Re: Transmission Swap Input 1973 Charger [Re: cjskotni] #2423115
12/24/17 03:25 PM
12/24/17 03:25 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Can you rebuild a manual trans? If not do you know somebody who can? You can buy the Passion gear set and put it in a stock case to save money.
Re: Transmission Swap Input 1973 Charger [Re: 71birdJ68] #2423385
12/25/17 01:18 AM
12/25/17 01:18 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
iagree I have done a few of these gear conversions and they work very nicely.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Transmission Swap Input 1973 Charger [Re: cjskotni] #2423728
12/25/17 09:07 PM
12/25/17 09:07 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Yeah then I still need the pedals, console, shifter, hump, etc. Not to mention a core which will be hard to find.
If I am going yo have to through the trouble of sourcing all those parts, I think I would want to go with a modern one.
Re: Transmission Swap Input 1973 Charger [Re: cjskotni] #2423758
12/25/17 10:35 PM
12/25/17 10:35 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
But all that stuff was engineered for you 50 years ago, it all just bolts in, even the hump falls in place just to be welded. After the modern stuff if in place let us know, how it turns out.
Re: Transmission Swap Input 1973 Charger [Re: cjskotni] #2424119
12/26/17 10:06 PM
12/26/17 10:06 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
A 4000 lb car with 499 cid and a stick will surely break a 8.75 if it hooks. And 1350 yokes and a rev limiter wouldn't be a bad idea.
Re: Transmission Swap Input 1973 Charger [Re: forphorty] #2424168
12/26/17 11:35 PM
12/26/17 11:35 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
I find that hard to believe with street tires....slicks I will give you but I would think my tires would spin before the rear breaks...
Guess I could be wrong though.
Not sure if I am going to go this route. I was thinking this would be a 5-6K project - not a 8-9k one. :-(
