Re: Methanol injection
[Re: oldschoolracer]
#2427079
01/01/18 02:31 PM
01/01/18 02:31 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
I haven't used it, but a lot of guys around me do. There is about a .1 gain, and you can run more timing. All the guys running it are using vacuum pumps with it as well. It also requires a different cam I am told for the injection, but that may be for stacks.
Tuning window is bigger......BUT, for the money, and the hassle, I would never do it....I watch those guys struggle some days. Fuel goes bad, can't get it started, floods out, have to dump bad fuel and find fresh fuel...No thanks. Seems like a real PITA most weekends.
Now if I were to go E85 or Meth, it would be with a carb and a small vacuum pump. A lot less changes needed.
#2427393
01/01/18 09:02 PM
01/01/18 09:02 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I would run a primer plus system with a hat on a tunnelram . Max power, quick warmup on gas and the ability to clear out the alky at the end of each pass so it saves on fuel costs and preserves the cylinder bores during storage and races. I have a single terminater now, and not having the primer plus eats up a lot of alky plus like i said earlier causes problems with bore corosion if you don't do a perfect job of clearing the motor of alky. A well setup car is absolutely deadly consistant, right up till about 96 percent humidity. Then there is a serious dip in power because of the high humidity. I think it amounts to about .04 in the 1/4 on my car, been many years since i had to deal with that. On timing, methanol runs best with about 2 degrees less timing than gas. Throttle response with alky injection is killer. Idle is very fat on an injection system, and fuel is waiting at the intake valve! The first pass i ever ran with an injecter it went right on the bumper launching off idle. What a surprise that was.
#2427706
01/02/18 01:43 PM
01/02/18 01:43 PM
Posts: 4,213 New York
polyspheric
New York
Only the biggest stacks are big enough. The CFM capacity isn't the total of 8 for 8 cylinders, but of 1 for each cylinder, the demand is much greater.
Boffin Emeritus
