Page 2 of 3 1 2 3
Re: motor plate questions [Re: Quicktree] #242144
03/04/09 07:26 PM
03/04/09 07:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Clamps.... its a little different Tony, they flex
big time and they are right up against the rearend
via a coupling
Re: motor plate questions [Re: Quicktree] #242145
03/04/09 07:28 PM
03/04/09 07:28 PM
I use a set of old school elephant ears with a solid welded passenger side stock mount. The trans mount is poly. This set up is low buck,strong,and solved my external oil line clearance problem. I run 10.90-11.00 @ about 660 hp.
Re: motor plate questions [Re: MR_P_BODY] #242146
03/04/09 08:26 PM
03/04/09 08:26 PM
Q
Quicktree Offline
Quicktree  Offline
Q
via a coupling
ok lets scale down to a super comp dragster, same deal. they are held on the front by 2 aircraft type water hose clamps and they are not held against the rear end. they do have a coupler but it's loose fit. and with all the flexing you say wouldn't that make it worse? my point is the heavy duty front motor plates are not needed imo.
Re: motor plate questions [Re: Quicktree] #242147
03/04/09 08:34 PM
03/04/09 08:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you wheel stand and run a 1/4" plate and come down
hard.... it WILL buckle.... as me. I stepped up to
a 3/8" plate with limiters
Re: motor plate questions [Re: MR_P_BODY] #242148
03/04/09 08:40 PM
03/04/09 08:40 PM
Q
Quicktree Offline
Quicktree  Offline
Q
so will your oil pan and a whole bunch of other stuff
Re: motor plate questions [Re: Quicktree] #242149
03/04/09 08:49 PM
03/04/09 08:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Fortunately I didnt run a real deep pan back then and
all it hurt was the plate. As soon as I unbolted the
plate the chassis sprung back into place(thank goodness
it was a moly chassis)
Re: motor plate questions [Re: MR_P_BODY] #242150
03/04/09 09:09 PM
03/04/09 09:09 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
If you look closely down by the passenger side shoick tower you will see the limiter. just a mount with a heim on it that bolts to a tab off the bottom of the frame rail
On my coronet i use the stock repop hemi mounts with a limiter that bolts to a mount that i welded up under the battery tray and to two bolt holes on the water pump housing (that go into the block), has heims on both ends (which helps when adjusting the valves to pull motor over to get the valve covers off)
Re: motor plate questions [Re: Quicktree] #242151
03/04/09 09:26 PM
03/04/09 09:26 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
via a coupling
Tony, what exactly is your point? i like the heavier plate because of the 1.cutouts 2. they are made by a member here 3. they are sold by a sponsor here 4. i dont have any extra hose clamps to use as motor mounts
Re: motor plate questions [Re: sixpackgut] #242152
03/04/09 09:43 PM
03/04/09 09:43 PM
Q
Quicktree Offline
Quicktree  Offline
Q
via a coupling
nothing wrong with it, I don't like the triangle cut outs on that one but it's not going to hurt anything. go for it.
Re: motor plate questions [Re: Quicktree] #242153
03/04/09 10:51 PM
03/04/09 10:51 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I don't care for the triangles.These go with my weld wheels.I bought mine from V & V machine in Wappingers Falls NY.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: motor plate questions [Re: hemi-itis] #242154
03/04/09 10:52 PM
03/04/09 10:52 PM
Q
Quicktree Offline
Quicktree  Offline
Q
that looks much better to me, but thats just my opinion.
Re: motor plate questions [Re: Quicktree] #242155
03/05/09 12:02 AM
03/05/09 12:02 AM
Temperance, MI
P
P
Temperance, MI
last i heard from andy he was also offering the motor plates with NO holes so people could do whatever they wanted with them
Re: motor plate questions [Re: sixpackgut] #242156
03/05/09 10:12 AM
03/05/09 10:12 AM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Hey I didn't want to horn in, but Andy has not replied. I can make your motor plate and we will "customize" it for you.(holes, triangles, solid, we can even put a pentestar in it if you want)
PM me if you are interested.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: motor plate questions [Re: nhramark] #242157
03/05/09 12:32 PM
03/05/09 12:32 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I was going to run my limiters from the rear of the trans case to the trans crossmember. I was planning on using the machined locating lugs on the rear sides of the case. It would be out of the way,easy to access.
Doug
Re: motor plate questions [Re: nhramark] #242158
03/05/09 12:50 PM
03/05/09 12:50 PM
Charleston
Charleston
can you post pics of some plates? i would like to see some different ones
Re: motor plate questions [Re: sixpackgut] #242159
03/05/09 10:46 PM
03/05/09 10:46 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Here is a pic of our new 5.7 Hemi 3/8" motorplate.
www.aeicnc.com
Website will be updated soon, click the automotive tab.
Re: motor plate questions [Re: nhramark] #242160
03/05/09 11:04 PM
03/05/09 11:04 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Here's a pic from the other side that I didn't botch while re-sizing.
Re: motor plate questions [Re: nhramark] #242161
03/05/09 11:06 PM
03/05/09 11:06 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
www.aeicnc.com
will you be able to make 1/4 to 3/8 valvecover spacers for bigblock mopars ?
1.39 9.85 - 137 mph
Re: motor plate questions [Re: Ari440] #242162
03/05/09 11:14 PM
03/05/09 11:14 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Sure. We could make those very quickly.
Re: motor plate questions [Re: nhramark] #242163
03/05/09 11:15 PM
03/05/09 11:15 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
THAT WOULD BE NICE , THANK YOU !!! MARK
Im using INDY heads if it makes a diffrence
pm me when you do
Page 2 of 3 1 2 3
