can't find crank bolt - which MP part # should i order? #242767
03/04/09 11:27 AM
03/04/09 11:27 AM
Oakbank, MB Canada
mbmopar Offline OP
mbmopar  Offline OP
Oakbank, MB Canada
we're moving and lets just say my stock steel crank damper 1972 Chrysler 440 crank bolt went missing, no one here "remembers" where it is.........now which mopar part # do i get??? here's the ad in the catalog:
. Crank Bolt Packages
P5249557AB Crank Bolt Package — 2.25" Length
(426 Hemi, Big Block, Small Block,
Aftermarket Dampers)
P5249562 Thin Damper Crank Bolt Package —
1.25" Length (426 Hemi and Big Block)
THANKS !!!!!!
Derek
"Put a Dodge in your garage!"
Re: can't find crank bolt - which MP part # should i order? [Re: mbmopar] #242768
03/04/09 11:53 AM
03/04/09 11:53 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I would think the shorter of the two is for your application. .
Re: can't find crank bolt - which MP part # should i or [Re: buildanother] #242769
03/04/09 12:03 PM
03/04/09 12:03 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: can't find crank bolt - which MP part # should i or [Re: Dodgem] #242770
03/04/09 02:03 PM
03/04/09 02:03 PM
Oakbank, MB Canada
mbmopar Offline OP
mbmopar  Offline OP
Oakbank, MB Canada
never mind boys - we found it ! THANKS !
