R/T side scoop bracket?
#2424918
12/28/17 02:59 PM
12/28/17 02:59 PM
Posts: 670 Third rock from the sun.
busboy
Seasons Greetings All, picked up a set of the repop R/T side scoops a little while ago. They appear to be a very nice, accurate piece. Similar to the originals, these have that little bracket on the inside that seems to serve no purpose. On these repops, there is also some wire sticking out of the same bracket. Anyone have any idea what it's for? The wire will have to be cut off or bent down for the scoops to fit flush. Thoughts??
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: R/T side scoop bracket?
[Re: stumpy]
#2424935
12/28/17 03:40 PM
12/28/17 03:40 PM
Posts: 4,762 Florida
BDW
Just a wild guess,
If you unscrewed that bracket and flipped it over, and mounted from inside, the wire loops looks like it would snap into the hole and locate the scoop.
On 2nd thought, maybe you drill a hole smaller than wire loops and just press fit through quarter panel?
[Re: stumpy]
#2424937
12/28/17 03:50 PM
12/28/17 03:50 PM
busboy
No instructions at all Stumpy. I've had a look at an original one, it had that little bracket as well just not the wire sticking up. I was thinking it was a bracket/mount used in the production process. I won't mess with anything till I figure this out.
[Re: busboy]
#2425118
12/28/17 11:01 PM
12/28/17 11:01 PM
Posts: 18,160 Mass
DAYCLONA
Mass
No instructions at all Stumpy. I've had a look at an original one, it had that little bracket as well just not the wire sticking up. I was thinking it was a bracket/mount used in the production process. I won't mess with anything till I figure this out. You answered your own question, it's an assy line component to retain the scoop after it was plopped on, so that only one line operator (working inside the vehicle) was needed to tighten it from inside, no need to have an assistant hold it in place so that it wouldn't fall off...it'll aid you as well if working alone, items like this were prepainted and delivered to the line, when the optioned/equipped vehicle/model came down the line, the required part was plopped on, the worker(s) only had seconds, not minutes to install and fasten parts... the scoop you saw (off the car) minus the clip, was no doubt pulled in haste, or unknowingly of the types of fasteners used, and the wire retainer was pulled off
[Re: DAYCLONA]
#2426392
12/31/17 03:58 PM
12/31/17 03:58 PM
busboy
Thanks Dayclona, so does that mean I need to drill another hole in the quarter for it? I've got some help working on the car, less holes the better, seems like we could work with the three for the studs.
[Re: busboy]
#2426415
12/31/17 04:41 PM
12/31/17 04:41 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Thanks Dayclona, so does that mean I need to drill another hole in the quarter for it? I've got some help working on the car, less holes the better, seems like we could work with the three for the studs. less holes the better...
