Trick Flow 270 or Edelbrock Victor Max Wedge #2416439
12/10/17 10:03 PM
12/10/17 10:03 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Hi, I could use some advice. I am building a low deck 511 (street/strip car) and was planning on using the TF 270's. Now I have been offered a really good deal on some used MW Victors. I know the Victors require some different rocker arms and headers but I need to get all that anyway. The Victors have been gasket matched and port blended, no other port work. If I go with the Victors I will save myself about $1500. What do you think?
Thanks,
Steve
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: srunge55] #2416459
12/10/17 10:16 PM
12/10/17 10:16 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Do the Victors come with the springs you need to work with your cam?
Will those used heads require a trip to the machine shop prior to installation?
With only that minimal amount of work, if the Victors have the newer style chambers, they will be way down on flow compared to the TF270’s, especially in the low and mid-lifts.
Depending on what you do for rockers, there could be a few hundred $$$$ difference between the two.
I’d look into exactly what the header fitment situation is between the two so you really know what you’re getting into.
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: srunge55] #2416460
12/10/17 10:17 PM
12/10/17 10:17 PM
The Great White North
RAMM Offline
RAMM  Offline
I think you need to talk to CCDave--he has all of the facts, I am missing them. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: fast68plymouth] #2416461
12/10/17 10:18 PM
12/10/17 10:18 PM
RAMM Offline
RAMM  Offline
This is really good advice^^^^^^^^^^^^^^. J.Rob
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: srunge55] #2416466
12/10/17 10:23 PM
12/10/17 10:23 PM
So. Burlington, Vt.
So. Burlington, Vt.
You’re saying you can buy the Victors for about $1000.
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: srunge55] #2416467
12/10/17 10:26 PM
12/10/17 10:26 PM
Be very careful on your decision making when it comes to buying used race parts twocents
I have used a bunch of different heads on my race cars over the years from stock iron 516 on street motors to NHRA legal stock 1963 M.W. heads on my old NHRA A/SA Plymouth Belvedere to Indy 440-1 on bracket motors.
My current bracket S/P car has a set of used Victor M.W. heads on my 505 C.I. 400 block, I raced that motor with a set of Eddy RPM heads that I had MCH CNC port them and then switch the M.W. Victors that winter, mine where M.W. ported all the way to the seats, not like Edlebrock said they sold them out of the box originally confused I wouldn't buy another set of them regardless of price tsk
Buy the good ones once, don't repeat my mistakes on trying to save money by buying and using used race parts tsk , especially heads twocents
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: RAMM] #2416469
12/10/17 10:27 PM
12/10/17 10:27 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I think you will end up with the same money and less headaches in the end if you go the TF 270 route. How much power does it need to make and on what type of fuel?
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: Cab_Burge] #2416471
12/10/17 10:29 PM
12/10/17 10:29 PM
RAMM Offline
RAMM  Offline
So what are you saying Cab? Did the car slow down with the RPM's or what? How did the MW Victors perform? J.Rob
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: RAMM] #2416472
12/10/17 10:33 PM
12/10/17 10:33 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Junk is junk....
Have a great day
Iowan
"obsolete is neat"
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: fast68plymouth] #2416474
12/10/17 10:34 PM
12/10/17 10:34 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Hi Dwayne, I did buy the cam for this project from you (you spec'd it for the TF 270 heads). I was maybe going to give you a call sometime this week for your advice.
I know I will need new springs so I figured about $500 for the springs and machine shop install. These heads have recently been to my machinist for valve work so I'm pretty sure they are good to go except for springs.
I'm planning to use the Hughes offset rockers (part of the deal) and the $900 TTI headers setup for the Victor heads. All this figured in I'm still saving about $1500.
I'm not sure which version of the head they are. I'll need to look into that. I'm not to excited about the low/mid-lift flow especially on the street. I'd like to save some money but if the difference is significant I will stick with the TF 270s.
Thanks,
Steve
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: RAMM] #2416480
12/10/17 10:39 PM
12/10/17 10:39 PM
The Victor M.W. heads didn't pick this car up as much as the Duster did when I switched from the same set of Eddy RPM to the Indy non ported SR M.W. heads on the same motor that flowed 20 CFM more than the RPM did shruggy work The Victors had smaller CC on the heads also so it should have pick that motor up even more with the compression ratio increase confused
Those Victor M.W. heads have not impress me yet down
I'll be trying a new set of the Trick Flow 270 soon, after I use up the current stock of heads I have on hand up
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: fast68plymouth] #2416481
12/10/17 10:39 PM
12/10/17 10:39 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
No not exactly, I get the Victor heads (springs for solid flat, I have solid roller), rockers arms, an e85 Dominator Carb and Indy intake for $2200.
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: srunge55] #2416483
12/10/17 10:42 PM
12/10/17 10:42 PM
So. Burlington, Vt.
So. Burlington, Vt.
If you get a pic of the chambers and post it, I can tell you which version they are.
However, without some reworking, the low/mid lift flow on the first version wasn’t great, and it pretty much just plain sucked on the second.
IMO, some of the $1500 in savings should be spent in improving the flow a bit, if you went the Victor route.
The overall fit and finish of the TF heads are just “nicer”.
Pretty hard to find a good argument against them.
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: Jeremiah] #2416486
12/10/17 10:44 PM
12/10/17 10:44 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
I'm hoping for 650 to 700 HP. This is a street/strip car so I will be using pump gas (92/93 octane).
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: srunge55] #2416523
12/10/17 11:43 PM
12/10/17 11:43 PM
So. Burlington, Vt.
So. Burlington, Vt.
At over 500 cubes, that shouldn’t be too hard really.
As a counterpoint to Cabs story, Todd at Comp Wedge pulled some pretty nicely ported RPM heads(over 300cfm) off of (what I believe was) a 493 with a smallish race roller cam that was in a very well sorted out bracket car(multi time track champion), and replaced them with some Hughes CNC ported MW Victors and the car picked up about 4 tenths as I recall(something like 9.90’s to 9.50’s).
One of the few dyno results I’ve seen from the MW Victors were from Brian at IMM.
As I recall the numbers were pretty good.
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: fast68plymouth] #2416535
12/10/17 11:58 PM
12/10/17 11:58 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Here is a picture
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: srunge55] #2416543
12/11/17 12:06 AM
12/11/17 12:06 AM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Here is everything minus the rocker arms for $2200.
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: srunge55] #2416597
12/11/17 01:38 AM
12/11/17 01:38 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I have the cnc MW victor on a 511 with 11.25 compression. Havent been to the track yet, but not real impressed at this point. I paid $1100 for HS rockers which isnt to far from T&D prices.
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: mopar dave] #2416600
12/11/17 01:45 AM
12/11/17 01:45 AM
RAMM Offline
RAMM  Offline
What was your combo before? J.Rob
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: RAMM] #2416621
12/11/17 02:50 AM
12/11/17 02:50 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I had an Indy headed 408 on pump gas that ran 10.30's with 3300# race weight.
