Re: converting master cylinder [Re: DoctorDiff] #241576
03/05/09 07:48 PM
03/05/09 07:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
OEM 2-bolt aluminum master cylinders with plastic reservoir:
'95 Lebaron 7/8" bore**
'89 Dakota 15/16" bore**
'85 Diplomat (F-body) 1 1/32" bore*
'85 D-150 1 1/8" bore*
**Back of piston must be bored to accept manual brake push rod and retainer.
* Back of piston will accept manual brake push rod and retainer.
Rule of thumb:
1. Master cylinder piston size is relative to caliper piston size. Large caliper pistons require large MC piston.
2. All things equal, smaller bore master = higher line pressure and longer, softer pedal stroke.
Thanks, I didnt know what size the different body
lines used
Re: converting master cylinder [Re: MR_P_BODY] #241577
03/05/09 08:12 PM
03/05/09 08:12 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
That is why I use the big bore.If you use a lot of braided line the pedal will fill like a soft grapefruit.
Re: converting master cylinder [Re: 8secDart] #241578
03/05/09 08:23 PM
03/05/09 08:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the braided for the whole set up and it has a
little softness but not much... not worth my changing it
Re: converting master cylinder [Re: MR_P_BODY] #241579
03/05/09 08:28 PM
03/05/09 08:28 PM
8secDart Offline
8secDart  Offline
It will have a hole lot of softness in a 3,800lbs car.I learned the hard way.
Re: converting master cylinder [Re: MR_P_BODY] #241580
03/05/09 10:43 PM
03/05/09 10:43 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
Just to clarify:
The 85 diplomat is a "M" body no??
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!) 03 Mach1
Re: converting master cylinder [Re: tilt] #241581
03/05/09 11:56 PM
03/05/09 11:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just to clarify:
yes
Re: converting master cylinder [Re: MR_P_BODY] #241582
03/06/09 12:05 AM
03/06/09 12:05 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Just to clarify:
yes
Re: converting master cylinder [Re: Sport440] #241583
03/06/09 05:49 AM
03/06/09 05:49 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
thanks--looks like the D150 is the way to go
Re: converting master cylinder [Re: 493_DART] #241584
03/06/09 07:35 AM
03/06/09 07:35 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If you have stock, manual brakes, a 1 1/8" bore master will result in a hard pedal with low line pressure. The Diplomat master is usually a better choice.
Re: converting master cylinder [Re: DoctorDiff] #241585
03/07/09 04:20 AM
03/07/09 04:20 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
i think id rather have a stiffer pedal than a softer feel--i hate squishy brakes with long travel...
Re: converting master cylinder [Re: 493_DART] #241586
03/07/09 09:46 AM
03/07/09 09:46 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
MC bore size is relative to caliper bore size.
Why would you have squishy brakes with a long pedal travel?
Are you running aftermarket brakes with larger than stock caliper pistons?
Re: converting master cylinder [Re: DoctorDiff] #241587
03/07/09 05:03 PM
03/07/09 05:03 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
i was assuming ...
my factory brakes seem a little stiff/ not a lot of travel. they feel fine to me
Re: converting master cylinder [Re: 493_DART] #241588
03/07/09 06:01 PM
03/07/09 06:01 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes, your stock brakes have a 1 1/32" bore master, the same size as the Diplomat aluminum master.
If you switch to a truck 1 1/8" bore master, you will probably have a rock hard pedal, low line pressure and minimal stopping power.
Re: converting master cylinder [Re: DoctorDiff] #241589
03/08/09 04:07 AM
03/08/09 04:07 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
ok--
thanks Doc !
