Instrument Voltage Regulator upgrade: why 5V instead of 6V? #2429558
01/05/18 06:47 PM
01/05/18 06:47 PM
New Brunswick Canada
copperSwinger Offline OP
Will be redoing the Dash on a 68 Barracuda and will be converting the Instrument Voltage Regulator to Solid State per the November 1992 Mopar Muscle Article.
Most of these conversions use a "7805" voltage regulator which supplies a constant 5V to the gauges. My question is WHY 5V? These gauges are meant to run on 6V so why not get a "7806" voltage regulator instead?
I have heard that people using the 7805 dont get full gauge travel and accuracy. Wouldnt a 7806 therefore be the answer?
Also I have seen some people soldering the additional Capacitor (which is meant to protect the Voltage regulator from spikes) to the 12V input side of the Regulator, and other people soldering it to the 5V output side of the Regulator.
The Mopar Muscle article shows it soldered to the Output side and to ground. This doesnt make sense since it will have no way of protecting the Voltage Regulator since they mounted it "downstream" of the current.
THANK YOU
Here are two links showing different Capacitor configuration:
http://1962to1965mopar.ornocar.org/ml-instrument-voltage-regulator64.html
http://www.jefframin.org/library/IVR.2.jpg
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: copperSwinger] #2429568
01/05/18 07:06 PM
01/05/18 07:06 PM
BDW Online content
BDW  Online Content
Not sure what the original gauges were designed for, but I could never get the 5v regulator to read full scale, so you might be right on the need for 6V.
You do need to consider the current rating of the regulator, some are too low.
Protection cap at input makes sense, wouldn't hurt to have another on the output as well, for ripple suppression.
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: copperSwinger] #2429592
01/05/18 07:54 PM
01/05/18 07:54 PM
I figure by using a 6 V Regulator, I can calibrate the needles at the half way point with 2 AA batteries (3V)
when I test the gauges with 3V they go to half way (give or take 1/16") I can bend the needles as needed so that they all go to precisely half travel at 3 Volts.
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: copperSwinger] #2429596
01/05/18 08:06 PM
01/05/18 08:06 PM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
I know the parts aren’t that expensive, I’ve built a few to the specs in that article. Would be interesting to see the results of both 5 and 6 volt.
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: copperSwinger] #2429597
01/05/18 08:06 PM
01/05/18 08:06 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Does anybody know what voltage the Real Time Engineering regulator run at?
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: copperSwinger] #2429610
01/05/18 08:34 PM
01/05/18 08:34 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: copperSwinger] #2429735
01/06/18 01:32 AM
01/06/18 01:32 AM
FWIW when I bench checked mine they were exactly halfway with 3 volts.
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: copperSwinger] #2429942
01/06/18 02:31 PM
01/06/18 02:31 PM
New York
rarefish Offline
rarefish  Offline
New York
Just an FYI.
Some years back I bench checked a few factory IVR's using my Fluke 179. It has a ability to average readings over time.
The voltage output of the "point style" IVR will start at 12 volts when first powered up then it will go to 0 volts when the points open. The points close again and the it's output goes back to 12 volts. With in a second or two the points will be opening and closing at a very rapid pace. Way too fast for the meter to read in real time.
I switched the meter setting to average reading over time and found that the IVR was outputting and average voltage of around 4 volts. I was a little surprised that it was not closer to 6 volts. I tested the other IVR's using the same method and found the same results.
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: rarefish] #2429949
01/06/18 02:37 PM
01/06/18 02:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The factory IVR s a thermal resistor, it won't work well with the minimal load of the Fluke.
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: copperSwinger] #2429965
01/06/18 02:49 PM
01/06/18 02:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The factory IVR is not a thermal resistor, it is a bimetallic strip that heats and cools cycling the output on and off causing a chopped DC output that averages somewhere around 5V.
Don't be the exception.
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: Supercuda] #2429983
01/06/18 03:14 PM
01/06/18 03:14 PM
New York
rarefish Offline
rarefish  Offline
New York
I guess if you looked at the output on a oscilloscope you would see a square wave form.
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: copperSwinger] #2430010
01/06/18 03:51 PM
01/06/18 03:51 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
How many gauges are you powering, Temp, Fuel, and oil?
The reason I ask, is if all three, the linear IVR (7805) can go into thermal shutdown unless it had a good heat sink.
The 7805 regulator circuit should have both input and output capacitors.
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: 451Mopar] #2430091
01/06/18 06:48 PM
01/06/18 06:48 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Is there a picture of one of these electronic conversions completed? My dash does not work and I am pretty sure this is the reason. I would like to replace the old point type with a newer electronic version.
OOPS!
Never Mind. I just found th elink already posted back a few pages.
Old Geezer Racing
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: SCATPACK 1] #2430147
01/06/18 08:17 PM
01/06/18 08:17 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Why doesn't anybody say anything about Real Time Engineering plug, and play regulator, instead of having to rig something up?
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: copperSwinger] #2430166
01/06/18 08:52 PM
01/06/18 08:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Could it have anything to do with the high price maybe.
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: copperSwinger] #2430171
01/06/18 09:05 PM
01/06/18 09:05 PM
BDW Online content
BDW  Online Content
I'm wondering what's wrong with the factory regulators.
Has anyone ever really had 1 go bad AND destroy the gauges?
Not really seeing the benefit of paying so much for the solid state version.
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: copperSwinger] #2430180
01/06/18 09:22 PM
01/06/18 09:22 PM
While my dash is out, I figured now is the time to do it. It cost $10 (CDN) to make it myself.
Also the A body rally dash doesnt use a seperate plug and play regulator. Its integral to the fuel gauge. I ended up clipping out the regulator parts inside the Gas gauge and rigging it up externally. I ended up using the 5V instead of 6V per Nacho's link. I will test it at school next week and see if I can use their fancy equipment to calibrate them.
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: stumpy] #2430181
01/06/18 09:27 PM
01/06/18 09:27 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
$50 is a cheaper than getting the gauges fixed, and they are designed so that if it fails, the power to the gauges are shut down.
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: BDW] #2430231
01/06/18 11:11 PM
01/06/18 11:11 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Has anyone ever really had 1 go bad AND destroy the gauges?.
Not me, but yes know some and have dissasembled many other clusters damaged because that. Any fail able to keep stuck the points burn the gauges. Even a missed ground which still with a good conditions VL will make the bimetall never to open and feed straight 12v
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V? [Re: NachoRT74] #2430235
01/06/18 11:19 PM
01/06/18 11:19 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Dunno if this could be "promotional" to their product, but seems to be kinda logic
