to have to pressure wash I guess. I've been using a scraper to remove what was coming off engine when it was leaking out a rear freeze plug, oil and trans fluid so that every bit of dirt stuck. There was almost an inch of dirt stuck to transfer case, and in every little nook and cranny. Yep, FSM states 10W-30 engine oil for transfer case.
Re: Leaky transfer case [Re: scratchnfotraction] #2433239
01/12/18 05:20 AM
01/12/18 05:20 AM
GA, USA
U
ulrich Offline
ulrich  Offline
U
GA, USA
That sounds a great solution.
Re: Leaky transfer case [Re: larrymopar360] #2433305
01/12/18 11:56 AM
01/12/18 11:56 AM
get some brake clean and rags,scraper and get it clean.
throw some baby powder around the output seals or where you think it may have a leak. this will slow the leak before windage moves it every where.
most times the wet washed area is clean and oily with gunk built up around the area.
IIRC you can remove the yokes and change the output shaft seals and IIRC you can remove the front output shaft seal housing and replace the gasket. the flat cover for front output has a gasket also.
I will have a look at the old Chilton books I have and see how much is involved on the rear xfer output housing gaskets seals.
cant be 2 hard as I installed the ajustachain kit and the part time kit 1x but never have seen anyone with it or another kit for sale in 30 yrs
been a while since I serviced a good ol 4x4 full time but miss doing it.
IIRC I found some 2 lip seals I used on the front trans pump that kept water out as well as fluid in the trans. I think I used 2 lip seals on the output shafts or axles maybe..? maybe not. I do remember learning about the one for the trans.
I was doing a lot of deep water swamping with 17/40/15 ground hawgs and 6" lift in a 79 RC, man I miss the mud some days but had enough of it now days. cant jump up in a 4x4 now so I be a lowered & tub street freak now.
Re: Leaky transfer case [Re: larrymopar360] #2433307
01/12/18 11:58 AM
01/12/18 11:58 AM
LARRY..do you know what gear ratio the axles have? cant mix them as they need to match.
most common are the 3.21 3.23 3.55 some time you find a 1/2 ton with a 3.91 some one ordered when new.
find it stamped on the ring gear with the date.
Re: Leaky transfer case [Re: larrymopar360] #2433431
01/12/18 03:26 PM
01/12/18 03:26 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Got under it last night at midnight after work. Had so little time lately but itching to work on it. I see a tag on the rear but tough to read. Need to clean it up. That pumpkin is seeping a bit so I've been planning on popping the cap and cleaning it out and filling it with clean gear oil anyhow, along with front, and hopefully can read tag.
Also, it looks like I have 8.25's. Does that sound right? It's a 150 but 1/2 ton 1979. Also, I did check speedo adapter and it's dry. It connects into a block, that connects into the transfer case. The black had a small crack, but it's dry.
Re: Leaky transfer case [Re: larrymopar360] #2433472
01/12/18 04:17 PM
01/12/18 04:17 PM
chicagoland,usa
chicagoland,usa
They may have called the 10 bolt rear 8 3/8". It could be that or a 9 1/4" 12 bolt rear. 321 gears were really common on 79's but could be 355's.
Re: Leaky transfer case [Re: larrymopar360] #2433602
01/12/18 09:26 PM
01/12/18 09:26 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I count the bolts tonight. It does not look like a 9 1/4 to me but again, haven't had much underneath time. Thank you.
Re: Leaky transfer case [Re: larrymopar360] #2433632
01/12/18 10:24 PM
01/12/18 10:24 PM
chicagoland,usa
chicagoland,usa
My 79 warlock II with part-time kit installed, had the 8 3/8 until I punished it too much, kindof started the ring gear teeth a leaning over, then I installed a 9 1/4.
Re: Leaky transfer case [Re: larrymopar360] #2433644
01/12/18 10:54 PM
01/12/18 10:54 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
What kind of money am I looking at to do part-time kit (ballpark number)? Is it really necessary if I'm not going to be punishing it, as in a lot of off-roading or beating on it on the road? I just would like to have leak free.
