Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2423022
12/24/17 10:13 AM
12/24/17 10:13 AM
Guitar Jones Offline
First, did you try it to see if it works? I've never had to add oil to any cylinder either.
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2423023
12/24/17 10:15 AM
12/24/17 10:15 AM
Originally Posted By MuuMuu101
Originally Posted By GoodysGotaCuda
I'm not sure the cherry picker I have has had that plug for the last 5 years. A wrap around the ram with electrical tape and it's good to go. laugh2
I like the way you think. work laugh2
Duct tape! laugh2
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2423086
12/24/17 02:13 PM
12/24/17 02:13 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I never had to ad oil to my cherry picker but to bottle jacks. The rubber plugs are difficult to get in but I have used a small screw driver to work it in. I have also lost the rubber plug upon removal , bing and it was gone forever. The duct tap method was used and has been on for years.
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2425266
12/29/17 10:21 AM
12/29/17 10:21 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
OMG... runaway
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2425268
12/29/17 10:49 AM
12/29/17 10:49 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Harbor Freight sells an engine support bar, I have used mine for shimming motor mounts, header installs, FWD car timing belt jobs, evn FWD clutch jobs (it can even help put the FWD trans back in while still supporting the eng)
Even my complete front end detail/rebuild.... look Ma "No K frame"
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: UCUDANT] #2425325
12/29/17 01:21 PM
12/29/17 01:21 PM
moparx Offline
moparx  Offline
i whipped up an engine support bar from a chunk of "unistrut", that generic 1 1/2" or so square tube with one open side and all the slotted 1/2" or so holes in the opposing side. works great, is cheap, readily available at almost any hardware store and home improvement centers, and support ends and hooks are easy to come up with. unfortunately, i don't have any pics of it in use.
beer
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: Guitar Jones] #2425362
12/29/17 02:36 PM
12/29/17 02:36 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
Yes I did! Because of that I ended up reading the instructions which states, "Hyrdaulic Oil Not Included."
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2425364
12/29/17 02:38 PM
12/29/17 02:38 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Did the instructions say how to remove and install the rubber plug? LOL
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: mopars4ever] #2425367
12/29/17 02:41 PM
12/29/17 02:41 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Its really not that hard guys. A little lube and push it in.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: mopars4ever] #2425370
12/29/17 02:48 PM
12/29/17 02:48 PM
SoCal
SoCal
The instructions didn't even refer that the plug was the fill hole.
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2426215
12/31/17 05:26 AM
12/31/17 05:26 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
I got hair plugs. Pretty successful. Use the Bosley Method.
I’m listening.
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine [Re: MuuMuu101] #2435975
01/16/18 10:55 PM
01/16/18 10:55 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
I bought the Orange one from Harbor Freight, it had oil in it.
