Re: Bright Dip anodizing
[Re: curbman68]
#2429055
01/04/18 06:57 PM
01/04/18 06:57 PM
Posts: 18,157 Mass
DAYCLONA
Mass
bright dip/anodizing will/could vary between the same and or different vendors, which is why it's usually wise to maintain the same vendor, and have all the pieces done in one batch/lot
Same goes for chrome plating, shop A might use a smoke/grey chrome finish, and shop B uses blue chrome finish, some will ask/tell you, some just take the parts and finish them to what's in use/shop SOP/etc, both shops work appears like "bright chrome", till you combine/match components that you had each shop do for the same project, same happens with bright dip/anodizing, black oxide/ cad plating/etc/etc...and going back to the same shop months or years later is no guarantee that parts done long ago will match parts to be done/redone
[Re: curbman68]
#2429455
01/05/18 03:13 PM
01/05/18 03:13 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I used McNichols in Detroit (Redford, MI actually), nice people and the anodizing work was great. Just the metal straightening was not as good as I wanted. I should add I'm pretty particular, their metal work might be fine to a lot of people Same here,I've been using them for year,only place that sent me everything back and didn't want payment until they were sure I was satisfied with work and one of those bills was over $1,800.I will say that what you get depends a lot on condition when sent,if you have trim that has any pitting,don't expect it to be flawless when finished.Every piece of aluminum trim on this car was done by McNichols.
[Re: curbman68]
#2430196
01/06/18 09:52 PM
01/06/18 09:52 PM
Posts: 6,716 KY
65pacecar
KY
Thanks, I will check the out. I have a 65 Sport Fury finish panel thats needs to be dipped. Straight South western piece with no pitting.
