Harbor Freight Engine Cherry Picker / Lifting an Engine #2421945
12/21/17 05:17 PM
12/21/17 05:17 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
So, maybe it's just me or maybe the Harbor Freight instructions just suck, but I'm trying to put hydraulic fluid into my 2 ton Harbor Freight Cherry Picker so that I can lift my engine and fix my motor mounts or add shims. The instructions mention to remove an oil fill cap and to pour oil into the cylinder until it overflows; however, nowhere else in the entire instruction manual does it mention which hole is the oil fill hole. So, naturally I look at the cylinder and say, "Hey there is this rubber fitting and this hole is at the highest point of the cylinder, maybe that's it." So, I yank the rubber fitting, which was a pain in the butt since it's tapered, and grab my bottle of hydraulic fluid and dribble it inside. Not knowing if it's doing anything or even filling, I say to myself, "Let's test to see if it's actually doing anything." I grab the rubber fitting to put it on and due to the taper it doesn't want to go back in the hole.
So, I'm just guessing here, but I did something wrong, right?
Any tips or advice? Is there another way to adjust my motor mounts without using a cherry picker?
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2421951
12/21/17 05:27 PM
12/21/17 05:27 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
I've done it for many years by putting the floor jack under the oil sump. With a piece of plywood or 6x6 between the pan and jack pad to spread out the weight better.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: amxautox] #2421952
12/21/17 05:28 PM
12/21/17 05:28 PM
SoCal
SoCal
That's actually not a bad idea. Thanks!
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2421954
12/21/17 05:29 PM
12/21/17 05:29 PM
amxautox Offline
amxautox  Offline
As far as putting the rubber plug back in, put some vasoline on the plug, it should go in easier.
Tom
author unknown
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2421959
12/21/17 05:37 PM
12/21/17 05:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That's the right hole for oil. Fill it and work the plug back in.
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2421994
12/21/17 07:05 PM
12/21/17 07:05 PM
SoCal
SoCal
I was able to lift the engine and make spacers using Tom's method, but I will keep chugging with the hydraulic cylinder.
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2422148
12/22/17 12:12 AM
12/22/17 12:12 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
When you fill the lift cylinder, be sure the rod is completely down inside the cylinder, or when it goes back in, the oil will run out the fill hole. Gene
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2422164
12/22/17 12:40 AM
12/22/17 12:40 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
A lot of those rubber plugs need to be stretched out with an allen wrench or other suitable thin rod in order to be put back in the hole. That is, if it has a place in the center to put the rod.
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: Jim_Lusk] #2422168
12/22/17 12:44 AM
12/22/17 12:44 AM
amxautox Offline
amxautox  Offline
...and don't punch a hole in the rubber with the allen wrench...
Might have to use a small screwdriver to push the lip into the hole, working it around the hole a little at a time. Do it easy like, with care.
Tom
author unknown
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: amxautox] #2422197
12/22/17 02:31 AM
12/22/17 02:31 AM
agreed
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2422258
12/22/17 10:48 AM
12/22/17 10:48 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I had a toy back in late 70s or early 80s that used rubber rivits to hold panels and parts together. The "riviter" was a tool that grabbed the head and stretched the body of the rubber rivit so it would squeeze through the holes. I think you need that tool.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2422262
12/22/17 11:02 AM
12/22/17 11:02 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
It'll go back in, just be careful. My china cherry picker came pre-filled with oil. In fact I've never had any hydraulic cylinder that I had to add oil too unless it leaked out.
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: RoadRunner] #2422268
12/22/17 11:31 AM
12/22/17 11:31 AM
Unfortunately back in New York
N
Nukechargerboy Offline
N
Rivitron! I had that too!
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2422283
12/22/17 12:35 PM
12/22/17 12:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
This may sound funny but try twisting (screwing) it back in rather than pushing straight on it.
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: Nukechargerboy] #2422284
12/22/17 12:36 PM
12/22/17 12:36 PM
nj
MoJoe Offline
MoJoe  Offline
nj
I've used the sharpened point of a wooden pencil to plug holes in quite a few situations like that. Cut it about a 1" for easy handling
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MoJoe] #2422322
12/22/17 02:06 PM
12/22/17 02:06 PM
moparx Offline
moparx  Offline
iagree wipe the area around the hole, and let the graphite in the pencil lead work.
beer
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2422337
12/22/17 02:52 PM
12/22/17 02:52 PM
SoCal
SoCal
Interesting pencil tricks. Thanks!
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2422600
12/23/17 08:41 AM
12/23/17 08:41 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I'm not sure the cherry picker I have has had that plug for the last 5 years. A wrap around the ram with electrical tape and it's good to go. laugh2
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2422637
12/23/17 12:25 PM
12/23/17 12:25 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
How about a self tapping screw of the appropriate size with a rubber washer. shruggy
I have mechanical Aptitude.
I can screw up anything.
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: GoodysGotaCuda] #2422715
12/23/17 04:16 PM
12/23/17 04:16 PM
SoCal
SoCal
I like the way you think. work laugh2
