key in ignition warning switch 2947488, need interchange #2411593
12/01/17 12:39 AM
12/01/17 12:39 AM
St. Louis, Mo
3
318 Stroker Offline OP
St. Louis, Mo
Would like to know the interchange applications for the key in ignition warning switch, part # 2947488. Goes inside the steering column on my 73 Challenger. I just placed an ad in the E-body parts wanted section, but would like to place in other parts wanted sections if I can find the interchanges.
Re: key in ignition warning switch 2947488, need interchange [Re: 318 Stroker] #2411673
12/01/17 05:04 AM
12/01/17 05:04 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Should be the same as 70-74 b body
Arizona parts should have one.
http://arizonaparts.com/partslist.asp
Re: key in ignition warning switch 2947488, need interchange [Re: 318 Stroker] #2412350
12/02/17 07:36 PM
12/02/17 07:36 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
