Pre-oiling my 318 - what tool?? #242184
03/03/09 05:50 PM
03/03/09 05:50 PM
SK, Canada
E
etek Offline OP
etek  Offline OP
E
SK, Canada
Rebuilt my 318 and about to run it up - can't find a tool to pre-oil it. Am I relegated to finding a distributor cam gear in a wrecking yard??? Does Melling sell them? Will a big Hex key work?
Re: Pre-oiling my 318 - what tool?? [Re: etek] #242185
03/03/09 06:18 PM
03/03/09 06:18 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I just cut off the gear from the oil pump shaft and welded a piece of rod to it. Works great.
Re: Pre-oiling my 318 - what tool?? [Re: etek] #242186
03/03/09 06:19 PM
03/03/09 06:19 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
http://chucker54.stores.yahoo.net/oilpumprimsh.html
think they are 5/16 hex shaft or maybe 3/8
Re: Pre-oiling my 318 - what tool?? [Re: burdar] #242187
03/03/09 06:20 PM
03/03/09 06:20 PM
wisconsin
1BAD68 Offline
1BAD68  Offline
wisconsin
I cut an end of a allen wrench/hex key off and welded it to a long drill bit when I did mine. It worked great.
Re: Pre-oiling my 318 - what tool?? [Re: 1BAD68] #242188
03/03/09 06:22 PM
03/03/09 06:22 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
make sure you wrap electrical tape around hex shaft so it does not score bushing!
Re: Pre-oiling my 318 - what tool?? [Re: etek] #242189
03/03/09 06:29 PM
03/03/09 06:29 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Re: Pre-oiling my 318 - what tool?? [Re: etek] #242190
03/03/09 08:12 PM
03/03/09 08:12 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I took a scrap piece of 18" 1/4" steel tubing and ground a hex on the end. I've been using it for over 25 years. Picture to follow, I use it every week to prime my hemis after each rebuid, so it has got a ton of use and still holding up well. Best part it was free.
Re: Pre-oiling my 318 - what tool?? [Re: Challenger 1] #242191
03/03/09 08:19 PM
03/03/09 08:19 PM
unless one of your hardware stores has hex rod that you can run & get as said just take a piece of steel rod & grind a hex on the end. Just use an allen wrench for a template.
