Re: bb ootb flow numbers
[Re: ccdave]
#2422574
12/23/17 03:41 AM
12/23/17 03:41 AM
Posts: 4,705 Wichita
GY3
Wichita
Trickflow 240's, cnc ported Eddys and 440Source Stealths all flow really close to the same.
[Re: rbkt65]
#2422576
12/23/17 03:49 AM
12/23/17 03:49 AM
Posts: 43,317 Bend,OR USA
Cab_Burge
Different folks like different results, what is it you want from your car and its "543" motor? I have a set of Victor M.W. ported all the way to the valve seats, I'm not happy with them on my bracket motor in my S/P car. The next motor has a set of CNC ported 440-1 with a set of Jesel paired shaft rockers and a little more compression to race it on E85 ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: rbkt65]
#2423066
12/24/17 01:28 PM
12/24/17 01:28 PM
fast68plymouth
So. Burlington, Vt.
The flow numbers are only one piece of the puzzle when it comes to choosing the correct head for the application.
[Re: fast68plymouth]
#2423135
12/24/17 04:06 PM
12/24/17 04:06 PM
Posts: 4,457 Washington
madscientist
Washington
The flow numbers are only one piece of the puzzle when it comes to choosing the correct head for the application. Yep. All these years and most guys still buy heads based on flow numbers.
