Steering box coupler stuck on steering shaft??? #2422555
12/23/17 02:29 AM
12/23/17 02:29 AM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
Post 73 A body. I pulled the steering column no problem. Coupler came off the box no problem. I want to put a new shoe and seal kit on it. The coupler easily slides back and forth on the end of the steering column shaft but stops just as the shoes are flush with the opening of the coupler. What’s keeping the coupler from coming off? I don’t want to force it off and break the shoes. I just need to put a new seal on it. Thanks.
Re: Steering box coupler stuck on steering shaft??? [Re: da50r] #2422596
12/23/17 07:16 AM
12/23/17 07:16 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Little solid roll pin on the side that you can push outwards with a small 3/8(bolt size) or so inch nut, and creative use of channelocks.
Re: Steering box coupler stuck on steering shaft??? [Re: da50r] #2422603
12/23/17 10:07 AM
12/23/17 10:07 AM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
I don’t understand. The coupler is off the gearbox. The column is out. The roll pin is pushed. The coupler has grease in it and slides back and forth so easy. But it won’t come off the steering colum. It hits an obvious “stop “ just before the shoes are visible.
Re: Steering box coupler stuck on steering shaft??? [Re: da50r] #2422604
12/23/17 10:25 AM
12/23/17 10:25 AM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
I found it. Under the grease and crust. That’s a tiny little roll pin. Thanks.
Re: Steering box coupler stuck on steering shaft??? [Re: da50r] #2422605
12/23/17 10:26 AM
12/23/17 10:26 AM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I was way wrong. Cool! Glad you got it.
Scott
1969 Super Bee, 383/4 speed
Re: Steering box coupler stuck on steering shaft??? [Re: da50r] #2422631
12/23/17 01:13 PM
12/23/17 01:13 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
You really need a factory service manual to put it back together correctly.
Re: Steering box coupler stuck on steering shaft??? [Re: da50r] #2422639
12/23/17 01:34 PM
12/23/17 01:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
You can read the TSB on the couplers at http://www.hamtramck-historical.com/1969-TSB-Index.shtml
It is No. 69-19-4 in the menu & there are 8 pages.
Re: Steering box coupler stuck on steering shaft??? [Re: Alaskan_TA] #2422688
12/23/17 03:48 PM
12/23/17 03:48 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Don't know how stock you want to stay but we would drill the housing and put a grease fitting in.
Re: Steering box coupler stuck on steering shaft??? [Re: SALEM1912] #2422740
12/23/17 06:47 PM
12/23/17 06:47 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Re: Steering box coupler stuck on steering shaft??? [Re: da50r] #2422940
12/24/17 01:07 AM
12/24/17 01:07 AM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
What’s the bail for? I never had a coupler come apart.
Re: Steering box coupler stuck on steering shaft??? [Re: da50r] #2422951
12/24/17 01:38 AM
12/24/17 01:38 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Then you have been very lucky with your rebuilt couplers. The retainer keeps the cover from working loose.
Re: Steering box coupler stuck on steering shaft??? [Re: da50r] #2422952
12/24/17 01:42 AM
12/24/17 01:42 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Chrysler came up with the bail, cause they knew how hard it was to keep the retainer on once it has been removed.
Re: Steering box coupler stuck on steering shaft??? [Re: da50r] #2422968
12/24/17 02:11 AM
12/24/17 02:11 AM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
Interesting
Re: Steering box coupler stuck on steering shaft??? [Re: da50r] #2422972
12/24/17 02:19 AM
12/24/17 02:19 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
This works even better. Get it from Steer and Gear
Abe Lincoln
Re: Steering box coupler stuck on steering shaft??? [Re: da50r] #2422973
12/24/17 02:32 AM
12/24/17 02:32 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Actually the metal bail is the best of the two due to the fact it lasts forever and is entirely reusable and never loosens up.
Re: Steering box coupler stuck on steering shaft??? [Re: da50r] #2423411
12/25/17 02:24 AM
12/25/17 02:24 AM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
I'm not sure if this is the same thing as the bail mentioned but I used this clamp.
https://www.ebay.com/itm/Rare-Mopar-2996935-Steering-Coupler-Retaining-Clamp-most-Dodge-Plymouth/301416193929?hash=item462dce1f89:g:-PcAAOSwj0NUeURR&vxp=mtr
Re: Steering box coupler stuck on steering shaft??? [Re: srunge55] #2424231
12/27/17 01:50 AM
12/27/17 01:50 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
That's actually the exact one I used too, (same thing as the previously shown bail) it took a little effort to install and would say it's not going anywhere up