Thank you.
Larry
Re: Leaky transfer case [Re: larrymopar360] #2433919
01/13/18 02:57 PM
01/13/18 02:57 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
It's 10 bolt, and I have a picture on my phone. Try and put it on here soon. Not very tech savvy so it takes me a bit to post pics.
Re: Leaky transfer case [Re: larrymopar360] #2433937
01/13/18 03:40 PM
01/13/18 03:40 PM
Alberta
440_Offroader Offline
Alberta
My 79 Macho has the 8 3/8" rear. It has a 360, and 3.21 gears. Seems weird that a 4x4 has the smaller differential with such high gears, but that's how it came from factory. I think Randy's Ring & Pinion Web site has picture references to what would be in your truck.
You're on the right track, clean the T-case as good as you can, and keep an eye on it. The leak point(s) will show up.
Re: Leaky transfer case [Re: larrymopar360] #2433955
01/13/18 04:19 PM
01/13/18 04:19 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Thanks 440 Offroader. I'll check Randy's site. Just by sight, I think this looks a bit different than the 8.25 in my Diplomat Police car, so I'm guessing 8 3/8". I have the Diplomat tucked away in my Dad's garage right now, so I don't have the cars side by side to look at though. And in the driving I've done, feels like it could be 3.21 gears.
Thanks again,
Larry.
Re: Leaky transfer case [Re: larrymopar360] #2434229
01/14/18 02:00 AM
01/14/18 02:00 AM
Alberta
Alberta
Sorry Larry, I looked on Randy's site and I guess my truck would have a 8.25" rear end, according to them. My owners manual states 8 3/8 as well as service manuals. My 1975 service manual has 8 1/4. Not sure if the 8 1/4 and the 8 3/8 rear are two different units? I have seen the reference to both... but I'm thinking they're basically the same.
Re: Leaky transfer case [Re: larrymopar360] #2434429
01/14/18 02:47 PM
01/14/18 02:47 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
No problem. It seems odd they would build an 8 1/4 and an 8 3/8 being so close in size, but I guess stranger things have happened. I just as soon have it be an 8 1/4. I have had several with high HP engines and they have held up very well, and I have some spare NOS parts. So is the axle housing or cover stamped somewhere, inside or out? I'm going to be popping cap off soon to clean and put fresh fluid.
Thanks,
Larry
Re: Leaky transfer case [Re: larrymopar360] #2435523
01/16/18 11:30 AM
01/16/18 11:30 AM
IIRC a 8 3/8 is the same as a 8 1/4 just called 2 different names. I call it a 10 bolt. 9 1/4 a 12 bolt. next up is the 12 bolt cover on a D60 very similar to a 9 1/4 cover at first glance.
I would have a look at the ring gear for yr/ratio to see if it has been replaced. a lot could have been worked on since 79.
I have replaced a lot of rear axles as a whole going with what I could find. a 10 bolt is always easy and cheaper to find but now days they are getting hard to locate. a 9 1/4 is hard to find that in good condition or it has/need a rebuild they tend to hold up if the crush sleeve is replaced with a solid spacer.
72-74 RC-4x4 truck would have a 8 3/4 as well. I have one from a 72 w100 with 489-3.91sg (cone) FYI-same hosing/axles as a C-body car.
I have relocated a couple 9 1/4 axles from 73-74 newports to trucks with a perch move same width flange to flange as truck chassis.
so when looking for a mopar rear axle I look at ALL of them.
just installed a 67 polara 8 3/4 in my stepside to tuck 10 rims and have the A-body 8 3/4 in the 88-440 truck tucking 12" rims.
Re: Leaky transfer case [Re: larrymopar360] #2435767
01/16/18 05:30 PM
01/16/18 05:30 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I believe my 10 bolt will hold up with what I have planned (no towing or beating on it).
What I am most concerned with is having the Transfer Case reliable and sealed up. Last night I discovered I'm still losing transmission fluid. I know it's not from shaft seal, and shouldn't be pan gasket, both have been replaced. I'm beginning to think I'm going to have to drop the transmission.
