360 leaks water from lower timing cover bolt #2413452
12/05/17 03:47 AM
12/05/17 03:47 AM
Toledo, Ohio
70FJ5383 Offline OP
70FJ5383  Offline OP
Toledo, Ohio
Bottom bolt on the left hand side of the timing cover. Just above the oil pan. It just started leaking the other day, antifreeze from around that bolt or maybe the gasket but I think it’s around the bolt. Does it go through into the water jacket? If so will silicone fix it?
Re: 360 leaks water from lower timing cover bolt [Re: 70FJ5383] #2413459
12/05/17 04:52 AM
12/05/17 04:52 AM
P
Porter67 Offline
Porter67  Offline
P
Yes it goes through, id just drain it while its hot so it self dries and use a good sealer on the bolt. I like the dark thick airplane gasket goop or simple rtv.
But it seems you know the deal already.
Re: 360 leaks water from lower timing cover bolt [Re: 70FJ5383] #2413468
12/05/17 07:35 AM
12/05/17 07:35 AM
Toledo, Ohio
70FJ5383 Offline OP
70FJ5383  Offline OP
Toledo, Ohio
Wasn’t sure. And if rtv was ok.
Re: 360 leaks water from lower timing cover bolt [Re: 70FJ5383] #2413488
12/05/17 10:54 AM
12/05/17 10:54 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I would not use RTV, Teflon tape is better. It will seal and it will keep the bolt from corroding itself solid tot he block.
Don't be the exception.
Re: 360 leaks water from lower timing cover bolt [Re: Supercuda] #2413496
12/05/17 11:11 AM
12/05/17 11:11 AM
X2, I would use some thick cement like permatex #2 or Indian head shellac.
Re: 360 leaks water from lower timing cover bolt [Re: Supercuda] #2413529
12/05/17 12:56 PM
12/05/17 12:56 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
X2 . . . teflon tape the bolt . . .
Re: 360 leaks water from lower timing cover bolt [Re: a12rag] #2413665
12/05/17 05:12 PM
12/05/17 05:12 PM
dogdays Offline
dogdays  Offline
RTV won't stick to a wet surface. The non-hardening Permatex (stinky, in a small tube)is good and really all old timers used back in the day. Gasket shellac isn't meant for that use.
Teflon tape or paste will work. Hylomar blue works. FelPro TIGHT is both a sealer and locker.
Or you could put a little stop-leak in the radiator and it'll stop leaking, without disassembly.
R.
PS: I vote for Stop-leak. BTW, that isn't the worst thing you can do from the front of the engine. It is possible to use a bolt long enough that it penetrates the cylinder wall.
Re: 360 leaks water from lower timing cover bolt [Re: 70FJ5383] #2413954
12/06/17 12:24 AM
12/06/17 12:24 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
The lowest bolt does not go through to water. the second from the bottom is the one that is through to coolant. Probably running down and looks like it is dripping from the lowest bolt. Same thing on other side, except that bolt is behind the water pump.
Re: 360 leaks water from lower timing cover bolt [Re: 70FJ5383] #2413968
12/06/17 12:35 AM
12/06/17 12:35 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I prefer to seal straight threads with silicone.
Re: 360 leaks water from lower timing cover bolt [Re: 70FJ5383] #2414070
12/06/17 08:18 AM
12/06/17 08:18 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Liquid Teflon sealer will seal threads with no issue. Brand X uses it on head bolts that go into the water jacket. There may be a bigger issue. The timing cover may be corroded or the timing cover gasket split. This can allow coolant to migrate from the water pump passage out the bolt. It may also allow coolant to get into the oil.
Doug
Re: 360 leaks water from lower timing cover bolt [Re: dvw] #2414147
12/06/17 12:58 PM
12/06/17 12:58 PM
Agreed (on the leak potentially being nearby). I would drain the coolant & screw in an NPT "tank valve" (less than $3 at O'reillys) into the cooling temp sensor port at the top rear of the block & with shop air pump it up to 15 lbs & see if it holds. You can spray a soapy water solution around potential areas to see if it starts to bubble (for external leaks) & there is a "bubble up" (iirc) solution that reportedly bubbles more readily but the dish soap in some water has worked for me. EDIT on second thought I would pump it up to just 10 for a start.
Re: 360 leaks water from lower timing cover bolt [Re: dvw] #2415229
12/08/17 02:12 PM
12/08/17 02:12 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Have same problem with bolt above timing tab, went to tighten it and it just spins....threads in timing cover must be stripped..has anyone put a heli coil in the timing cover still on the engine before or do i have to remove it ?
Re: 360 leaks water from lower timing cover bolt [Re: 70FJ5383] #2415246
12/08/17 02:47 PM
12/08/17 02:47 PM
P
Paul_Fancsali Offline
P
Drain block and coat bolt with sealer let it set overnight and then add anti freeze Do do this if you cannot maintain at least 50+ degree if sealer is silicone
Re: 360 leaks water from lower timing cover bolt [Re: 70FJ5383] #2415401
12/08/17 08:40 PM
12/08/17 08:40 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
One more thing to think about, the cover is aluminum, block cast iron. Electrolysis. Over time the cover corrodes, I've replaced a few because of this problem. What looks like a leak around a bolt turns out to be a tc cover. A bad sign? Moisture in the oil. Look at it good, water will travel far from where it actually leaks. Other than a messed up gasket, bad cover is the only time I had a leak.
Re: 360 leaks water from lower timing cover bolt [Re: Joesixpack] #2415422
12/08/17 09:31 PM
12/08/17 09:31 PM
Which bolt (hole) in particular is that?
Re: 360 leaks water from lower timing cover bolt [Re: RapidRobert] #2416161
12/10/17 01:51 PM
12/10/17 01:51 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
lower right hand corner of water pump. attaches water pump to timing cover.
Re: 360 leaks water from lower timing cover bolt [Re: Joesixpack] #2416940
12/11/17 08:22 PM
12/11/17 08:22 PM
those lower threads on the aluminum timing cover are a weak 11/16" deep & open on the back side & go directly into the timing chain area/eng oil & it uses a 3/8 bolt so I'm thinking if you could block the very back with something fairly firm just to temporarily plug the rear end of that passage for your work then drill/tap a good amount of the threads then carefully/lightly blow the chips out the front (the critical part) & I would use brake kleen as opposed to shop air & either helicoil or just drill/metric tap to the next larger metric size/use a metric bolt. Use grease on the tap to catch alot of debris. EDIT Another option might be to permanently JB weld a stud in there
Re: 360 leaks water from lower timing cover bolt [Re: RapidRobert] #2418177
12/13/17 09:55 PM
12/13/17 09:55 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Yea i figured as much, just bought a used timing cover, will heli coil all the threads in it first and just replace the cover.
Re: 360 leaks water from lower timing cover bolt [Re: Joesixpack] #2419811
12/17/17 12:52 PM
12/17/17 12:52 PM
I wouldn't think you would need to go to all that trouble (helicoiling undamaged threads). I think the one thread just went bad (they are aluminum) & after this you will be OK. Just me I'd clean em (& the bolts) & use some sealer & call it good.
Re: 360 leaks water from lower timing cover bolt [Re: 70FJ5383] #2419835
12/17/17 01:30 PM
12/17/17 01:30 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Putting in helicoils in a timing cover on the bench isn't a lot of effort. doing it while the timing cover is installed in the vehicle is another story.
