Page 2 of 3 1 2 3
Re: Standard port RPM/TF vs Standard port Victor-HP gain?i [Re: RAMM] #2416448
12/10/17 10:08 PM
12/10/17 10:08 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Read your posts.
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: ccdave] #2416455
12/10/17 10:12 PM
12/10/17 10:12 PM
The Great White North
RAMM Offline OP
RAMM  Offline OP
[quote=ccdaveYour trying to say that Victor heads are very bad. This is old news. Everyone already knows this who cares. Next.
[/quote]
Well I didn't know this way back when and I wish there were HONEST threads LIKE THIS about them so I would have prevented myself some time/$$$$.
Actually now that I think about it I guess I wouldn't have learned nearly as much because you don't really learn from your successes.
Like Mr.P body said--Don't like the thread don't step in. Move on--next. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Standard port RPM/TF vs Standard port Victor-HP gain?i [Re: ccdave] #2416479
12/10/17 10:39 PM
12/10/17 10:39 PM
jersey
Spaceman Spiff Offline
jersey
Originally Posted By ccdave
Originally Posted By RAMM
[quote=ccdave] troll
I guess I'm a troll for trying to initiate a discussion?
I'm guessing you are a Victor cylinder head owner venting some frustration over your choice. J.Rob
Sometimes I wonder why I even bother. You are right, but in this case I felt compelled to be a little crass. Sometimes people make comments without having all of the facts. When they do I think they should be called out.
I'm calling you out, because it's a fact that not everyone knows about the victors.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: RAMM] #2416482
12/10/17 10:42 PM
12/10/17 10:42 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
There have been quite a few posts highlighting Eldebrock Victor issues and the respective solutions.
Like anything else, it all depends on what you are trying to accomplish. From what we have seen I think we can all agree that OOTB TrickFlow is the best thing going right now and they have everything covered from the RPM's to the Indy EZ line up.
That said my second 511" low deck is getting a set of 440 -1's with a paired rocker setup. Simple and proven.
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: RAMM] #2416635
12/11/17 03:36 AM
12/11/17 03:36 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Like Mr.P body said--Don't like the thread don't step in. Move on--next. J.Rob [/quote]
So your telling me that you being the engine master, the master of all things Mopar, the king of telling people how it should have been done just found out by viewing this thread that the Victor heads have some design flaws??
Time for some ice fishing and some pond hockey. Take a break lock
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: RAMM] #2416706
12/11/17 12:08 PM
12/11/17 12:08 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Actually ccdave, you should probably take some of your own advice.
Getting old just means you were smarter than some and luckier than others.
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: dannysbee] #2416711
12/11/17 12:23 PM
12/11/17 12:23 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Danny,
Not good on skates and the ice is not out on the lakes here in Michigan. I do enjoy Ice fishing however. Thanks for your input up
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: fast68plymouth] #2416770
12/11/17 02:29 PM
12/11/17 02:29 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By fast68plymouth
Originally Posted By WO23Coronet
What kind of cfm do porters get out of the std port heads? I know that’s not the end all be all but it’s a pretty good indicator
The highest I’ve seen from a “true” std port head is around 350cfm........and that’s been with the Victor/Pro Comp heads.
I haven’t done one in a long time, but I’ve had std port SR’s flowing in the 340’s.
Actually, now that I think about it, I had some nicely ported std port EZ’s in the shop, done by Hughes, that had the transition in the roof filled in, and those went about 350 as well.
This is an older post that is should be relevant to the question above, if the OP is asking about standard-port Victors.
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/1955306
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: BradH] #2416789
12/11/17 03:31 PM
12/11/17 03:31 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I think JohnRR's Chapman VI's also went right at 350 peak too and with better .200-.600's (from Fast's bench) than any other standard ports I can remember. I think below .350 or so they were even better than my MW 285's. Wish I'd have known when he was selling those...and those numbers were more than 12 years ago. I was thinking at the time....300 cfm at only .450 lift is pretty amazing if you think about it, even a stock replacement Mr sixpack cam in a 10:1 440 would make some serious power and have 14" at idle and a still streetable .557 or .590 purple shaft in a hot 470 would be killer with those .500-.600 numbers.
