Some stage 6 stuff #2423900
12/26/17 02:15 PM
12/26/17 02:15 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
This will be another one of those threads where there is only about 5 people who are all that interested....... But again, it's winter...... So I'm doing my part in providing "content".
This is sort of a continuation of another thread from about a year ago:
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2205545/1/mopar-stage-6-heads.html
These particular heads are a bit of a mystery.
They had about 10 shipping labels on the boxes, so they have definitely changed hands a few times.
They already had some cnc porting done, but I don't think it was done through MP channels.
These heads had a few ex seats that had been replaced, most likely as a means to correct some of the typical fairly substantial valve seat depth variation.
They also had 11/32 guides installed, but the ID's were unfinished and you couldn't even begin to slide a valve in.
The cnc porting ran over the guides, so they were installed prior to the porting.
After fitting the guides, the valve seat concentricity was pretty far off, so I think the previous "valve job" was done when the 3/8" guides were still in the heads.
Some of the other highlights are, the chambers are really quite large in diameter......so much so that they will require the use of a Cometic 4.600 bore gasket if you don't want the gasket fire ring hanging into the chamber.
The spark plug holes were cut too deep, and/or the chambers are cut too much, so the plugs hang way into the chambers. Plug washers can correct this.
I don't like it when the two small coolant holes by the dowels are so close to the chambers, so I plugged them.
The rocker shaft holes on one head had a raised burr around every hole, which was more pronounced than it looks in the pic, which could have created a place for oil to leak out instead of going where it needed to.
I wouldn't call the cnc work really "finished"....... But rather, more of a roughing job that resulted in a lot less time needing to be spent porting out material that shouldn't have been there in the first place.
Re: Some stage 6 stuff [Re: fast68plymouth] #2423916
12/26/17 02:57 PM
12/26/17 02:57 PM
So. Burlington, Vt.
So. Burlington, Vt.
A few more "before" pics:
1009 gasket
Re: Some stage 6 stuff [Re: fast68plymouth] #2423918
12/26/17 03:06 PM
12/26/17 03:06 PM
AndyF Online content
AndyF  Online Content
Good luck with those! Looks like various people have tried to salvage them over the years but everyone to date has given up.
Re: Some stage 6 stuff [Re: fast68plymouth] #2423919
12/26/17 03:07 PM
12/26/17 03:07 PM
So. Burlington, Vt.
So. Burlington, Vt.
Since the guides were unfinished, and the seats weren't concentric to the guides, fitting the guides and recutting the seats would represent the absolute minimum work required to be able to run the heads.
Even though some ex seats had been replaced, the valve depth variation still wasnt great.
I got all the intake and exhaust seats on each head close to each other, but the two heads still had a variance of about .010-.015 between the two heads, which I planned on getting closer with milling later on.
After cutting the seats, the heads measured 92cc for one head, 94cc for the other.
These are going on a Mopar crate motor, and the part number for the service replacement head for those is 90cc, so no problem getting them into "spec" as far as chamber volume goes.
The cnc work on the intake port was fine. It got most of the big stuff out of the way, and left a little bit to work with and get into the final desired shape.
The exhaust however was not how I would have gone about it.
Way too much material removed from the short turn and floor, and too much left on the backside of the bowl.
I was pretty sure this lower ex port floor wasnt going to end up all that good...... But it is what it is.
Flow with as rec'd cnc work and seats cut, no additional porting-
4.375 bore, 28" test pressure, no tube on ex:
Lift------in/ex
.100---70.2/55.3
.200--133.6/112.7
.300--196.8/147.6
.400--248.7/165.1
.500--286.8/178.1
.550--293.5/183.0
.600--292.4/189.1
.650--291.7/192.7
.700--291.7/195.6
Re: Some stage 6 stuff [Re: fast68plymouth] #2423932
12/26/17 03:43 PM
12/26/17 03:43 PM
So. Burlington, Vt.
So. Burlington, Vt.
One of the first things I did was to plug those small coolant holes.
