Time for a new oxy sensor............... #2430570
01/07/18 04:29 PM
01/07/18 04:29 PM
State of confusion
Thumperdart Offline OP
State of confusion
Anyone have a part # for the Bosch that is proper for the Innovate LM-1 by chance.......... beer thumbs
Re: Time for a new oxy sensor............... [Re: Thumperdart] #2430578
01/07/18 04:38 PM
01/07/18 04:38 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
mine is a LM-2 which my understanding is that the only difference is your's is a 1 channel and mine is a 2 channel so this is the number's I found in my instruction manual,,Innovate number is 3737 and the other option is a volkswagen part number 021-906-262-B
Re: Time for a new oxy sensor............... [Re: dartman366] #2430581
01/07/18 04:42 PM
01/07/18 04:42 PM
State of confusion
State of confusion
Want something I can buy locally if possible............
Re: Time for a new oxy sensor............... [Re: Thumperdart] #2430584
01/07/18 04:46 PM
01/07/18 04:46 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
you may be able to take the VW number and hav a competent auto parts store cross reference it, probably be a lot less expensive than a VW dealer, make sure you take the old one with you.
Re: Time for a new oxy sensor............... [Re: Thumperdart] #2430586
01/07/18 04:50 PM
01/07/18 04:50 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Is there such a thing as a competent Auto Parts store these days smile
Re: Time for a new oxy sensor............... [Re: Al_Alguire] #2430590
01/07/18 04:59 PM
01/07/18 04:59 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
there are still a few around, but around here it's usually the ones that have the old guy's running them that have been around for decades, like the Farmers insurance add,, 'we know a few things because we have seen a few things" LOL
Re: Time for a new oxy sensor............... [Re: dartman366] #2430594
01/07/18 05:10 PM
01/07/18 05:10 PM
State of confusion
State of confusion
I called Auto-zone and they have the VW part # sensor so need to see if the connector is the same............. thumbs
Re: Time for a new oxy sensor............... [Re: Thumperdart] #2430601
01/07/18 05:24 PM
01/07/18 05:24 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Bosch #17205
Re: Time for a new oxy sensor............... [Re: Forest] #2430609
01/07/18 05:38 PM
01/07/18 05:38 PM
State of confusion
State of confusion
thumbs
Re: Time for a new oxy sensor............... [Re: Thumperdart] #2430738
01/07/18 09:46 PM
01/07/18 09:46 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Dom,
What’s wrong with your current sensor?
Re: Time for a new oxy sensor............... [Re: Thumperdart] #2430748
01/07/18 10:07 PM
01/07/18 10:07 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Amazon and Rockauto are usually a lot cheaper. And even if you can't wait for them, your parts store might price match them.
Master, again and still
Re: Time for a new oxy sensor............... [Re: Thumperdart] #2430852
01/08/18 12:36 AM
01/08/18 12:36 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Put some propane heat to ot to clean it up
Re: Time for a new oxy sensor............... [Re: ccdave] #2430880
01/08/18 01:47 AM
01/08/18 01:47 AM
State of confusion
State of confusion
Get this crap, it's been reading all over the place and dancing around so being 10 years old I put a new one in and same thing. I was considering an alt. upgrade here soon as well because at the track it couldn't keep up w/the lights on and the voltage was low in the 13's but when I fired it up w/the second battery and oxy sensor installed today, my volt gauge was showing 15.10 volts and the same tested at the batts. in the trunk. work I looked at the afr gauge and it was damn near solid at 13.6-13.8 but then when I turned off the headlights it was all over the place.......light back on, solid afr readings, lights off, all over the place. So I'm going to start by removing the 2nd batt. and see if anything changes but I ASSume there's a short or bad ground in the headlight switch or maybe 15 volts is too much for the gauge and the lights drop the load........just guessing here and as some know, my electrical skills are NOT worth a damn............... laugh2 thumbs
Re: Time for a new oxy sensor............... [Re: Thumperdart] #2430881
01/08/18 01:49 AM
01/08/18 01:49 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I am pretty sure it's a 17014 with a "rounded" end
the Bosch #17205 connector is square
Joe
Without Data, you’re just another guy with an opinion.
Re: Time for a new oxy sensor............... [Re: sr4440] #2430883
01/08/18 01:55 AM
01/08/18 01:55 AM
State of confusion
State of confusion
Don't have a part # but it's like the top one........... thumbs
Re: Time for a new oxy sensor............... [Re: Thumperdart] #2430893
01/08/18 02:18 AM
01/08/18 02:18 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Electrical problems are not fun. down You will figure it out up Until then however.................
drinking
Re: Time for a new oxy sensor............... [Re: ccdave] #2430911
01/08/18 03:56 AM
01/08/18 03:56 AM
State of confusion
State of confusion
Just isolated the 2nd battery and that wasn't it which makes sense, same w/the oxy sensor so maybe the alt's bad out of no where or who knows but ya, fun stuff and a big weakness for me.............
Re: Time for a new oxy sensor............... [Re: Thumperdart] #2430964
01/08/18 11:23 AM
01/08/18 11:23 AM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
Dom, i would call Innovate about that. I noticed your gauge read out jumping all over on your vids and thought maybe it was your cam over lap as my gauge does not do that. stays fairly steady.
Re: Time for a new oxy sensor............... [Re: Thumperdart] #2430970
01/08/18 11:42 AM
01/08/18 11:42 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Can you "free air" calibrate the sensor? if you can, then the sensor is not bad.
the 17014 sensor is the one used with the LM-1 and 2. I have 10 of them on the dyno and use adapters to go from customers lm-1 sensors to my Daytona controllers.
Good luck!
Re: Time for a new oxy sensor............... [Re: sr4440] #2431014
01/08/18 01:10 PM
01/08/18 01:10 PM
State of confusion
State of confusion
I free air calibrated it no problem but my alt is now putting out 15.1-15.2 volts and the gauge is going crazy, turn on the headlights and it smooths out so I was thinking the sensor was reacting to too much voltage.......... shruggy I will see about hot rodding my alt. or getting a better(more voltage)model and go from there........ thumbs I will also check and add grounds and see what that does as well........ coffee
