Page 2 of 4 1 2 3 4
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424688
12/27/17 11:46 PM
12/27/17 11:46 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
The Cuda gets a new cage in Feb to replace the one installed in 1988. Still trying to decide on a power plant. Leaning towards a 540 w/a F2
or a 540 w/B1's.
This will probably be a 2018-2019 build. Lol
Ok
Re: Looking to 2018. What are you Building? [Re: Dragula] #2424694
12/27/17 11:53 PM
12/27/17 11:53 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Originally Posted By Dragula
I have a set of G3 ported Eddy heads, and I just scored a mint 400 block, and a set of new Hedman fenderwll headers, and I am just finishing the install of my 605 Hemi in the Cuda....
Those pieces should fit together nicely hammer
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424701
12/28/17 12:10 AM
12/28/17 12:10 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Remove my 547 wedge from my sons car, remove the heads and put them onto his 440 and fit it to his car.
Refresh the 547 short.
Remove my 528 wedge from the Cuda, remove the heads and give them a rebuild with new springs and locks.
Fit the heads to the 547 and fit into the Cuda with new convertor.
Refresh 528 and wrap it up.
Fabricate molly cage for the Cuda.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424790
12/28/17 07:44 AM
12/28/17 07:44 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Hopefully a 50x80x16 pole barn in the back yard to put everything in, with a lift!
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424809
12/28/17 11:33 AM
12/28/17 11:33 AM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
65 Plymouth Satellite to do some bracket racing with. 506 wedge with Victor maxwedge and solid roller.Shooting for 10.0s The chassis is being done now. Plan is a narrowed Dana with Caltracs and mono springs. Once that is completed and ready it's on to the driveline. Hope to have it ready for shakedown passes this year and turn my daughter loose in it at some point. She has some time left to Jr. race so we aren't in a hurry.
71 440-6 4spd & 69 Hemi 4spd
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424818
12/28/17 12:07 PM
12/28/17 12:07 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Well I guess I can finally show the mostly finished product. It started life and one of Rick Jones personal Pro Stockers. It was only run at a couple races before they went back to GM stuff. Was raced by Art Hodges for a couple years after that then was sold and sat for years til I acquired it in 2014. We stripped the three paint jobs from its pro stock days car down to bare carbon and chassis. We also removed all the wiring from the car and started over. Been a long long road with only being able to work on it when I'm in Vegas. We moved to DC in the end of 2014 as well. So work has been slow to say the least. The car is now pretty much done and ready to go. We spent a lot of time dropping weight out of it where we could. It is all Carbon and has some titanium components on it as well. The engine has been another pain to say the least and it is apart again having the heads redone by Slawko and will have a new HRE intake built when the heads are done. The back to the dyno a quick look inside and back in the car. Hope to have it out by summer when we come back to Vegas permanently when the wife retires from the USAF..
Anyway here she is. I am sure the paint is a love it or hate it thing. My sons kind of came up with the design in a combined effort deal. Hopefully it will run ok, if I don't sell the Mopar power plant and jump ship. Anyway hope some like it. Sorry about the mess in the garage, I'm not home much and we seem to have a car in there all the time for chassis stuff smile
Re: Looking to 2018. What are you Building? [Re: Al_Alguire] #2424819
12/28/17 12:09 PM
12/28/17 12:09 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Looks great, Al. Good luck with it this coming year.
Re: Looking to 2018. What are you Building? [Re: hemi_doug] #2424824
12/28/17 12:26 PM
12/28/17 12:26 PM
an8sec70cuda Offline
Buy new axles, weld in subframe connectors and a cage and do some footbrake bracket racing w/ this car.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Looking to 2018. What are you Building? [Re: an8sec70cuda] #2424825
12/28/17 12:27 PM
12/28/17 12:27 PM
Finish reassembling this '71 Demon 340 and ruin some tires.
