0-w40 oil question #2424303
12/27/17 11:30 AM
12/27/17 11:30 AM
S.E. Missouri
AeroMonte Offline OP
S.E. Missouri
I read somewhere that I should not be using 0-W40 oil as recommended by Mopar in our Hellcat and Demon cars. Now I can't find the article back. Wouldn't this void the warranty if I don't? The article said there were several engine failures because of this oil and I really don't want to chance it if it is true. Looking for insight from those smarter than me.
Re: 0-w40 oil question [Re: AeroMonte] #2424337
12/27/17 12:42 PM
12/27/17 12:42 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
What does the manufacturer recommend? Anyone else doesn't matter, as they didn't design the engine and are likely going off of some sort of archaic information.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: 0-w40 oil question [Re: AeroMonte] #2424371
12/27/17 02:01 PM
12/27/17 02:01 PM
S.E. Missouri
S.E. Missouri
Manufacturer says 0-W40, but if there are issues I want to know
Re: 0-w40 oil question [Re: AeroMonte] #2424382
12/27/17 02:24 PM
12/27/17 02:24 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
If there were issues, Mopar/Dodge would be the first to know, and the first to let customers know. Engineers came up with the oil recommendations for a reason.
Re: 0-w40 oil question [Re: A39Coronet] #2424411
12/27/17 03:22 PM
12/27/17 03:22 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Better fuel milage. Thats it. The only reason OEM's require 0 weight oil. Blame it on the govt
Re: 0-w40 oil question [Re: AeroMonte] #2424437
12/27/17 03:54 PM
12/27/17 03:54 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Oh I don't doubt that one bit...but I'm sure these engine was designed with those restrictions in mind.
Re: 0-w40 oil question [Re: AeroMonte] #2424439
12/27/17 03:55 PM
12/27/17 03:55 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the much tighter tollerances in the modern engines is why they need 0 weight, the thicker it gets the more it is like glue with that tight and precise of a tollerance. MPG on a demon or even a hellcat is insignificant. If they thought it was going to destroy and engine with that 60K warranty and they could solve it by recomending 5 or 10 weight they would be all over it.
Re: 0-w40 oil question [Re: AeroMonte] #2424567
12/27/17 07:41 PM
12/27/17 07:41 PM
Northern Colorado
E
EagleDuster Offline
EagleDuster  Offline
E
Northern Colorado
I would be more concerned with voiding the warranty than blowing up my engine while it's still under said warranty... Dealers will try to find any stupid little reason to deny a warranty repair. I know there was a guy on YouTube with a Hellcat Charger, something broke in the supercharger system and his dealer refused to fix the car under warranty because he had an aftermarket cold-air intake. He finally did get it fixed for free but not after a whole bunch of legal BS getting second and third opinions and communicating directly with FCA on the issue which took a few months IIRC.
Khalid
1970 Plymouth Duster, 1993 Jeep Cherokee 4x4
Re: 0-w40 oil question [Re: EagleDuster] #2429631
01/05/18 09:32 PM
01/05/18 09:32 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
I would not use any oil that was not factory fill. The oil was formulated specifically for the engines. Very different oil than reg syn.
Leave the gun.......take the Cannoli's....Mike
Re: 0-w40 oil question [Re: sixpackgut] #2429666
01/05/18 10:55 PM
01/05/18 10:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The ignorance in this statement is overwhelming and a prime example of why the OP should listen to the manufacturer and not some internet clown.
Do you even know what 0w40 means?
No, you do not.
Educate yourself
http://www.upmpg.com/tech_articles/motoroil_viscosity/
Don't be the exception.
Re: 0-w40 oil question [Re: AeroMonte] #2429984
01/06/18 03:14 PM
01/06/18 03:14 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Ouch.. Hot Rod Dave it the nail on the head...tolerances...
Bob(Cowboy)Hogan
Monrovia So-Cal
