Page 1 of 4 1 2 3 4
A little science project [[[ updated]]]] #2421848
12/21/17 02:06 PM
12/21/17 02:06 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
Working on both side of the motor
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: A little science project [Re: WHITEDART] #2421853
12/21/17 02:09 PM
12/21/17 02:09 PM
bean town ....Ca
W
W
bean town ....Ca
I guess you could say in and out
Re: A little science project [Re: WHITEDART] #2421871
12/21/17 03:33 PM
12/21/17 03:33 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
What r u up to now Shiloh?
Re: A little science project [Re: WHITEDART] #2421878
12/21/17 03:44 PM
12/21/17 03:44 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Judging by the shoe comparison, I would guess 10 inch wide collectors. LOL
Thanks for sharing and yes, I know they are on a table.
But is the O2 sensor bung in the correct spot?
I thought they were supposed to be half way back in the collector?
Just asking to learn a little more.
MERRY CHRISTMAS.
Old Geezer Racing
Re: A little science project [Re: SCATPACK 1] #2421897
12/21/17 04:43 PM
12/21/17 04:43 PM
bean town ....Ca
W
W
bean town ....Ca
Well I run a 9.6 deck block.. and the 420 intake is for a low deck so I've had to use spacers to make it work.. I cut it in half and shipped it to Brett Miller.. he's going to stretch it I think close to 5/8 of an inch.. it will make the plenum larger in the runner shorter... the idea behind the collector is it has a 3-inch pinch. Versus the 2.5 that I'm running right now.. trying to find a happy medium between acceleration and mph
Re: A little science project [Re: WHITEDART] #2421899
12/21/17 04:48 PM
12/21/17 04:48 PM
I've heard that the merge type collectors are good and others say help grin no good confused
I have seen ET and MPH gains at the track by changing collector length and primary pipe lengths, what are your thoughts and findings?
Re: A little science project [Re: Cab_Burge] #2421906
12/21/17 04:59 PM
12/21/17 04:59 PM
bean town ....Ca
W
W
bean town ....Ca
Well going from a 2.5 pinch to a 4'open collector I seen a 12 horsepower increase on the dyno.. which was a significant find more than any other single change that we made including from small carburetor to Big carburetor.. but the smaller collector accelerates the car so much faster it actually provides a better time slip. Now keep in mind this is on a fairly heavy two speed small block.. mph is definitely down with the smaller collector
Re: A little science project [Re: WHITEDART] #2421909
12/21/17 05:04 PM
12/21/17 05:04 PM
Isn't it amazing what the motor does on the dyno with changes compared to what it does in the car at the track and the different results.
Did you test jet changes to go both leaner and fatter with the smaller collectors? work grin
Your car and your results are great bow up
Keep testing wrench whistling
Re: A little science project [Re: WHITEDART] #2421917
12/21/17 05:14 PM
12/21/17 05:14 PM
bean town ....Ca
W
W
bean town ....Ca
I think what most people miss with collectors is the actual effect that it has on the carburetor.. you could easily need a four or five jet increase or decrease with different collectors.. and what provides more power on the dino isn't always the fastest way down the track
Re: A little science project [Re: WHITEDART] #2421919
12/21/17 05:15 PM
12/21/17 05:15 PM
and what provides more power on the dyno isn't always the fastest way down the track
up You be correct on that one up devil whistling
Re: A little science project [Re: WHITEDART] #2421922
12/21/17 05:18 PM
12/21/17 05:18 PM
bean town ....Ca
W
W
bean town ....Ca
What we're looking at is finding the happy medium.. Greg thought the collector he built before was a little small for what we're trying to do now.. Greg is also the one that chose where to put the bung these collectors are very short and so I think if you moved the bung towards the rear it may pull in clean air.. I will say that there's a possibility with a converter change and gear change I could take advantage of the larger collector.. but some of these science projects can become expensive panic
Re: A little science project [Re: Cab_Burge] #2421924
12/21/17 05:20 PM
12/21/17 05:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It likes the smaller tubes on the primaries to
give you more torque in the lower RPMs due to
the trans... I cut one of those intakes in half
to fit a engine.. it was for testing
wave
Re: A little science project [Re: WHITEDART] #2421935
12/21/17 05:37 PM
12/21/17 05:37 PM
Washington
madscientist Offline
Washington
A three speed would probably help the big collector accelerate as fast or faster than the pinch collector but...as you know it's hard to control all that low gear, especially if you are running leaf springs (which, IIRC you are) so at some point you have to do what you are doing.
As I've always said, if it makes more power in the dyno it SHOULD go faster in the car. Gearing, converter, suspension and shocks can all make an engine with more power go slower.
Re: A little science project [Re: madscientist] #2423349
12/24/17 11:49 PM
12/24/17 11:49 PM
bean town ....Ca
W
W
bean town ....Ca
Intake stretch 2.0.. it made the trip safe and sound and is now in the fixture..
Re: A little science project [Re: WHITEDART] #2423356
12/25/17 12:02 AM
12/25/17 12:02 AM
bean town ....Ca
W
W
bean town ....Ca
the way it used to look with the adapter... this stretch will let the motor see the booster better..
Re: A little science project [Re: WHITEDART] #2425481
12/29/17 07:23 PM
12/29/17 07:23 PM
bean town ....Ca
W
W
bean town ....Ca
Engine development.1o1
Re: A little science project [Re: WHITEDART] #2425487
12/29/17 07:27 PM
12/29/17 07:27 PM
bean town ....Ca
W
W
bean town ....Ca
Now Brett will work his magic.. with this process we enlarge the plenum and shorten the runner..
Re: A little science project [Re: WHITEDART] #2425497
12/29/17 07:38 PM
12/29/17 07:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Bad ass right there......... beer
Re: A little science project [Re: WHITEDART] #2425617
12/30/17 02:32 AM
12/30/17 02:32 AM
Nampa, Idaho
Moparmatts72 Offline
Nampa, Idaho
That's going to turn out awesome, be interesting to see how the engine response to it.
Re: A little science project [Re: WHITEDART] #2425670
12/30/17 05:48 AM
12/30/17 05:48 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Almost All mods Lengthen the runner on the plenum floor for best results on a single plane like that. Yours will want that too. Huge plenum short runners equals slow port velocity. Bad for fuel atomization and cylinder fill. shruggy stirthepot
Page 1 of 4 1 2 3 4
