dominator to 4150 2" adapter
#2419977
12/17/17 07:59 PM
12/17/17 07:59 PM
dartman366
Mt. Vernon, Ohio
how much performance do you guys think I could be loosing by having to use the adapter spacer on my box stock Trick Flow manifold on the 512, kinda looks like a bit of a choke point to me,, oh and it has been blended to match the manifold opening.
Re: dominator to 4150 2" adapter
[Re: dartman366]
#2420052
12/17/17 10:37 PM
12/17/17 10:37 PM
Posts: 1,030 ohio
67mprfan
ohio
Bill I've been told it's worth some gains don't remember how much but that's what I was running on my car
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#2420069
12/17/17 11:07 PM
12/17/17 11:07 PM
dartman366
Mt. Vernon, Ohio
Bill I've been told it's worth some gains don't remember how much but that's what I was running on my car Was told that by just about everyone back when I had one on my smallblock, increased plenum volume was the reason they gave,, just wondering if it held true on a larger cid engine that pulls more air.
[Re: dartman366]
#2420071
12/17/17 11:09 PM
12/17/17 11:09 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
It was INDY that was quoting about 12hp gain
1963 Plymouth Max Wedge 1971 Barracuda
[Re: Thumperdart]
#2420339
12/18/17 02:35 PM
12/18/17 02:35 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
My thoughts would be if your engine wants a shorter runner than a big plenum dom flange would be helpful.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: dartman366]
#2420793
12/19/17 03:03 AM
12/19/17 03:03 AM
Posts: 472 Minnesota, USA
humpty
Minnesota, USA
Here's another datapoint: our 451 RB with a set of stage VI heads, decent size roller cam, 1.5 rockers and an HP 950 made 620HP. We replaced the 1.5 rockers with 1.6's, and an 1150 Dominator atop a 2" adapter with some nice blending made 677HP. I remember the dyno operator looked at the adapter and said "that's not going to work". I'd say it didn't hurt!
[Re: humpty]
#2420817
12/19/17 04:01 AM
12/19/17 04:01 AM
Posts: 43,233 Bend,OR USA
Cab_Burge
I have dyno tested two different M1 intakes on the same motor the same day, one 4150 with a 2.0 inch tapered Dominator adapter with a Holley 1050 9375 non HP 1050 CFM carb., swapped the intake to a M1 4500 flange intake with no spacer, the motor lost right at 8 HP, I then added a Wilson 1.5 inch four hole reversion spacer and picked up a little more than 10 HP with no other changes on either test. Adding plenum volume will normally make most BB Mopar motors gain power I've seen the same results on another car at the track that swapped from Team G 4150 intake with a tapered Dominator adapter with a dominator carb. to the same brand, Weiand Team G with a 1.5 inch open spacer and his car went faster with the 4500 type intake and spacer compared to the 4150 intake and tapered adapter with the same carb with no jetting changes
[Re: sasquatch]
#2421220
12/19/17 11:44 PM
12/19/17 11:44 PM
dartman366
Mt. Vernon, Ohio
I have always explained it like this. If eight guys are drinking beer from a keg and you make the keg bigger, eight guys are going to be much happier. Todd Now that's a explanation that I can relate to!LOL sounds like it should be ok for now or untill I can come up with some thing better.
