what year is this 904? An early less splines input shaft? #2416962
12/11/17 08:42 PM
12/11/17 08:42 PM
RapidRobert Offline OP
stamped numbers in the pan rail. 588338Y 2281676 thank you for your time.
Re: what year is this 904? An early less splines input shaft? [Re: RapidRobert] #2417038
12/11/17 10:50 PM
12/11/17 10:50 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
No one is getting much info on transmissions this week, this one is too low for my charts. Sorry.
11B40
Re: what year is this 904? An early less splines input shaft? [Re: JonC] #2417054
12/11/17 11:09 PM
12/11/17 11:09 PM
I'm thinking that it came out of a 65 or 66 dart.
Re: what year is this 904? An early less splines input shaft? [Re: RapidRobert] #2417077
12/12/17 12:01 AM
12/12/17 12:01 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Does it have a flange on the output shaft? I believe 65 was the last year for that, I do know my 65 Cuda has it.
My 65 parts manual has transmission assemblies starting with 24XX XXX. So it's older.
Don't be the exception.
Re: what year is this 904? An early less splines input shaft? [Re: Supercuda] #2417122
12/12/17 01:26 AM
12/12/17 01:26 AM
Supercuda, it is a slip spline yoke/rod linkage
Re: what year is this 904? An early less splines input shaft? [Re: RapidRobert] #2417201
12/12/17 05:15 AM
12/12/17 05:15 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Sounds like 66/7 maybe? They went to the bigger input in 68.
Re: what year is this 904? An early less splines input shaft? [Re: RapidRobert] #2417213
12/12/17 08:01 AM
12/12/17 08:01 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
2281676 but I don't think this is your transmission part number
I think it's 228th transmission on (day 1676 is) Monday, February 28, 1966 shruggy or similar
is it V8 or /6?
looks like:
170
1949550 early '60 Valiant
2204985 late '60-'61 Valiant, Lancer
2464427 '62-'64 Valiant, Dart, Lancer, Barracuda
225
2204987 '61 Valiant, Lancer
2204916 early '62 Valiant, Lancer
2464428 late '62-early '64 Valiant, Dart, Lancer, Barracuda
2466092 late '64 Valiant, Dart, Lancer, Barracuda
Re: what year is this 904? An early less splines input shaft? [Re: RapidRobert] #2417218
12/12/17 08:14 AM
12/12/17 08:14 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
588338Y is this clear? missing a digit? got a pic?
2538338 '66 a-body 273 2bbl
Re: what year is this 904? An early less splines input shaft? [Re: 6bblgt] #2417249
12/12/17 11:30 AM
12/12/17 11:30 AM
it is a SB. I will recheck the #. I am trying to find out if it is the later spline (hopefully yes) so I can order a torque converter.
Re: what year is this 904? An early less splines input shaft? [Re: RapidRobert] #2417268
12/12/17 12:30 PM
12/12/17 12:30 PM
Minn
SportF Offline
SportF  Offline
Minn
I ran into this a couple of years ago when I put a late model converter on a 63 trans. No drive.
When they changed the 727 input in 67, they also changed the 904.
In my case, I replaced the front clutch and pump to allow the newer converter. This is also what is done to update the 727.
Good luck.
Re: what year is this 904? An early less splines input shaft? [Re: SportF] #2417271
12/12/17 12:34 PM
12/12/17 12:34 PM
If it turns out to be an earlier one I likely will go ahead & prep another one that is already partly undone (& I know it is a later one). I kinda have my doubts about the current one as it is (likely) a high mileage OE unit & it is going into a circle burner & will be abused. I will confirm the # when I get over there. thanks guys.
Re: what year is this 904? An early less splines input shaft? [Re: RapidRobert] #2417524
12/12/17 07:15 PM
12/12/17 07:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
588338Y
Probably 2538338 a 904 from a '66 A or B-body with a 273-2.
Re: what year is this 904? An early less splines input shaft? [Re: John_Kunkel] #2417653
12/12/17 11:03 PM
12/12/17 11:03 PM
John you're the man (as always).
