Re: Some stage 6 stuff
[Re: fast68plymouth]
#2424096
12/26/17 09:03 PM
12/26/17 09:03 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The earliest ones were pretty famous for porosity.
The ones I've worked on of this vintage often have plenty of issues...... But that hasn't been one I've come across...... Yet.
#2424344
12/27/17 12:59 PM
12/27/17 12:59 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Thanks for the post Dwayne! Your work looks awesome as always. I love seeing these posts even if it's something that I will never have to worry with (hopefully).
[Re: dart9ss]
#2426431
12/31/17 04:53 PM
12/31/17 04:53 PM
BradH
When I saw the subject of this t read, I didn't know if I should or and watch the story unfold. If the owner is using the MP Stage VI RB 4150 intake manifold, he needs to look into getting it reworked to really see the benefits of the improved heads. Out of the box, it leaves a LOT to be desired.
#2426472
12/31/17 05:13 PM
12/31/17 05:13 PM
fast68plymouth
So. Burlington, Vt.
Brad......refresh my memory.
Doesn’t the stage 6 manifold really have MW sized runners, and is shrunk down where it bolts to the heads?
That’s how I remember it.......but I haven’t looked at one in several years.
If that’s how it really is, and one was looking for the “next step” in improving the flow into the motor........I would think opening it up, and then making the heads MW size to match would make the most sense. I think you’d probably have to make a step up from the 509 cam to really see much benefit though.
#2426625
12/31/17 07:42 PM
12/31/17 07:42 PM
BradH
... Finished flow numbers:
Lift-------in/ex----ex w-2" tube .100---71.3/61.5 .200--149.2/115.9 .300--211.2/157.8 .400--267.4/179.3 .500--306.7/193.2---221.1 .550--319.7/199.3---226.8 .600--318.6/205.4---236.2 .650--320.5/209.8---241.9 .700--321.6/213.9---248.3
FWIW, Dwayne's last test on my old hand-ported Stage VIs: Stage VI test #1 cylinder: Lift -- Int / Exh (no tube) .100 --- 69 / 53 .200 -- 143 / 108 .300 -- 213 / 146 .400 -- 262 / 181 .500 -- 293 / 211 .550 -- 305 / 222 .600 -- 307 / 231 .650 -- 307 / 237 .700 -- 307 / 243 And these were good enough for 600+ HP on a pump-gas 440 w/ the right combination of parts. However, the subject heads are going on something quite a bit different, from the sound of things.