I tap them with a fine tap....... Then take a piece of 3/8 aluminum rod, turn it down to 5/16 so I can thread it up about 3/8" or so, then with green loctite on it, thread it into the head until it bottoms out at the end of the threads. Snug it up tight, then cut it off.
Re: Some stage 6 stuff [Re: fast68plymouth] #2423936
12/26/17 04:00 PM
12/26/17 04:00 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Of course since I own and run stg 6 heads on my 451 ci engine(now my spare) count me as an interested party!
Excellent tech info Dwayne. Thanks.
Don
Re: Some stage 6 stuff [Re: fast68plymouth] #2423946
12/26/17 04:37 PM
12/26/17 04:37 PM
So. Burlington, Vt.
So. Burlington, Vt.
Stage 6 heads of this vintage, which have pushrod tunnels for the intake pushrods, don't have the alignment of all the tunnels very even, and as a result, they often have a few holes that will need relieving...... Especially if 1.6 or higher ratio rockers will be used....... As was the case for these(the motor they're going on has Crane 1.6's).
So, I did some clearancing...... Hopefully it ends up being enough.
I also trimmed off that raised lip around the rocker shaft bolt holes.
Re: Some stage 6 stuff [Re: fast68plymouth] #2423952
12/26/17 04:57 PM
12/26/17 04:57 PM
So. Burlington, Vt.
So. Burlington, Vt.
Every set of stage 6's I've done have had some sort of issue that I hadn't seen with them before, and even though as a whole these weren't all that bad(in the grand scheme of things in the stage 6 world), they didn't disappoint in that regard.
I thought I had a good before/after pic of this, but I apparently didn't take an "after" pic.
I'm not sure why these ended up this way, and it's not really that big of a deal...... But something I hadn't run into before.
The massively deep spring pockets, which get modified for better drainage so the tops of the seals aren't submerged in oil, aren't a "normal" size.
They're too big to properly locate a 1.550 type spring if you only wanted to run a shim under the spring, but they aren't big enough to fit a spring cup.
And the guides don't stick out of the top enough to run a spring seat and still get full engagement of the seals.
So, they need to be opened up to use a normal spring cup.
On this set of heads, the spring pockets were no where near centered on the guides.
On some of the holes, it was cutting about .060 out of one side, and not even touching the other side.
The one before pic I have, you can see how one side of the spring pocket wall is much thicker than the other.
After recutting, they were much closer in thickness all the way around.
Re: Some stage 6 stuff [Re: fast68plymouth] #2423960
12/26/17 05:16 PM
12/26/17 05:16 PM
So. Burlington, Vt.
So. Burlington, Vt.
So, after the guides were honed, seats cut, pushrod tunnels relieved, spring pockets cut for spring cups, and modified for better oil drain back, coolant holes plugged, thread chase all bolt holes...... As well as checking to make sure there were no issues with intake manifold face alignment, or rocker shaft to valve spacing......... It was finally time to start in on improving the flow.
Nothing really too drastic was planned....... Just a basic cleanup and detailing of what was there.
A better final approach into the intake bowl along with trimming the guide boss a bit more, then knocking down the fairly course cnc ridges.
The exhaust also got the basic clean up work, but there wasnt much I could really do about the missing material from the floor and short turn.
The flow was steady on the exhaust, but pretty noisy.
Re: Some stage 6 stuff [Re: fast68plymouth] #2423969
12/26/17 05:28 PM
12/26/17 05:28 PM
So. Burlington, Vt.
So. Burlington, Vt.
Some before n after:
Re: Some stage 6 stuff [Re: fast68plymouth] #2423975
12/26/17 05:36 PM
12/26/17 05:36 PM
It would be interesting to know how much money has been spent on that set of heads over the years. Looks like the heads went to a few different shops for work but never got finished and now you are finishing them.
Re: Some stage 6 stuff [Re: fast68plymouth] #2423989
12/26/17 05:52 PM
12/26/17 05:52 PM
Washington
madscientist Offline
Washington
That picture of the exhaust port certainly violates the 85% rule!! Damn those things are big.