from the Tech archives:
Chapman CNC'd MP Stage VI 260cc's:
Lift" I/E
.100--71.5/58.2
.200-150.0/118.6
.300-219.4/180.0
.400-278.7/219.4
.500-323.6/233.9
.550-338.9/240.3
.600-352.3/243.5
.650-348.5/246.7
.700-348.5/249.9
.750-348.5/251.5
.800-348.5/253.1
WIZE
In Car:
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: ccdave] #2416826
12/11/17 04:43 PM
12/11/17 04:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Danny,
Remember Dave, if no one agrees w/you, you are WRONG and sent to your room w/out dinner........lmao......Or, they will pm each other about you like in high school........... tsk I'm never right so we're good to go here............ penguin
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: Streetwize] #2416874
12/11/17 06:07 PM
12/11/17 06:07 PM
BradH Offline
BradH  Offline
Lift" I/E
.100--71.5/58.2
.200-150.0/118.6
.300-219.4/180.0
.400-278.7/219.4
.500-323.6/233.9
.550-338.9/240.3
.600-352.3/243.5
.650-348.5/246.7
.700-348.5/249.9
.750-348.5/251.5
.800-348.5/253.1
I'm sorry... can't help it... must... post... more... cylinder... head... data... wink
MP (Mopar Performance) Stage VI heads vs Edelbrock Victors (both prepped & ported significantly from "as cast"):
-------------------- MP --- EV
Intake valve ------ 2.14 - 2.20
Exhaust valve ----- 1.81 - 1.81
Intake runner cc -- 245* - 294
Intake Avg CSA ---- 2.39 - 2.76
Intake Min CSA ---- ~2.2 - 2.66
* Includes volume from intake spacers required to use on RB block (440)
III. Flow data from same Saenz 600-class bench tested on 4.375" fixture:
INTAKE - MP --- EV --- Delta
0.100 -- 69 --- 75 ---- 6
0.200 -- 143 -- 151 --- 8
0.300 -- 213 -- 220 --- 7
0.400 -- 262 -- 280 --- 18
0.500 -- 293 -- 326 --- 33
0.550 -- 305 -- 338 --- 33
0.600 -- 307 -- 346 --- 39
0.650 -- 307 -- 350 --- 43
0.700 -- 307 -- 355 --- 48
0.750 -- N/A -- 347**
EXHAUST - MP -- EV --- Delta -- EV w/ 2" pipe added
0.100 -- 52 --- 55 --- 2
0.200 -- 108 -- 116 -- 8
0.300 -- 146 -- 155 -- 9
0.400 -- 181 -- 194 -- 13
0.500 -- 211 -- 223 -- 12 ----- 238
0.550 -- 222 -- 233 -- 11 ----- 249
0.600 -- 231 -- 241 -- 10 ----- 259
0.650 -- 237 -- 247 -- 10 ----- 267
0.700 -- 243 -- 252 -- 9 ------ 274
0.750 -- 255 -- N/A ---N/A ---- 278
** Drop-off above .700" is suspected of being due to the chambers' CNC work laying back the plug-side wall too much. The same drop-off resulted when tested at 15" / 28" / 35" H20, yet without any change to relative flow #s for each depression level. A hand-ported casting that was used as a flow bench "guinea pig" didn't have the chamber pulled back as much as the CNC'd chamber program, and it did NOT have the same issue w/ dropping off at .700".
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: Thumperdart] #2417099
12/12/17 12:55 AM
12/12/17 12:55 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Danny,
I don't have any buddies here but I do get tired of assholes egos running contributing members off.
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: dannysbee] #2417105
12/12/17 01:01 AM
12/12/17 01:01 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Yes, me too. I’m glade we agree on something up
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: RAMM] #2417211
12/12/17 07:44 AM
12/12/17 07:44 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
they "copy" iron heads to cast them in aluminum,
they copy rpm heads, they copy Victor heads,
why the hell is nobody copying these Chapman heads????
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: Den300] #2417315
12/12/17 01:35 PM
12/12/17 01:35 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
or the Brewer heads!
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: CTD5.9] #2417327
12/12/17 01:52 PM
12/12/17 01:52 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Because there wouldn't be enough market for them to cover the costs
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: RAMM] #2417328
12/12/17 01:54 PM
12/12/17 01:54 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
These arent from Brads stage 6's, but a set of the same vintage....... ootb with Ferrea 2.14/1.81 valves:
Lift--------in/ex
.100---67.4/52.3
.200--126.3/108.5
.300--181.3/137.7
.400--215.0/144.8
.500--235.0/149.1
.550--236.9/149.1
.600--238.8/149.1
.650--240.8/149.1
.700--242.7/149.1
Ootb second gen Victor(the ones with the bowls cast .300 too small, like what Brads were):
Lift-------in/ex
.100---64.2/51.0
.200--126.1/104.1
.300--183.4/143.8
.400--238.8/174.8
.500--281.6/176.0
.550--297.4/176.0
.600--311.8/176.0
.650--302.4/176.0
.700--308.7/176.0
Just some numbers to give you an idea of the starting point for using either of those heads.
And for something else to compare to.....
Ootb Indy SR std port:
Lift--------in/ex
.100---69.0/54.1
.200--132.9/99.2
.300--189.5/135.1
.400--236.2/165.4
.500--264.6/188.9
.550--272.9/196.7
.600--279.7/203.2
.650--284.2/208.1
.700--287.2/212.0
Pro Comp "Victor", std port, valve job and back cut valve, no porting(intake test only):
Lift-----in
.100---71.9
.200--147.6
.300--204.2
.400--255.1
.500--289.1
.550--295.5
.600--304.2
.650--309.9
.700--309.9
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: Den300] #2417359
12/12/17 02:39 PM
12/12/17 02:39 PM
AndyF Offline
AndyF  Offline
I've often wondered that myself. It seems the folks at ProComp and other such places aren't smart enough to design their own heads so they copy existing heads. Okay, I get the fact that they aren't smart enough to design new stuff but why don't they copy the good stuff?
Even if they aren't smart enough know good from bad aren't they smart enough to hire someone to help them? If they are too dumb to hire someone to help them then how do they stay in business at all? Just one of the mysteries of life...........
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: dannysbee] #2417363
12/12/17 02:47 PM
12/12/17 02:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Danny,
So r u referring to me........... work
Re: Standard port RPM/TF vs Standard port Victor-HP gain? [Re: AndyF] #2417367
12/12/17 03:01 PM
12/12/17 03:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
These guys are looking at what moves off the shelf fast
(not what is good).. they are selling mass (or trying)
wave
EDIT
there is probably no more than about 5 or 6 people that
even work there and I doubt they have any design engineers
working there
Page 2 of 3 1 2 3
