400 block tear down #2419893
12/17/17 03:42 PM
12/17/17 03:42 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Finally got around to tearing the 400 block down that i picked up a few months ago. Everything looked real good, but it had clevite 77 bearings and an aluminum cam gear with pentistar cast in it. Are these factory items or do you think it was rebuilt? Need to get it sonic'd. Should make a good block.
Re: 400 block tear down [Re: mopar dave] #2419914
12/17/17 05:00 PM
12/17/17 05:00 PM
The aluminum cam gear is, the Clevite 77 bearings aren't shruggy
Re: 400 block tear down [Re: mopar dave] #2419964
12/17/17 07:20 PM
12/17/17 07:20 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
You won’t know if it’s a good block till after the block is sonic checked.
Re: 400 block tear down [Re: mopar dave] #2419973
12/17/17 07:50 PM
12/17/17 07:50 PM
AndyF Online content
AndyF  Online Content
Factory bearings are usually Michigan 77. Look close at the bearings and you might see a date stamp. If the date code is there then you'll know when the rebuild happened. Are the bearings standard size? It would seem odd to have the bearings changed but nothing else but maybe a customer had a rod knock so a shop put new bearings in.
Re: 400 block tear down [Re: ccdave] #2419980
12/17/17 08:01 PM
12/17/17 08:01 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
and for a few extra buck's have it checked for cracks also.
Re: 400 block tear down [Re: dartman366] #2420077
12/17/17 11:20 PM
12/17/17 11:20 PM
Mt Morris Michigan
Mt Morris Michigan
not sure on the date, but they do have clevite stamped in them. the nylon teeth on the cam gear are in almost new condition. gonna get it fully checked out and put it away. thanks