Re: Some stage 6 stuff [Re: fast68plymouth] #2424001
12/26/17 06:07 PM
12/26/17 06:07 PM
So. Burlington, Vt.
So. Burlington, Vt.
That's an illusion from the camera....... They really aren't that big.
I just cleaned up/squared up the cnc job, I didn't make it any "bigger".
It's well within a typical 2" header flange.
Re: Some stage 6 stuff [Re: fast68plymouth] #2424010
12/26/17 06:22 PM
12/26/17 06:22 PM
So. Burlington, Vt.
So. Burlington, Vt.
After I get the porting done, I'm giving them another little inspection and notice there is a gap under one of the intake seats.
Since its not uncommon for stage 6's to have the seats move around, or fall out, I figured it would be best to not chance it, and replaced it so I'd know it had adequate press fit.
Re: Some stage 6 stuff [Re: fast68plymouth] #2424015
12/26/17 06:32 PM
12/26/17 06:32 PM
So. Burlington, Vt.
So. Burlington, Vt.
These are supposed to be going on a MP 575hp(?) crate motor that already has stage 6's on it.
Those come with the 509 cam and he's running 1.6 rockers, and doesn't plan on changing the cam.
He also didn't want to have any intake fitment issues or replace the pushrods if possible.
As such, the heads were only milled enough to equalize the chamber volumes between the two heads, and get them under the 90cc spec....... I went for 88cc's.
I used the same springs that come on a set of Edelbrock RPM heads and set them up at about 145lbs on the seat....... Along with Comp Cams 10 degree retainers and locks.
Metal jacket Viton seals, spring cups, and SI 2.14/1.81 stainless valves.
Finished flow numbers:
Lift-------in/ex----ex w-2" tube
.100---71.3/61.5
.200--149.2/115.9
.300--211.2/157.8
.400--267.4/179.3
.500--306.7/193.2---221.1
.550--319.7/199.3---226.8
.600--318.6/205.4---236.2
.650--320.5/209.8---241.9
.700--321.6/213.9---248.3
If you look at the last pic, you can see that after milling the coolant hole plugs pretty much disappear.
As far as stage 6's go, these weren't that bad at all to do. They usually kinda need the guides replaced right ootb, the seat depth variation is usually around .060, with the chamber depths(and volumes) varying about the same amount, and when they have the monster sized guide bosses they require a fair amount of extra time in porting.
The date on the box for these was 12/96, so it took 21 years for them to be finished and ready to be used.
Re: Some stage 6 stuff [Re: fast68plymouth] #2424038
12/26/17 07:21 PM
12/26/17 07:21 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Very nice work!
69 GTX 68 Road Runner
Re: Some stage 6 stuff [Re: JERICOGTX] #2424040
12/26/17 07:27 PM
12/26/17 07:27 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Cool thread!
I was perusing ebay the other day and saw this:
B1 Head Package
I was thinking that the winner of the auction will be in contact with Mr. Porter lol.
B1's that flow 370?
Re: Some stage 6 stuff [Re: Jeremiah] #2424087
12/26/17 08:50 PM
12/26/17 08:50 PM
SoCal
Brian Hafliger Offline
SoCal
Did you pressure test them before and after?
Brian Hafliger
Re: Some stage 6 stuff [Re: fast68plymouth] #2424089
12/26/17 08:53 PM
12/26/17 08:53 PM
So. Burlington, Vt.
So. Burlington, Vt.
I didn't.
There isn't what I would call "extensive" porting.
I haven't seen leaking castings as an issue with stage 6's in general, other than the porous early ones...... But those actually look a little different, so they're easy to spot.
Re: Some stage 6 stuff [Re: fast68plymouth] #2424094
12/26/17 08:58 PM
12/26/17 08:58 PM
SoCal
SoCal
I've seen these damn things be porous in the bowls with no porting! Might have been super old castings but I could not believe it!
Brian Hafliger
