Re: Real world weight loss program and it` cost..........
[Re: fullmetaljacket]
#2438056
01/20/18 06:37 PM
01/20/18 06:37 PM
Posts: 4,804 Wichita
GY3
Wichita
Rears with special hubcaps on. Some local Mopar guys were even saying to me: Yo, why do you run those heavy @$$ wheels instead of getting your self a pair of lightweight aluminum wheels? LOL. The other brands of cars never even cared. Any pics of just the cap part? I need to do something like this for my car my wheels weigh way too much!
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
#2438076
01/20/18 07:30 PM
01/20/18 07:30 PM
fullmetaljacket
The rear back side to the hubcap. As one can see in this picture, the outer edges have a slight inturn to them to sit right and over the rivets on the centerline wheels.
#2438078
01/20/18 07:33 PM
01/20/18 07:33 PM
fullmetaljacket
[Re: Thumperdart]
#2438209
01/21/18 12:31 AM
01/21/18 12:31 AM
Posts: 12,593 Great Neck,LI,new york
hemi-itis
Lee,why are the tires rubbing the outer sidewall on the right side?
[Re: Thumperdart]
#2438513
01/21/18 06:06 PM
01/21/18 06:06 PM
hemi-itis
When I broke a perch,I had the rear centered and installed sliders.My street tires do rub-the-tub on the inside on sharp turns or uneven surfaces. Will be gutting the steering column soon and expect to lose some weight there.Also want to add a removable steering wheel,it's getting hard for the old guy to climb over that door bar Was 3700lbs,now 3500 lbs and falling
[Re: hemi-itis]
#2438595
01/21/18 08:24 PM
01/21/18 08:24 PM
Posts: 9,973 MI, usa
dvw
MI, usa
Will be gutting the steering column soon and expect to lose some weight there. Also want to add a removable steering wheel
Make that steering shaft out of .090"x .750" moly tube. Doug
[Re: dvw]
#2438604
01/21/18 08:34 PM
01/21/18 08:34 PM
hemi-itis
Make that steering shaft out of .090"x .750" moly tube. Doug You have instructed me on that.I need to figure out how to maintain the directional switch.I don't care about the oem look,kinda past that. I will also add that the car can go to it's legal limit of 8.50 as is,but have wanted to redo the column for 10 years!! Added:BTW Doug,is that the same OD as the stock shaft?
[Re: hemi-itis]
#2439007
01/22/18 02:48 PM
01/22/18 02:48 PM
dvw
MI, usa
Make that steering shaft out of .090"x .750" moly tube. Doug You have instructed me on that.I need to figure out how to maintain the directional switch.I don't care about the oem look,kinda past that. I will also add that the car can go to it's legal limit of 8.50 as is,but have wanted to redo the column for 10 years!! Added:BTW Doug,is that the same OD as the stock shaft? Yes, same diameter. You can always use a toggle switch for the turn signals. You would have to shut it off after a turn, big deal. Doug
[Re: Thumperdart]
#2439021
01/22/18 03:10 PM
01/22/18 03:10 PM
hemi-itis
LMOL,,my cancel hasn't worked in 10 years
