727 Rear Clutch Upgrade worth it? #2415489
12/08/17 11:15 PM
12/08/17 11:15 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Is it worth going to the more robust belleville washer and matching piston used in the later 727 rear clutch drums? Is the earlier, thinner cross sectioned ones problematic? My trans is a '73 so it has the thinner belleville...Im just using a Cheetah reverse pattern valve body so no sky high line presures. 600 hp approx... This is my first transmission job, so im a little in the dark...(pic from another thread on here)
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2415638
12/09/17 09:51 AM
12/09/17 09:51 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We've used the thinner, pre '74 washer in the trans with no issues. Usually lives behind a 655, or a 572 motor when the reserve motor steps in.
HTH's up
Re: 727 Rear Clutch Upgrade worth it? [Re: Tig] #2415641
12/09/17 10:21 AM
12/09/17 10:21 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Thanks Tig!
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2415665
12/09/17 12:06 PM
12/09/17 12:06 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Same here. I use the early one behind my 572 and Dizusters turbo motor. Never had a problem. Just make sure which ever spring you use it matches the correct piston.
Doug
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2415684
12/09/17 12:46 PM
12/09/17 12:46 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I would upgrade while you have it apart. There are a couple of factors at work. The wave spring allows fore and aft movement, which effectively increases piston travel irrespective of clutch retainer clearance. Not all piston retainer to clutch retainer fit, is the same. The looser the fit, the worse the problem of excessive piston travel and consequential over centering of the spring. If you have a good selection of oem, and aftermarket snap rings, you will find that a combination of 2, will replace the wave spring nicely.
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2415766
12/09/17 04:10 PM
12/09/17 04:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The early Belleville works OK when it's new but will fatigue with use and weaken more than the later one. HP has nothing to do with failures, line pressure kills them. Even if they don't break, the early ones can flex enough to allow the piston to pop out of its bore...very common failure.
I've seen a bunch of the early ones fail but never the later one. A worthwhile upgrade IMO.
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2415774
12/09/17 04:41 PM
12/09/17 04:41 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
I have used both style Springs. The only one I have ever had break was the thin style.
Re: 727 Rear Clutch Upgrade worth it? [Re: cl440] #2415926
12/09/17 10:22 PM
12/09/17 10:22 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Thanks a bunch guys. Sounds like with the line pressures Ill be running Id be fine. But with wanting to buy a new belleville anyway, Ill just get the new style with the newer piston. Cheap upgrade.
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2416094
12/10/17 09:01 AM
12/10/17 09:01 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Good Info up
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2416328
12/10/17 05:43 PM
12/10/17 05:43 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Andrews racing transmission, forward clutch video:
https://www.youtube.com/watch?v=eJsRtPhlwoA&t=9s
Re: 727 Rear Clutch Upgrade worth it? [Re: 451Mopar] #2416447
12/10/17 10:07 PM
12/10/17 10:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The video claims the early piston isn't any different than the late; I've found, by actual measuring, the late piston is taller. The casting number 2124834 ('62-'73) is .783" thick and the 3743623 ('74-later) is .830".
Re: 727 Rear Clutch Upgrade worth it? [Re: John_Kunkel] #2418649
12/14/17 08:25 PM
12/14/17 08:25 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Just picked one up. Casting number 3743623AB. Measures .782 thick. Maybe the "AB" is a revision?
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2418656
12/14/17 08:39 PM
12/14/17 08:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Most anytime you have letters following the numbers its
been upgraded and on yours with a AB it was down a
couple times
wave
Re: 727 Rear Clutch Upgrade worth it? [Re: MR_P_BODY] #2418704
12/14/17 09:51 PM
12/14/17 09:51 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
couple times
wave
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2418709
12/14/17 09:55 PM
12/14/17 09:55 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
In looking at both the pre '74 and 74up I see no differences between THESE two. The only small difference is a .060ish chamfer on the bore of the newer one. That's it.
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2418763
12/14/17 11:49 PM
12/14/17 11:49 PM
A727Tflite Offline
A727Tflite  Offline
Lay each on a flat surface and measure up to the OD of the piston.
Or take a mic and measure the top of that OD to the backside of the piston - on the back you will see a machined ridge, measure to it.
The piston rests on this ridge when in the clutch retainer. The inner bore does nothing In regards to the Belleville spring.
Re: 727 Rear Clutch Upgrade worth it? [Re: A727Tflite] #2418791
12/15/17 12:46 AM
12/15/17 12:46 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Not sure what you mean Transman....heres a couple more comparason pics..
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2418797
12/15/17 12:52 AM
12/15/17 12:52 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Unless you mean overall height..
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2418798
12/15/17 12:53 AM
12/15/17 12:53 AM
A727Tflite Offline
A727Tflite  Offline
I just saw your last photo. - yes - depending how you measure.
Thickness is different - as long as you measure correctly using the machined register on the bottom of the piston ( the machined radial ridge ) to the top of the outer rim of the piston. EDIT- The way you are measuring in the last photo should show the different thicknesses between the two p/n's.
Re: 727 Rear Clutch Upgrade worth it? [Re: A727Tflite] #2418809
12/15/17 01:16 AM
12/15/17 01:16 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
part numbers 623 and 834
