Original headlights #2412236
12/02/17 02:10 PM
12/02/17 02:10 PM
Monroe, LA USA
Carsavior Offline OP
Monroe, LA USA
Did all of the muscle era Mopars use GE headlights? And is there a way to identify the general era a GE headlight was produced?
Re: Original headlights [Re: Carsavior] #2412304
12/02/17 05:19 PM
12/02/17 05:19 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've heard Westinghouse was also a vendor, but the numerous original '68-'69 Road Runners and Chargers I've seen & owned all had GEs in them, and all had the wide ribs on their lenses and had "GENERAL ELECTRIC" on the bottom.
They're ink-stamped on their backsides, but I never bothered decoding them. Even back in the '80s, they were hard enough to find; I used to bone them from the junkyards I visited.
Re: Original headlights [Re: topside] #2412471
12/02/17 11:16 PM
12/02/17 11:16 PM
Monroe, LA USA
Monroe, LA USA
Ok thanks. I just came home with a truckload of NORS sealed beams from a shop that retired.
Re: Original headlights [Re: Carsavior] #2412505
12/03/17 12:16 AM
12/03/17 12:16 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
There is also an ink date stamp.
Re: Original headlights [Re: 71birdJ68] #2412622
12/03/17 11:47 AM
12/03/17 11:47 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
These are the original headlights from my 68 Road Runner - still functioning. Hope they help you out.
Re: Original headlights [Re: Carsavior] #2412629
12/03/17 12:17 PM
12/03/17 12:17 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
One other variation is that superbirds had 2 ge bulbs and 2 westinghouse, cant remember for sure which were highs or lows, think highs were westinghouse.
Re: Original headlights [Re: Carsavior] #2412644
12/03/17 01:31 PM
12/03/17 01:31 PM
New York
rarefish Online content
rarefish  Online Content
New York
My 71 GTX came from the factory with 4 Westinghouse lamps...
Re: Original headlights [Re: rarefish] #2412679
12/03/17 02:41 PM
12/03/17 02:41 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And when I brought this home from Nebraska in 1997 with 18 K miles,it had all Tung-Sol.
Re: Original headlights [Re: 4406bbl] #2412689
12/03/17 03:51 PM
12/03/17 03:51 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
The headlamps on my Superbird all appeared to be original with correct date codes. All 4 were Westinghouse.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Original headlights [Re: RealWing] #2412841
12/03/17 10:17 PM
12/03/17 10:17 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Same with my bird.
Re: Original headlights [Re: 62maxwgn] #2412849
12/03/17 10:35 PM
12/03/17 10:35 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
Same on my '69 RR.
Re: Original headlights [Re: Tempest] #2413073
12/04/17 02:39 PM
12/04/17 02:39 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
These two GEs came off the passenger side of my 69 Road Runner. Anyone know how to decipher the date codes?
Re: Original headlights [Re: Carsavior] #2413119
12/04/17 04:00 PM
12/04/17 04:00 PM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
I believe "4-8" is for April 8 1968.
Do others believe this to be correct?
Re: Original headlights [Re: B5Cuda440-6] #2413127
12/04/17 04:13 PM
12/04/17 04:13 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
That would be my guess too but didn't know for sure. Incidentally, my SPD is September 10th 1968, so perhaps a five month vendor supply time?
Re: Original headlights [Re: CompSyn] #2413144
12/04/17 04:53 PM
12/04/17 04:53 PM
Ohio
rck850 Offline
rck850  Offline
Ohio
There is also H 68 on that bulb, which could be August of 68.
Re: Original headlights [Re: rck850] #2413259
12/04/17 09:37 PM
12/04/17 09:37 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I checked my notes and while I can't comment on the H-68 shown on the bulb, mine did have the stamp of 3-8 on the low beams and 5-8 on the high beams. I thought I had looked up the date code guides and wrote them down as March '68 and May '68 which do fit in with my car's build date in May. I suppose they could have made a bunch of lights on March 8 (mine), April 8 (elsewhere in thread), and May 8 (mine) but I think the Month/Year makes more sense. I can pull a headlight to see if it has the H-68 as well but the car is up on the lift right now. I have a photo of the back but the lettering detail is not that clear...
Re: Original headlights [Re: Carsavior] #2413582
12/05/17 02:46 PM
12/05/17 02:46 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
The GE bulbs are just dated with month-year so 4 68 is April of 1968. When considering which type is correct, GE or Westinghouse, you need to think about WHERE your car was built. I have had a bunch of Lynch road cars and they all seem to be Westinghouse. This would include Superbirds. St. Louis cars seem to all be GE. All the musclecar area bulbs would be the wide flute design. I think the narrow flute didn't appear until 73-74 era. Also it is just needless to search for proper date codes as they are only ink stamped on the backside and you can't tell a 1965 bulb from a 1971 on the front side.
Re: Original headlights [Re: hemi70se] #2413699
12/05/17 06:06 PM
12/05/17 06:06 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Exactly - when and where matters
LA cars I believe were Westinghouse.
Re: Original headlights [Re: hemi70se] #2413789
12/05/17 08:09 PM
12/05/17 08:09 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
I didn't think anyone within this thread stated they were actively searching for correct/matching headlight date codes? I was simply referencing the date code on mine to identify what may be an original brand/type to come on my car.
That said, can you fill me in on wide-flute versus narrow-flute head lights? Not sure what that means?
Re: Original headlights [Re: CompSyn] #2413847
12/05/17 09:55 PM
12/05/17 09:55 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
It had to do with the pattern on the face of the bulb lens. The pattern on the face will focus the light as it passes through the glass. I'm hoping someone finds a good picture of the two different styles side-by-side and post it. The narrower/tighter pattern that they developed later on would focus the light a little farther out and you might see them advertised as +40 bulbs because they would supposedly give you 40 extra feet of driving light...
