Swapping the Glide for 727, weight difference #2426804
12/31/17 11:03 PM
12/31/17 11:03 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
Pulled the glide out of the Hemi GTX this week to replace with a 727 as I am way to heavy to take advantage of the glide. I'm chasing ET, not consistency. Cars weighs 3550 with me in it 540 inch hemi. Best time so far has been a 9.24 at almost 145. 1.31 60 ft, 5.85 in the 1/8.
Weight wise, the glide is a ATI SFI case, Bell and rollerized tail shaft with a deep cast aluminum pan. it came in at 130 lbs on my bathroom scale. the converter was a FTI nitrous 9 inch and with the flex plate and hub came in at 48 lbs for a total of 178 lbs.
Torque flight came in at 150 lbs with carbon shield. 8 inch converter with flex plate 30 lbs for 180lbs total.
I will need to shorten up my steel driveshaft 8 inches so it might be a equal swap!
I didn't stop there. between swapping to Lingenfelter bumper brackets for my lightened stockers I lost 19.8 lbs. With 1/2 of the undercoating removed sofar, I lost another 10 lbs I, am headed in the right direction.
I need to get an 8.99 out of this car before I die. I know I have an easy 30 lbs to go. rear disc over drums, aluminum master cylinder to replace the cast iron and working on a front air dam.
The guy I bought the torque flight has a 3000 lbs Roadrunner that has gone 9.0x. he put a glide in (serious bracket guy) and slowed down to 9.teens-9.20s.
I hope mine picks up what his lost. Wish me luck!
Re: Swapping the Glide for 727, weight difference [Re: mercman1] #2426812
12/31/17 11:14 PM
12/31/17 11:14 PM
fullmetaljacket Offline
You could shave off an easy 100 Lbs if you look closer at the beast.
What year GtXXXX is this we speak?
Re: Swapping the Glide for 727, weight difference [Re: mercman1] #2426818
12/31/17 11:20 PM
12/31/17 11:20 PM
Palm City, FL
Dadodgekid Offline
Dadodgekid  Offline
Palm City, FL
1969 GTX
Still wont be as fast as willard..... thumbs haha
Re: Swapping the Glide for 727, weight difference [Re: mercman1] #2426820
12/31/17 11:21 PM
12/31/17 11:21 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Heck, if we put your engine in my 2700lb A-body, it would be in the 8's already....Post some pics please...
Re: Swapping the Glide for 727, weight difference [Re: mercman1] #2426828
12/31/17 11:31 PM
12/31/17 11:31 PM
Speak no further than MoparJohn. His GTX is classified weight material and he's flying for an ALMOST all metal brute.
Re: Swapping the Glide for 727, weight difference [Re: Dragula] #2426829
12/31/17 11:31 PM
12/31/17 11:31 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
Have yet to figure out how to add a picture. I've looked at the instructions and the don't work for me. Any hints? Car is a 69 and looks almost show quality.
Willard's dart is toast compared to the GTX. His MoFo is something to definitely fear. 8.90s from a normally aspirated small block mopar in the Thunderbird is just Bad A$$! The 2700 lbs doesn't hurt.
Re: Swapping the Glide for 727, weight difference [Re: fullmetaljacket] #2426831
12/31/17 11:34 PM
12/31/17 11:34 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
Who is this MoparJohn and how much alchol must I pry him with to give up his secrets?
Re: Swapping the Glide for 727, weight difference [Re: mercman1] #2426835
12/31/17 11:37 PM
12/31/17 11:37 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Regarding pics, you have to put the picture on a photo-hosting site, then link to it. Not sure if the mods have changed the directions since the software change about a year ago (you used to be able to drop them straight here).
Re: Swapping the Glide for 727, weight difference [Re: mercman1] #2426838
12/31/17 11:41 PM
12/31/17 11:41 PM
Palm City, FL
Dadodgekid Offline
Dadodgekid  Offline
Palm City, FL
Here are some old pictures
Re: Swapping the Glide for 727, weight difference [Re: Dadodgekid] #2426842
12/31/17 11:49 PM
12/31/17 11:49 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
That's my girls! Thelma, the Street GTX my girlfriend races (very well I might add) and Louise the Hemi GTX I race. Hemi has the lift off hood. Street GTX has gone 10.84 at 123.50 at almost 4000lbs with a 3.73 gear. Pump gas 493.
Re: Swapping the Glide for 727, weight difference [Re: mercman1] #2426925
01/01/18 03:10 AM
01/01/18 03:10 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I've never seen John drink, but he does like helping Mopar folks go faster. Say his name 3 times and he will appear. boogie
Re: Swapping the Glide for 727, weight difference [Re: mercman1] #2426967
01/01/18 08:14 AM
01/01/18 08:14 AM
Palm City, FL
Dadodgekid Offline
Dadodgekid  Offline
Palm City, FL
Heres a couple more
Re: Swapping the Glide for 727, weight difference [Re: slantzilla] #2427009
01/01/18 12:54 PM
01/01/18 12:54 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
MoparJohn MoparJohn MoparJohn I need about a tenth and a half. Please send your GTX Genie to Stuart Fl. There are 4 GTXs in the garage that can use your help.
Re: Swapping the Glide for 727, weight difference [Re: mercman1] #2427100
01/01/18 02:46 PM
01/01/18 02:46 PM
I've reached out to MoparJohn and he should be on board shortly. He's also sprinkled some of his ideas on the other weight thread on here (Real world weight loss and its cost)
Re: Swapping the Glide for 727, weight difference [Re: mercman1] #2427203
01/01/18 04:20 PM
01/01/18 04:20 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
This MOPAR powered T-bird,,,,,does it come off the Island of Long??
Sound familiar.............. popcorn
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Swapping the Glide for 727, weight difference [Re: mercman1] #2427218
01/01/18 04:38 PM
01/01/18 04:38 PM
Palm City, FL
Dadodgekid Offline
Dadodgekid  Offline
Palm City, FL
No sir, its a street car out of florida
Re: Swapping the Glide for 727, weight difference [Re: mercman1] #2427231
01/01/18 04:57 PM
01/01/18 04:57 PM
Northeast
Racer68 Offline
Racer68  Offline
Northeast
ok. So can you educate me as to why a glide would slow the car down. This isn't the first time I've heard this but never asked before. A few years ago I called ATI and told them I was looking for a 727 beefed up for racing and he said no you want a glide. I haven't had a chance to complete the car but I do have a new glide sitting in the garage
Re: Swapping the Glide for 727, weight difference [Re: Racer68] #2427255
01/01/18 05:29 PM
01/01/18 05:29 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Lighter cars like glides. As far as the OP is concerned, I think I would try another 1st gear set or rear gear to get that tank moving rather than go to the 3 spd. I picked up .02 in 60 and a nearly a tenth in a 2,400# car switching to a glide. Not to mention the night and day consistency... My twocents
Re: Swapping the Glide for 727, weight difference [Re: Dave Hall] #2427309
01/01/18 06:52 PM
01/01/18 06:52 PM
What weight constitutes "Lighter car"? I ask because 2,400 Lbs is ultra light/feather weight and most people have different ideas/numbers of what a light car is.
Re: Swapping the Glide for 727, weight difference [Re: mercman1] #2427325
01/01/18 07:18 PM
01/01/18 07:18 PM
Northeast
Racer68 Offline
Racer68  Offline
Northeast
I was going to ask about gear ratios because ATI offers a lot of them . Before I put my car together I'm gunna make sure the gearing is right. I hate to call some of these companies
I always worry that the rep knows less than I do. As far as weight I would expect the rep to set you up based on weight of the car ect.