CHIP
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424887
12/28/17 02:21 PM
12/28/17 02:21 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Plan to have my renewed 68 Cuda back out early in the year. Over the past 2 yrs I have almost completely redone the whole car. I started with replacing the 8 3/4 and suspension with an aftermarket 9", new aluminum driveshaft, new suspension and a new set of slicks. I also removed all of the stock front suspension and built new K member setup for installation of Lamb struts, Pinto rack & pinion steering and Centerline spindle mount wheels. The power plant is my NA 413ci Xblock converted to a basically new blower motor. Using the Xblock and my 3.91 crank I have new Large Port Commando heads, new Racetec pistons on Lentz rods. Intake is a Offenhauser blower manifold with a 6-71 sitting on it. For fuel delivery I have a Hilborn bugcatcher injection which I have set up for E85. Didn't do anything to the JW Powerglide trans except change it's location a little over an inch.
One of the biggest challenges was determining location and designing mounts for hilborn fuel pump, vacuum pump, alternator and the CSI electric water pump. I had it all mocked up and then decided to go to the strut front end which required use of a motor plate. That required redo of all the mounting plans for the front of the engine. I've got it all figured out now and should be ready in Feb or March.
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424899
12/28/17 02:30 PM
12/28/17 02:30 PM
Renton Washington
Triple Threat Offline
Renton Washington
I bought a 68 Barracuda F/SA Stock Eliminator car that has been sitting for a decade. Been going through it, cleaning it up, all new wiring, new fuel system, carpet, seats, painting etc. I will run it some this year with a 360/380 crate motor while going through and building a 340 for it to be run in stock again.
Day 1
Removed the old stickers
Trunk
360/380 crate motor with a few upgrades. Repainted engine bay
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Looking to 2018. What are you Building? [Re: Triple Threat] #2424920
12/28/17 03:02 PM
12/28/17 03:02 PM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
Put my new PSO headed B1 in Silverfish and hopefully run some 4.50-4.70'S according to class and jet limit !!
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424923
12/28/17 03:06 PM
12/28/17 03:06 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Gary..... you coming to Norwalk this coming year?
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Looking to 2018. What are you Building? [Re: B3422W5] #2424927
12/28/17 03:14 PM
12/28/17 03:14 PM
Idabel,Oklahoma
Idabel,Oklahoma
Doubtful as it's the same weekend as the Polaris dealer show and someone from the store needs to be there which is usually me !!
I love the MMW show and people but hate the date change !!
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424930
12/28/17 03:27 PM
12/28/17 03:27 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
I'm hoping to take the Cuda out a few times this year, considring adding a 150 shot to it, that's why I'm pondering ordering a Dana to repalce the 8.75.
I'm just finishing my '69 Valiant sleeper, should be fun to drive, plan to drive it to the track, should go high 11's/low 12's on the motor.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Looking to 2018. What are you Building? [Re: Gary Robbins] #2424944
12/28/17 04:04 PM
12/28/17 04:04 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Better get rid of that JW wheel. The one I had in my Lebaron shed the starter ring and nearly sawed the passenger side frame rail in two. The "Wheel" was only a couple years old as well.
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424992
12/28/17 06:18 PM
12/28/17 06:18 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I just picked up G3 Hemi core also. Found it at a local boneyard for a couple hundred.
Re: Looking to 2018. What are you Building? [Re: qwkmopardan] #2424996
12/28/17 06:29 PM
12/28/17 06:29 PM
my own world
theraif Offline
theraif  Offline
my own world
going to try to make mad money selling art heheheh
Re: Looking to 2018. What are you Building? [Re: theraif] #2425037
12/28/17 07:59 PM
12/28/17 07:59 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
That will work as ALL Artist are rich. LOL. I'm still paying off my Sons Art School loan.
Ohhhh and he's a Parts Manager at an Autobody shop in Colorado so that counts, RIGHT!!!!!
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Looking to 2018. What are you Building? [Re: pittsburghracer] #2425130
12/28/17 11:14 PM
12/28/17 11:14 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
I'm going to a crank trigger and a bigger carb. Easy winter...
Page 2 of 4 1 2 3 4
