Re: 727 Rear Clutch Upgrade worth it?
[Re: Hot 340]
#2415638
12/09/17 09:51 AM
12/09/17 09:51 AM
Posts: 2,915 A shed in England
Tig
A shed in England
We've used the thinner, pre '74 washer in the trans with no issues. Usually lives behind a 655, or a 572 motor when the reserve motor steps in. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#2415641
12/09/17 10:21 AM
12/09/17 10:21 AM
Posts: 3,395 Pa
Hot 340
Pa
[Re: Hot 340]
#2415684
12/09/17 12:46 PM
12/09/17 12:46 PM
Posts: 5,989 Anoka County, MN
Leigh
Anoka County, MN
I would upgrade while you have it apart. There are a couple of factors at work. The wave spring allows fore and aft movement, which effectively increases piston travel irrespective of clutch retainer clearance. Not all piston retainer to clutch retainer fit, is the same. The looser the fit, the worse the problem of excessive piston travel and consequential over centering of the spring. If you have a good selection of oem, and aftermarket snap rings, you will find that a combination of 2, will replace the wave spring nicely.
[Re: Hot 340]
#2415766
12/09/17 04:10 PM
12/09/17 04:10 PM
Posts: 25,783 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The early Belleville works OK when it's new but will fatigue with use and weaken more than the later one. HP has nothing to do with failures, line pressure kills them. Even if they don't break, the early ones can flex enough to allow the piston to pop out of its bore...very common failure.
I've seen a bunch of the early ones fail but never the later one. A worthwhile upgrade IMO.
[Re: Hot 340]
#2416094
12/10/17 09:01 AM
12/10/17 09:01 AM
Tig
A shed in England
Good Info
[Re: 451Mopar]
#2416447
12/10/17 10:07 PM
12/10/17 10:07 PM
John_Kunkel
Rio Linda, CA
The video claims the early piston isn't any different than the late; I've found, by actual measuring, the late piston is taller. The casting number 2124834 ('62-'73) is .783" thick and the 3743623 ('74-later) is .830".
[Re: Hot 340]
#2418656
12/14/17 08:39 PM
12/14/17 08:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Just picked one up. Casting number 3743623AB. Measures .782 thick. Maybe the "AB" is a revision? Most anytime you have letters following the numbers its been upgraded and on yours with a AB it was down a couple times
[Re: MR_P_BODY]
#2418704
12/14/17 09:51 PM
12/14/17 09:51 PM
Posts: 3,395 Pa
Hot 340
Pa
Just picked one up. Casting number 3743623AB. Measures .782 thick. Maybe the "AB" is a revision? Most anytime you have letters following the numbers its been upgraded and on yours with a AB it was down a couple times 👍
[Re: Hot 340]
#2418798
12/15/17 12:53 AM
12/15/17 12:53 AM
Posts: 3,073 Michigan
A727Tflite
I just saw your last photo. - yes - depending how you measure. Thickness is different - as long as you measure correctly using the machined register on the bottom of the piston ( the machined radial ridge ) to the top of the outer rim of the piston. EDIT- The way you are measuring in the last photo should show the different thicknesses between the two p/n's.
[Re: A727Tflite]
#2418809
12/15/17 01:16 AM
12/15/17 01:16 AM
Posts: 3,395 Pa
Hot 340
Pa
part numbers 623 and 834
[Re: Hot 340]
#2418810
12/15/17 01:20 AM
12/15/17 01:20 AM
A727Tflite
Too cold for me to go to the garage again and I don't want to get snow on my pink slippers but .623 sounds pretty skinny. EDIT - sorry - thought that was your measurement. Mayberry I should have enlarged your image of the mic. 👀
[Re: A727Tflite]
#2418811
12/15/17 01:23 AM
12/15/17 01:23 AM
Posts: 3,395 Pa
Hot 340
Pa
Too cold for me to go to the garage again and I don't want to get snow on my pink slippers but .623 sounds pretty skinny. Stay warm. Those two numbers 623 and 824 are the last 3 numbers in the part numbers. The thickness of both are around .785ish.
[Re: A727Tflite]
#2418916
12/15/17 11:22 AM
12/15/17 11:22 AM
Posts: 3,395 Pa
Hot 340
Pa
Only explanation I can come up with is Kokomo machined the late casting to the early spec. Maybe they ran out of service parts for the early application - stranger things have happened there. I can image. I bought a dirt cheap, new old stock A1 Transmission hp rebuild kit the other day because it has the solid front red band, but it also has a brand new, early bellville in it. Temping to just use it.
[Re: Hot 340]
#2419110
12/15/17 05:49 PM
12/15/17 05:49 PM
John_Kunkel
Rio Linda, CA
From the factory TF Service Bulletin, running changes for the '74 model year:
"Neutral to Drive shift quality
A-727 only
The N-D package for the A-727 also required the following changes in the rear clutch. The Belleville spring has a higher load and a reduced cone height and thickness. In the clutch retainer, the Belleville spring seat and cushion ring groove were moved forward. The over-all height of the piston was also increased. The piston and Belleville will not service prior models. The clutch retainer will service prior models."
[Re: John_Kunkel]
#2419131
12/15/17 06:51 PM
12/15/17 06:51 PM
Posts: 3,395 Pa
Hot 340
Pa
A-727 only
John, I believe you. And I believe my measuring tools as well..
[Re: Hot 340]
#2419139
12/15/17 07:10 PM
12/15/17 07:10 PM
MR_P_BODY
Take both parts back to your supplier shop and see if you got a bad part.. sounds like both parts are the same
[Re: MR_P_BODY]
#2419173
12/15/17 08:54 PM
12/15/17 08:54 PM
Posts: 3,395 Pa
Hot 340
Pa
Take both parts back to your supplier shop and see if you got a bad part.. sounds like both parts are the same Just gonna mail it back to the ebay seller.They're a trans parts dealer...they can measure it.😂
[Re: FurryStump]
#2419180
12/15/17 09:11 PM
12/15/17 09:11 PM
Leigh
Anoka County, MN
I have found a couple sources for the later belleville spring anyone have a source for the later piston? Cancelled part#. Used, is your best bet.
[Re: John_Kunkel]
#2419190
12/15/17 09:29 PM
12/15/17 09:29 PM
Posts: 3,395 Pa
Hot 340
Pa
A-727 only
Moving forward with the discussion on this upgrade...per John's post of the service bulletin, Do I need to do somthing to the piston retainer as there appears to be changes made there as well for the '74-up parts. How about the plastic cushion spacer? Is it the same or do I need 74-up specific one?
[Re: Hot 340]
#2419204
12/15/17 10:03 PM
12/15/17 10:03 PM
A727Tflite
We went from metal to plastic on the spacer, they are interchangeable. The piston retainer is the part with the clutch splines, also called a rear clutch piston support. I don't recall a change to it in 74. The clutch retainer is what fits around the piston support and that is what had the groove location change made to it in 74. As the bulletin states it is interchangeable. If you can - you might try to add another snap ring to the one just up from the spacer, it makes the retainer tight to the support if you find yours is sloppy.
As for the retainer - a retainer out of a 46/47/48 will fit the 727.
